> Tech/Misc
Old 03-02-2006, 05:18 AM   #1
-DC2-
-DC2-'s Avatar
Default HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings
in this thread i will discuss how to plumb your clutch line using AN fittings and a braided feed line. this will allow you to tuck/run the line anywhere you want it.
DISCLAIMER:
there's absolutely no performance benefit, it's purely for asthetics
stuff you need to know:
- the threads for the clutch master cylinder and slave cylinder fittings is 10mmx1.0
- use steel fittings
- brake fluid eats paint. DO NOT GET BRAKE FLUID ON THE PAINT. if you spill any fluid during the install, clean it up IMMEDIATELY.
- don't use teflon tape for AN/flared connections. teflon tape is only need for "square" or thread only sealing.
PARTS LIST
everything you need can be had on summitracing.com. i HIGHLY recommend them!
(1) pair Male -3 AN to Male 10mm x 1.0 Earls Brake Adaptors ($11.99) EAR-592032ERL
NOTE: see the reverse flare on the 10mmx1.0 side, that is needed for a perfect seal
(2) steel -3 AN swivel hose ends - style is up to you (~$10 each)
note: on summit search for "-3 AN swivel hose end". AER-FBM1120 is a nice 90deg option. or, perhaps a 45deg is needed for your app, AER-FBM1110. there's even a 120deg bend.
(1) -3 AN braided hose 10ft length ($35) - AER-FCC0310
NOTE: of course, use whatever length is necessary for your application. 10ft is probably enough for most people, but figure out where you want to route the hose and get out the tape measure.
(1) DOT 3 brake fluid - any qty/brand should work
(1) buddy - to help bleed the clutch. or, get a vaccuum assist pump and figure out how to connect it to the clutch resevoir.
THE INSTALL
prep the braided line for install by installing hose ends and tightening. check this link for swivel seal end install instructions.
map out the install in the engine bay to make sure you understand exactly where things need to be placed
1. remove your OEM fittings and hard lines (10mm). use flare wrenches on the hard line fittings so you don't destroy them. be prepared to have something to catch the fluid that will leak out.
2. install the brake adaptor fittings on the clutch master cylinder and slave cylinders
3. install the braided line from the master cylinder to the slave cylinder routing it whereever you want it
4. fill the resevoir with fluid and bleed the clutch just like you bleed brakes
Modified by DOHCvtecDX at 6:50 AM 8/11/2006
Modified by DOHCvtecDX at 6:54 AM 8/11/2006
<FONT COLOR="blue">formerly DOHCDX, DOHCvtecDX</FONT>
<FONT SIZE="1">
Vouches, buy from good sellers
</FONT>
-DC2- is offline Report Post   Reply With Quote
Old 03-02-2006, 06:57 PM   #2
old man neri
old man neri's Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (DOHCvtecDX)
Originally Posted by DOHCvtecDX
DISCLAIMER:
I am happy you put this disclaimer.
Nice work,
Cheers.
old man neri is offline Report Post   Reply With Quote
Old 03-03-2006, 06:20 AM   #3
SkankyEJ7
SkankyEJ7's Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (old man neri)
does the braided line have any problems with expanding under extended use?
what was the total of all of this
2003 RSX type s
1998 civic lx
wēk´sôs ĭn'dustrēz
SkankyEJ7 is offline Report Post   Reply With Quote
Old 03-03-2006, 06:35 AM   #4
-DC2-
-DC2-'s Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (98ekhx)
no, definitely not. these hoses are rated to ~3000psi
total cost: ~$80
[edit] i removed a reference to brakes
Modified by DOHCvtecDX at 10:38 PM 3/7/2006
Old 03-03-2006, 08:03 AM   #5
bdavis
bdavis's Avatar
got any pics of this, im curious to how it looks. i may do it the next i rob a bank
bdavis is offline Report Post   Reply With Quote
Old 03-03-2006, 08:20 AM   #6
-DC2-
-DC2-'s Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (bdavis)
no, not really. the idea behind doing this is that you don't see it.
Old 03-03-2006, 08:32 AM   #7
bdavis
bdavis's Avatar
how do you have it routed to the the slave cylinder. do you have it tied anywhere to the frame or any brakets or anything. i think this could be the ultimate in blinging your bay
Old 03-03-2006, 08:47 AM   #8
-DC2-
-DC2-'s Avatar
most stay in the engine bay and have it run over the rear x-member to the back of the trans, under the starter to the cylinder in the front.
Old 03-07-2006, 05:10 PM   #9
mattcivic
mattcivic's Avatar
Send a message via AIM to mattcivic
great how to thread i was thinking of doing this while doing my ABS removal i broke one of my clutch hard lines glad i found this article another question answered by the SEARCH option.
<U>MY RIDES</U>[b]
01 dodge 2500 6-speed cummins
89 civic wagon B18c1, crv 5 speed trans AWD FTW!
mattcivic is offline Report Post   Reply With Quote
Old 03-07-2006, 06:35 PM   #10
Blown90hatcH
Blown90hatcH's Avatar
Send a message via AIM to Blown90hatcH
Cool man, but I have some comments. What pressure do you think those swivel seal fittings are rated for where they meet the hose? Do you think there is a reason that stainless braided brake lines are compression crimped and not twist / seal like what you did? What inside pressure does a stock brake line undergo? Just some thoughts I hope you considered.
