Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura RSX DC5 & Honda Civic EP3
Old 02-19-2006, 12:32 AM   #1
92 honda ex
92 honda ex's Avatar
Default Adjusting headlights on 2002 civic
How do you adjust the headlights on a 2002 Civic?
92 honda ex is offline   Reply With Quote
Old 02-19-2006, 12:39 AM   #2
chizzadd
Send a message via AIM to chizzadd
Default Re: Adjusting headlights on 2002 civic (92 honda ex)
just take a long phillips head screwdriver and put it straight down b/t the little hole in the frame of the car (immediately after the headlight housing) (in the upper tie bar) and keep going until it touches the gears. I think that one (on the outside more) adjusts the up and down. To go left and right (which might be up or down), go more from the middle of the car, near the grille, at angle to teh headlight.
If you are standing looking at the headlights from the front of the car, point the screwdriver at about a 45 degree angle to the left and you'll find the adjustment on thh left headlight (ur left b/c ur looking at it from the front) close to where the light frame narrows.
If this isn't good enough, post another thread and i'll help best i can.
chizzadd is offline   Reply With Quote
Old 02-19-2006, 01:17 AM   #3
m.kusanagi
m.kusanagi's Avatar
Default Re: Adjusting headlights on 2002 civic (chizzadd)
This the same method for the si?
EP3 Squad Member #04
m.kusanagi is offline   Reply With Quote
Old 02-19-2006, 02:29 AM   #4
chizzadd
Default Re: Adjusting headlights on 2002 civic (m.kusanagi)
i believe so
Old 02-19-2006, 10:58 AM   #5
92 honda ex
So, do I need the hood open to do this? I "think" I follow you but maybe not.
The adjustments will be made from the front of the car.........correct?
How long a screwdriver will I need.....about a 6 inch?
Old 02-19-2006, 11:31 AM   #6
chizzadd
well yes you need to pop the hood
you will pop it then look down on your headlight kinda and its behind it
6in or longer most likely
Old 02-19-2006, 04:28 PM   #7
BarracksSi
BarracksSi's Avatar
Send a message via AIM to BarracksSi
So you're asking about the Si?
Hang on, I've got this somewhere...
BarracksSi is offline   Reply With Quote
Old 02-19-2006, 04:35 PM   #8
BarracksSi
BarracksSi's Avatar
Right from the service manual for the 2002-03 Civic Si, the key illustration about adjusting the headlight (I assume that you already know how to determine where they're supposed to be aimed, etc).
I'm a long ways away from home right now, so I can't check my EP's owner's manual to see if it has the same thing.
Old 02-21-2006, 03:05 PM   #9
92 honda ex
Default Re: (BarracksSi)
Thanks! Would this also be how the Accords adjust?
02, 2001, 2002, 2005, adjust, adjusting, aiming, angle, civic, ep3, headlight, headlights, honda, si, video
