Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 03-09-2006, 07:48 PM   #1
O16581724 5 2 5
O16581724 5 2 5's Avatar
Send a message via AIM to O16581724 5 2 5
Default Symptoms of a bad main relay?
'02 Audi A4 3.0 Quattro.
'87 BMW 325is.
'86 Golf GTI VR6 swapped
'84 Rabbit GTI
Satisifed with purchases from: Flamenco-T, wantboost, FJT
O16581724 5 2 5 is offline   Reply With Quote
Old 03-09-2006, 08:34 PM   #2
deadon
deadon's Avatar
Default Re: Symptoms of a bad main relay? (O16581724 5 2 5)
car does'nt start....you also have to listen really good and see if your fuel pump kicks right before you crank the motor. I think also if you turn on your car, see if your fuel guage goes up as well. I went through a few of them. Also watch you igniter and coil in your distributor. There famous for failure. You can solve the coil with just buying a cap and external coil. As for igniters good luck.
deadon is offline   Reply With Quote
Old 03-09-2006, 08:42 PM   #3
O16581724 5 2 5
Default Re: Symptoms of a bad main relay? (deadon)
Not a bad main then, i don't know, check my other thread near this one, i'm getting despirate for a solution, i'm stumped. =\
I've read a few threads on bad mains and they're all like you describe, thought maybe there'd be a few freak cases like mine.
'87 BMW 325is.
'84 Rabbit GTI
Old 03-09-2006, 10:08 PM   #4
JG90CRX-Si
JG90CRX-Si's Avatar
When mine was going out it would start the car then turn it off. I would have to wait a few seconds and try again and it would work fine. When it really started getting bad I would have to try cranking it over couple of times and would hesitate to stay on. Finally one day it bit the bullet but it only cost about $42.00 from Orielly/Autozone brand new and fix the problem.
Good luck
JG Click the image to open in full size.
JG90CRX-Si is offline   Reply With Quote
Old 03-09-2006, 10:32 PM   #5
O16581724 5 2 5
Default Re: Symptoms of a bad main relay? (JG90CRX-Si)
Well, the problem fixed itself!
I don't know what i did, but i hooked a battery charger to it, still dead, then suddenly i got all power, tried to start it, everything shut down. Unhooked the battery terminals while it was still being held on charge, got power back, reattached it to the battery, full power back, started right up, let it run for awhile, shut it down, started right back up again, did that about 10 times.
'87 BMW 325is.
'84 Rabbit GTI
a4, accord, audi, bad, diagnose, distributor, failure, honda, hondatech, integra, main, power, problem, relay, signs, symptoms