Blown90hatcH is offline Report Post   Reply With Quote
Old 03-07-2006, 07:19 PM   #11
old man neri
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (Blown90hatcH)
Yo, blown90hatch, is that a FEA of a turbo assembly? (your avatar)
Old 03-07-2006, 07:26 PM   #12
Blown90hatcH
Yes it is man.
Old 03-07-2006, 07:37 PM   #13
-DC2-
-DC2-'s Avatar
who's talking brakes? this is a clutch hydraulic system. no where near what pressures the brakes see
there are fittings and hoses sold that are designed specifically for brake use. i removed the above reference to brakes. i'm not implying that anything shown here can or should be used for brakes.
Old 03-07-2006, 07:48 PM   #14
old man neri
Yes it is man.
Sexy. What do you do for a living? You seem almost engineeringish, or student engineeringihs by what you said and how you said it. Just a guess.
Old 03-07-2006, 08:02 PM   #15
Blown90hatcH
I am not nocking you man, I just want to make sure people understand the pressures in the systems. For a clutch system, this shouldn't be an issue. The other guy made reference to an ABS system and all. The hose and fittings are rated accordingly, but the mating of the two may not be brake worthy.
Mechanical engineer, aerospace structures/thermal. /End thread highjack and back to a good topic.
Old 05-17-2006, 01:56 PM   #16
maxpsi
2000 Honda Civic
My Garage
maxpsi's Avatar
Send a message via AIM to maxpsi
Ordered everything from Summit. I also ordered padded clamps to securely mount the line along the firewall and across the tranny.
2008 NBP Honda Fit
72 Camaro SS 350 Placer Gold
maxpsi is offline Report Post   Reply With Quote
Old 05-23-2006, 04:36 PM   #17
guymosiris
guymosiris's Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (maxpsi)
Probably a stupid question, but what would happen if you use -4AN lines and fittings with -4AN to 10mm x 1 adapters? Would it work safely, or would the increase in size cause a failure somewhere? And yes, I know, theres no benifits in doing this, but I was just curious.
<U>Sold To</U> B18CJDM GSR,IVANITR,B18Flip,Curtisbeef,SM 30 Hatch, undagroundrican,Legend_master,Overcover_Skankz,Cha dB,slo4door, $ISELLTOU4LESS$,BlackDC2_05, ingrate,koolaid3246,95 integra,BoostedGreddy, jacknimble,King Tut33,willie_su2166,You Know I Got SOL!,vtec99,Upperguy
guymosiris is offline Report Post   Reply With Quote
Old 07-20-2006, 05:56 AM   #18
-DC2-
-DC2-'s Avatar
Default Re: HOW-TO: convert OEM hydro clutch hard line to braided flex line for AN fittings (guymosiris)
maybe a slight difference in pedal travel (reduced) as a larger line will move more fluid
Old 07-26-2006, 05:12 PM   #19
mattcivic
mattcivic's Avatar
well i made the line not much to realy see but it worx just fine
i only used 4 1/2 feet of the 10 foot junk and i have 2 of the AN to inverted flare fittings so im gunna make my friend a clutch line as well. if i did it again i would have only used 4 feet of line its a lil long but it worx awsome great write up thanx
<U>MY RIDES</U>[b]
Old 08-07-2006, 06:11 PM   #20
JDMorgan
JDMorgan's Avatar
Send a message via ICQ to JDMorgan Send a message via AIM to JDMorgan
good job on the writeup.
JDMorgan is offline Report Post   Reply With Quote
Old 08-09-2006, 02:40 AM   #21
methos713
methos713's Avatar
Default Re: (KraZEtEggIE)
nice
Vouch list: eg8kid, redasphalt, camp1320, jdmstylesi/robearracing, N.O.B, #1151, R6Boy69, PerformanceCloseout, ValleySyder, OnlyHJC, civic dx 4dr, GoT HaTcH, Hondaruss, regamaster, soulpwr, sky9, acuraturbo90, thareddb, 96civic_hb
http://images.honda-tech.com/set1/smile/emthup.gif
methos713 is offline Report Post   Reply With Quote
Old 09-07-2006, 04:35 PM   #22
sauceja
sauceja's Avatar
Default Re: (methos713)
Just ordered from Summitracing.com
EAR-592032ERL 1 @ 11.99
EAR-600103ERL 1 @ 5.25
AER-FBM1120 1 @ 9.88
AER-FCC0306 1 @ 31.95
Total 59.07
Handling charge 9.95
2nd day air 12.00 (in a hurry as always)
Grand total paid 81.02
I decided on a straight piece for the slave cylinder as I am keeping to the stock routing kinda.
Will take pictures when installing.
My Build
FS: honda Service Manuals and ETM
Leaving the game for a bit! I will return stronger!!
sauceja is offline Report Post   Reply With Quote
Old 09-07-2006, 06:26 PM   #23
-DC2-
-DC2-'s Avatar
Default Re: (sauceja)
glad to see the thread going strong. i have not had a single leak or problem with my conversion
Old 09-07-2006, 09:46 PM   #24
mattcivic
mattcivic's Avatar
Default Re: (DOHCvtecDX)
same here
<U>MY RIDES</U>[b]
Old 09-07-2006, 11:24 PM   #25
Muckman
Muckman's Avatar
Send a message via ICQ to Muckman Send a message via AIM to Muckman
What about if you just wanted to convert the section downstream of the rubber section? Is the fitting at that junction 10x1.0 too?
425whp/300ft-lbs at 17psi
Muckman is offline Report Post   Reply With Quote
Bookmarks
braided, clutch, crimped, hard, hardline, honda, hose, line, replacing
