Idle fluctuates with clutch
Old 03-10-2006, 06:46 AM
forcefedish's Avatar
Default Idle fluctuates with clutch
I have a issue with my car dying when i push the clutch in, even in neutral, but only when its hot and i rev the engine then push in the clutch while its coming down in revs........the odd thing is whenever i just push the clutch in neutral the rpm's will fall from like 750 to just below 500 if i keep the clutch in, it will correct back up to 750, if i then let the clutch back out it drops and resets again...its really weird cause when it does die from driving and pushing in the clutch, whenever you restart it makes a knocking noise right when you start it then starts fine....just a quick knock knock.....but if you just cut it off and restart doesnt make this noise , any ideas any help would be appreciated, by the way this a brand new motor and clutch that just got put in, running chipped p28
Old 03-10-2006, 10:41 AM
Default Re: Idle fluctuates with clutch (forcefedish)
bump
ic89
25
10-16-2006 12:08 PM
Jmumblez2001
08-08-2006 12:05 PM
Stoich EG2
03-21-2005 05:53 AM
2001civ
04-26-2003 01:36 PM
Quick Reply: Idle fluctuates with clutch
