Go Back   Honda-Tech > Honda and Acura Technical Forums > Hybrid/Engine swaps
Old 03-27-2006, 07:55 PM   #1
dungeonKing
dungeonKing's Avatar
Send a message via AIM to dungeonKing
Default ls swap in 97 civic hx
A friend of mine has installed a B18B in place of the single cam. The engine is out of a 92 integra. The ecu and distributor are out of a 97 integra.
The swap went great, the car starts and idols fine. The problem is when you try to rev the car it wants to bog down, and won't go anywhere.
I know it is a mess, but i am just trying to help a brutha out.
Any info is greatly appreciated!!!
dungeonKing is offline   Reply With Quote
Old 04-02-2006, 09:06 PM   #2
dungeonKing
bump
Old 04-02-2006, 09:14 PM   #3
hatchi
hatchi's Avatar
Default Re: ls swap in 97 civic hx (stifflerEG)
any Cel??
onecleanda,careawholelot,beaterdriver,supervince,e j8,davep,njandrewg,rollydc69,dchung1,b16hybridsol, RaceInspiredDC2, JswineyHB93, AL ASPIRATED,Wild0ne21,ndustryalGSR,drunknbass,Two_K Si, 88crxsir,bob evans, langinthorpe,krazySOHC,pheen0m,Vera, Otacon,Tokyo_X-treme_Racer,TurboDB8,
HatchEh2, butters,fongph,scoop.BlueIntegraBoy,REALek4,surfer chad122, hctjohnson,Bimmerman,LSVtecor82,AssPenny,Top-Fuel,greencivichb,NinetyTwoHB,rocket247,mitsuman,B lackhatch94,Repodevil,Tad,SjCiViCHB,dek1mfk,evil_r yu,q45mm,INDYGSR,LaXcAt
hatchi is offline   Reply With Quote
Old 04-03-2006, 08:34 AM   #4
EKlscoupe_98
EKlscoupe_98's Avatar
Send a message via AIM to EKlscoupe_98
does it only go to 4 on the rpms
97 civic dx ls-t 294whp sold
94 integra rs ls/vtec 401whp/300tq sold
00 civic si new daily grind j-k-tuning and IMW
EKlscoupe_98 is offline   Reply With Quote
Old 04-03-2006, 03:53 PM   #5
dungeonKing
if you rev it slow enough it would just barely make it there. kind of sounds like lack of fuel, but i really don't think that's the problem...
Old 04-04-2006, 08:57 AM   #6
dungeonKing
bump
Old 04-04-2006, 03:39 PM   #7
dungeonKing
bump again
Old 04-11-2006, 08:36 AM   #8
EKlscoupe_98
you need to get a jumper harness that was what was wrong with mine an it was doing the same thing
Old 04-12-2006, 12:21 PM   #9
dungeonKing
bump
Old 04-12-2006, 12:31 PM   #10
slo97coupe
slo97coupe's Avatar
Send a message via AIM to slo97coupe
map and tps backwards?
I <3 BOOBS
slo97coupe is offline   Reply With Quote
Old 04-12-2006, 12:39 PM   #11
schardbody
schardbody's Avatar
Send a message via AIM to schardbody Send a message via Yahoo to schardbody
check the map sensor connection as well, the hx probably had a TB mounted map, and depending on which TB he used it might not have been, so it could have gotten forgotten or not plugged in.
schardbody is offline   Reply With Quote
Old 04-14-2006, 11:43 AM   #12
dungeonKing
bump
Old 04-14-2006, 12:11 PM   #13
92hatchling
92hatchling's Avatar
Default Re: (stifflerEG)
did you mess with the timing
92hatchling is offline   Reply With Quote
Old 04-14-2006, 09:41 PM   #14
dungeonKing
timing is perfect
Old 09-12-2012, 04:59 PM   #15
looseOFFboost
looseOFFboost's Avatar
Send a message via AIM to looseOFFboost
So what happened? having the same issue.
looseOFFboost is offline   Reply With Quote
Old 09-17-2012, 08:57 PM   #16
looseOFFboost
bump
2000, 96, civic, hx, ls, swap
Similar Threads
Need Help Stumped No Fuel Or Spark OrangeTeggy Acura Integra 10 09-01-2014 07:52 AM
k24z1 axel question The_Nightrida K Series 0 11-06-2013 06:05 PM
Swap Perrdog Honda Civic/Del Sol (1992 - 2000) 15 06-25-2013 01:58 PM
b18c1 swap questions! BUCCIek Hybrid/Engine swaps 2 01-12-2013 05:16 PM
B18 no reverse. Help slowDB7 Transmission & Drivetrain 8 10-09-2012 08:13 PM
