Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura TL, RL & ZDX
Old 02-26-2006, 11:07 AM   #1
tnord
Send a message via AIM to tnord
Default replacing head gasket on 94 legend
well, after having sporatic but reoccuring cooling problems, the source finally reared its ugly head in the form of white smoke out the tailpipe.
i'm pretty mechanically inclined (have built entire engines from a bare block), so i thought i might try this myself. the issue is i've never done any real work on anything but a 4cyl. has anyone here done this and want to offer up some advice, words of encouragement, or words of discouragement?
91 Spec Miata - 90% done
01 Silverado 5.3 Z71
94 Acura Legend - FOR SALE $4250
Kansas City Region SCCA
"Find Tenths." - Pat diNatale
"it's easy as hell to drive inside of someone if I have enough power to overcome the fact that my apex is rooster-in-the-morning early." -Kirk Knestis
tnord is offline   Reply With Quote
Old 02-26-2006, 11:36 AM   #2
CmptchAV6
CmptchAV6's Avatar
Send a message via AIM to CmptchAV6
Default Re: replacing head gasket on 94 legend (tnord)
here should be all the info you need Click the image to open in full size.
http://www.acura-legend.com/vb...65753
- Dustin
Current Cars: 2005 Acura TSX Navi Auto stock
2009 Nissan Versa 1.6 Manual
CmptchAV6 is offline   Reply With Quote
Old 02-27-2006, 08:55 AM   #3
sixfiveoh
Sweet Title
sixfiveoh's Avatar
Send a message via AIM to sixfiveoh
Default Re: replacing head gasket on 94 legend (CmptchAV6)
i ran into this problem myself, and many told me that getting a fresh motor would be the better path to go
european whippin' it
sixfiveoh is offline   Reply With Quote
Old 03-03-2006, 04:58 AM   #4
tnord
perfect....thanks for the link.
i'm not even going to consider a new motor since i'm just going to turn around and sell it.
Old 03-06-2006, 03:47 PM   #5
tvrsir
tvrsir's Avatar
one suggestion, be carefull with those knock sensors when removing the heads, you tend to hit them with the heads when taking it out. so if i were you i would just remove the sensors first then remove the heads
then install the heads then reinstall the sensor.
ask me how i kow Click the image to open in full size. i've broken them
"AFTER 5000 RPMS ALL HELL BREAKS LOOSE"
tvrsir is offline   Reply With Quote
Old 03-06-2006, 04:16 PM   #6
tnord
Default Re: replacing head gasket on 94 legend (tvrsir)
i'll remember that....thanks.
i'll be starting on this in the next couple days.
Old 03-15-2006, 06:49 PM   #7
tnord
i dunno how you guys work on these cars.....
without a doubt this is the worst car i've ever turned a wrench on. i've never seen so many vacuum lines on a non rotary powered car.
for those of you that have worked on these cars.....is there something attached to the back of the intake manifold that i can't see? i seriously can't tell why it won't come off.
Old 03-16-2006, 07:46 PM   #8
Kenso
HT White Ops
Kenso's Avatar
Did you disconnect the PAIR pipe from the PAIR valve on the back of the manifold? (pipe runs from the valve to the driver's side exh. manifold). Also make sure you removed the EGR pipe from the EGR valve mounting bracket to the bottom of the intake manifold.
Kenso is offline   Reply With Quote
Old 03-18-2006, 10:06 AM   #9
tnord
Default Re: replacing head gasket on 94 legend (Kenso)
it was the EGR that needed to be disconnected. from the side, it didn't look like the intake manifold was connected to it, but obviously, it was.
i still hate working on this thing. out to the garage i go, heads are coming off this afternoon.
thanks.
Old 03-24-2006, 02:44 PM   #10
b16pwrcrx
b16pwrcrx's Avatar
Send a message via AIM to b16pwrcrx
yea a buddy at work did 2 headgasket cars last week, they def look like a pain in the ***. are u gonna take the heads to get milled?
b16pwrcrx is offline   Reply With Quote
Old 03-27-2006, 09:08 AM   #11
tnord
Default Re: replacing head gasket on 94 legend (b16pwrcrx)
nope. i just checked them with a straight edge and feeler guages. they checked out just fine.....so i lucked out a little bit there.
now i'm trying to figure out which knock sensor goes on which cylinder bank. there's a one with a blue wire and one with a gray wire. i'm thinking it probably does make a difference which one goes on which side.
anyone......anyone.....bueller?
Old 03-27-2006, 05:53 PM   #12
Kenso
HT White Ops
Kenso's Avatar
Fun isn't it? Red/Blue to the driver's side sensor, white to the pass. side sensor. I posted the schematic from the Helms in your thread on A-L.com if you want to check it out. Here's the pic from when I did my Type II head swap a while back.
Old 03-28-2006, 02:10 PM   #13
tnord
no, it's not fun.
thanks for replying (in both threads), i'm going back to work on it tonight.
94, 95, acura, changing, del, gasket, gaskets, head, honda, legend, price, replace, replacing, sol, typeii
