Go Back   Honda-Tech > Community Forums > General Discussion and Debate > Electronics, Gaming & Photography
Old 03-20-2006, 11:44 AM   #1
T-RO
T-RO's Avatar
Send a message via AIM to T-RO
Default New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter?
I just swapped power supplys on my computer (went from 200 to 500).
The OLD PS plugged into the motherboard with a 20pin connector (MB has a 20 pin slot on it).
The NEW PS has a 24 pin connector on it. I plugged the 24 into the MB's 20 pin slot and it powered up and is running.
Question
1) Does it matter that the remaining 4 pins are not connected?
2) Is there an adapter that will make the MB's 20 pin slot a 24 pin slot?
Thanks...
T-RO is offline   Reply With Quote
Old 03-20-2006, 12:44 PM   #2
loki2323
loki2323's Avatar
Default Re: New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter? (T-RO)
What kind of psu do you have?
I know on mine that the last 4 pins break apart from the clip. I'd assume that the first 20 pins have to be the same. I mean the only difference is that on mine they snap apart from the clip, and on yours they might not.
Only issue I could really think of is that the psu clip might not line up and snap down on the motherboard clip. But it should stay in place regardless
loki2323 is offline   Reply With Quote
Old 03-20-2006, 01:31 PM   #3
EE_Chris
EE_Chris's Avatar
Utzz_
It's just the difference between revisions of connectors. Newer mobo's need some extra juice but the 20 pin part of the 24 that plugs into your mobo is compatible, so no worries there.
EE_Chris is offline   Reply With Quote
Old 03-20-2006, 01:38 PM   #4
Slow*Jim
2000 Mazda Miata
Slow*Jim's Avatar
letostak
Default Re: New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter? (EE_Chris)
a lot of the higher-end motherboards require a 24-pin native connection.
'11 Mustang 5.0
Slow*Jim is offline   Reply With Quote
Old 03-20-2006, 03:36 PM   #5
T-RO
T-RO's Avatar
ok cool. Yeah if i line it up then 20 of the 24 pins plug right in and snap in place. I just wanted to make sure it wasnt gonna cause some issues
Old 03-20-2006, 03:49 PM   #6
Ishouldbebanned
HT Black Ops
Ishouldbebanned's Avatar
Default Re: (T-RO)
I just got a new PSU too and I had the same thing happen. I have a 20 pin MB, so when I opened up the box and saw it was a 24 pin connector and thought "Oh ****, will this work?" I was afraid my system was going to get fried somehow. Click the image to open in full size.
BF2= [HT[ Waffleiron75
Xfire = Ishouldbebanned
Ishouldbebanned is offline   Reply With Quote
20, 20pin, 24, 24pin, adapter, connectors, convert, diffrence, mbs, pin, power, ro, snap, supply, vs24, whats
