15x7 35+ offset users
Old 08-31-2005, 03:18 PM
eg6sir-s's Avatar
Default 15x7 35+ offset users
i just wanted to know if there's anyone that has used this particular size and offset on the track or street.
i wanted to know how your clearance was civic and or integra brakes? tire size? rubbing of the wheels on full turns?
Old 08-31-2005, 03:19 PM
Future Texas Boy
vtecvoodoo's Avatar
Default Re: 15x7 35+ offset users (eg6sir-s)
I had +35 te37`s w/ huge AP brakes under them. Tires were 205/50/15. No rubbing issues at all.
Old 08-31-2005, 06:20 PM
IM ALL BOB's Avatar
I have been running sm058s 15x7 31+mm offset w/azenis 205/50 tires..front was fine with no rubbing but the rear could not be lower than 1.5inches and just rolled the fenders and it is fine with no rubbing
Old 08-31-2005, 08:00 PM
.RJ
.RJ's Avatar
I have them on my integra... 205/50/15's rub slightly on the rear fenders, which would be solved if I wasnt lazy enough to roll them.
Old 09-01-2005, 12:13 PM
Mt3c's Avatar
225/50 front and rear. rear is rolled, and i get slight rubbing every once in a while.
Front will rub at full turn.
clears legend brakes in front easily.
this is on a dc2
Old 09-01-2005, 12:30 PM
AutoXer's Avatar
Default Re: 15x7 35+ offset users (Mt3c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c &raquo;</TD></TR><TR><TD CLASS="quote">225/50 front and rear. rear is rolled, and i get slight rubbing every once in a while.
this is on a dc2</TD></TR></TABLE>
Has anyone tried this on a 96-00 Civic? Since nobody makes a 215 for 15", I've been curious as to wether a 225 would fit.
Old 09-14-2005, 10:28 AM
JJ-Built's Avatar
Default Re: 15x7 35+ offset users (AutoXer)
yes.. I'm curious also...
I'm debating on getting some 15x7 +35 offset wheels on my EK... lowered on Omni sports coilover kit...
bump..
Old 09-14-2005, 11:24 AM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
i have a 2000 civic si....i run 225.45.15 on 15x7 35 offset wheels... no rubbing...have rolled fenders and i'm slammed!
Old 09-14-2005, 11:47 AM
Eee Pee's Avatar
Default Re: 15x7 35+ offset users (chad)
02 Si 225/50/15s, lowered 2 inches, no rub anywhere.
Old 09-15-2005, 10:33 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
Good to know. I'm not slammed (small gap up front, slight tuck in rear), would rolling still be necessary?
Old 09-15-2005, 10:50 AM
Moderator
chad's Avatar
yes i would suggest rolling your fenders....
my fenders would rub if they weren't rolled
Old 09-15-2005, 11:02 PM
D Tranny Guru
Mista Bone's Avatar
15x7 +35mm Primes with 195/50/15's, Eibach Pro's, no rubbing ever.
Old 02-17-2006, 04:09 PM
743power's Avatar
Default Re: 15x7 35+ offset users (Mista Bone)
sorry to bring this back up.
I was previously running 15x7, et38 k1's with 205/50-15 azenis rt615 and I was rubbing the rear fenders, and the front fender liners.
I never fully rolled the rear fenders, so that is fixable, but the front fender liners I couldn't see how to correct other than taking them out. Is that what ya'll are doing?
The reason I ask is because I am going to buy some 35mm 15x7 and I don't want to be rubbing all over the place.
Old 02-18-2006, 08:35 AM
743power's Avatar
Default Re: 15x7 35+ offset users (743power)
hm, what happened to Jaker's post after mine, that's weird.
Old 02-19-2006, 06:49 AM
743power's Avatar
so before i order the new wheels, are you guys still running front fender liners? that's what I'm really worried about
Old 02-19-2006, 04:32 PM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">so before i order the new wheels, are you guys still running front fender liners? that's what I'm really worried about</TD></TR></TABLE>
I didn't/don't have fenderliners...
Old 02-19-2006, 05:04 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">hm, what happened to Jaker's post after mine, that's weird.</TD></TR></TABLE>
I posted something about 215/45-15 Toyos in response to the post about there being no 215 tires in 15", and then realised that this thread originated about 6 months ago, so there was no point to my post. But then you posted as above, so I felt obligated to respond !
Old 02-19-2006, 05:08 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to know if there's anyone that has used this particular size and offset on the track or street.
run both....street and track
no clearance issues with stock civic brakes 92-00 no clearance with gsr knuckles itr calipers and rotors.
full turn might rub atitty bit...but when are you ever at full lock...especially on track!
225/45/15 toyo's hoosiers and hoosier rains
redGSRguy
10-19-2006 12:31 PM
White98LS
19
08-28-2006 09:10 AM
Andrew 825SM
06-14-2005 07:00 PM
C-speed
15
06-11-2005 05:42 PM
bdicustoms
17
02-19-2004 06:19 PM
Quick Reply: 15x7 35+ offset users
