B16A rocker arm adjusting nut comes loose
Old 03-23-2006, 09:17 AM
geebs's Avatar
Default B16A rocker arm adjusting nut comes loose
The adjusting nut on the exhaust side for the valve clearance adjusting screw keeps coming loose.. anyone know any remedies? loctite?
Old 03-23-2006, 03:08 PM
tealjdmcrx's Avatar
Default Re: B16A rocker arm adjusting nut comes loose (geebs)
replace the nut and adjuster it very easy. also check the treads on the arm, could be stripped.
Old 03-23-2006, 05:37 PM
geebs's Avatar
Default Re: B16A rocker arm adjusting nut comes loose (tealjdmcrx)
ive got a new nut and screw on order.. just curious as to why it would keep coming loose. they were tight, torqued to spec, the screw wasnt stripped. strange.
Old 09-27-2007, 11:03 PM
alaskanlue's Avatar
hey, where u order one from? I got the same problem but it's on my intake side.
OmgDelSol
04-15-2014 08:29 AM
v1crattlehead
04-01-2009 09:30 AM
beanbag
Suspension & Brakes
02-11-2009 06:04 AM
Quick Reply: B16A rocker arm adjusting nut comes loose
