***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
#27
Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (My DC2)
theres the black piece on mine, that clips onto another wire, it looks electrical can i leave it on? it doesnt look like it twist off
#31
Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">do you need to bleed the cooling system after doing this?</TD></TR></TABLE>
You can, but you don't have to. Just make sure that your coolant resisivor has coolant in it.
#32
Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm Blood »</TD></TR><TR><TD CLASS="quote">I clean the IACV and the FITV...new TB gasket...yet it still idle rough. When the car is warmin up...its fine until I gas it alittle then it idle fast...1 to 2. What to do? Also when I unplug the plug to the FITV...it idle fine with the check engine light on.</TD></TR></TABLE>
open up the copper-colored plate on the back of the FITv located attached to tha throttle body. there is an off-white circular ring on there that unscrews loose over time. that is sometimes tha culprit of erratic idling.
also make sure your cooling system has no air in it. tha FITv opens/closes according to temperature of coolant. air can sometimes screw it up. this is sometimes the culprit of erratic idling.
you must mean you unplugged tha plug to tha IACv. tha FITv is controlled by coolant temperature. tha IACv is controlled in combination with FITv, idle adjusting screw, and ECM/ECU. but if you have proper idle to begin with, tha idle adjusting screw should not cause or affect any erratic idling problem. you can adjust idle between IACv and ECM. do tha following steps:
- warm engine to normal running temperature.
- check gauge and make sure upper radiator hose is warm/hot. fan should turn on.
- unplug tha IACv from ECM. just remove tha plug on tha IACv. idle should settle low and CEL will come on.
- adjust idle adjusting screw (on throttle body) anywhere from 400-600 (dependant on engine).
- turn engine off. remove key.
- plug IACv back.
- reset ECM. don't remove fuse, ECM will still hold CEL codes. you have to unplug battery.
also, make sure your FITv and IACv are workin' properly, and that you have a good PCV valve. tha TPS is rarely tha problem, unless you screwed around with it. and really make sure you have no vacuum leaks.
i would. i mentioned why above. air pockets can also cause extra heat within your cooling system.
_taF
Modified by tallazzFilipino at 1:14 PM 7/13/2006
- plug IACv back.
_taF
#34
Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (wildoutwhitegsr)
Good stuff...I wish i had that kind of time on my hands...but then again I am to damn lazy...Good write up bro...you get a
#36
Re: (civicrida3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">i would do mine but its dark out lol</TD></TR></TABLE>
you took my avatar (pic of my car), lol.
_taF
_taF
#37
damn this came in handy as hell mine started when you would come to a stop and would jump up from 1000k to 1500k and would just sit solid at 1500 cleaned that bad boy out and it idles perfect
#38
nice write up man going to try it sunday hope it fixes these rpm's from going up and down
#40
IACV a.k.a. Idle Air Control Valve code can't fix
i have a ls/vtec in a 96 hatch, i'm using stock harness, a friend that i knew did the swap for me and now i have to pass inspection, so i took my obd 1 ecu out and put a stock ecu in i have fixed all the other codes that the ecu had but i can't fix the p1509 code. (manufac vec.spd. idle control auxiliary circuit). i have a vixtor-x intake, 65mm edelbrock trottle body, holley fuel rail and preassure reg. i changed all of these and put si intake, throttle, fuel rail, regulator. but the car doesn't like to stay on when i put these stock parts. i put all my stuff back exept i put stock injectord but i cant seem to be able to clear the p1509 code. any ideas????
i have also cleaned and installed 3 different iac's but nothing yet.
#41
Re: IACV a.k.a. Idle Air Control Valve code can't fix (tuyoonly)
i just got done doing this and my car idles at 800. pretty good i guess for now. i have to wait and see if this fixed my problem. i kinda let a lot of coolant out. i might needa refill it
#42
Thanks man for the big help i was gonna make a new tread to see if any one has done this because i need to do this on my car, but thank god i looked before i did. thankz man
#43
Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (Blazineyez)
its been a day and i think its idles a little too low sometimes, like it shakes a little
#49
Re: (rollercosta123)
i was having my idleing jumping up and down and i took out the iacv and cleaned it then put everything back and it works great...after 5min i shut the car off then start it back and the damn thing keeps jumping idle...what do i need to do?
