| Welcome to Honda-Tech! | ||
#1 |
i just wanted to know are the they different or the same.
ps: I heard from someone that the Z6 tranny is a little bit stronger is this true or not thanks |
#2 |
old post but same unanswered question.
#3 |
| Garage is empty, add now |
I have a d16z6 in my si and was wondering how mutch the tranny would take. Are the raitos the same? I put 17" weeles on mine and it slowed it down...... 1/8 mi track. I would like to find a bolt-in tranny with some beef that would give my final Back. what about you,
#4 |
im replacing my z6 tranny with a y8 tranny and wanted to know all the differences.
#5 |
What is the reason for the change did your z6 not hold up?
#6 |
na i bought the car with a auto to manual swap and the wrong tranny mounts were used. after the axle popped out a few times and screwed things up and got replaced (the axle was replaced twice so far) the right mount was put in and the problem still persisted. my mechanic said i would be best off getting a new tranny.
[Modified by bleh, 8:52 PM 12/23/2002] |
#7 |
anyone know the ratios for a 2000 ex tranny?
#8 |
The ratios are the same. The y8 is stronger because the shift forks in the z6's are cast aluminum and may break in the middle of your 1-2 shift at the race track and cause you to run a 30sec quarter. The y8 uses steel shift forks. There are other minor differences between the 2 so the better shift forks dont fit the older trannys. The shortest geared d-series tranny I found is the del sol si tranny. My old one used to wind out faster than my current z6.
Weekdays on Porsche's, weekends on Honda's. Porsche and ASE certified, any questions? |
#9 |
D Tranny Guru
D series tranny god here.............
Only difference gearing wise is 5th gear. 92-95 Civic Si and Sol Si got .750 5th, everything else got .702 5th gear. Check the link in my sig.......
"D" Tranny Guru |
| Tags |
| 750k, 92, d16y8, d16z6, gear, honda, miami, performance, ratio, ratios, regear, stock, tranny, transmission, z6 |
