#1 | |||||
Q45mm http://images.honda-tech.com/set1/smile/emsmilep.gif DIY how to install fog lights http://honda-tech.com/zerothread?id=1380666 Info http://honda-tech.com/zeromodi...32040 |
#2 |
This is a nice informative post...
You should definatly also post this in the faq's section so others can quickly find it later down the road: http://www.honda-tech.com/zerothread?id=642479 |
#3 | |
#4 |
Guest
Posts: n/a
this might be a little extreme.. but what about polishing the pats of the oil/coolant. blend the radius of the oil pump, maybe a oil cooler in the front
#5 |
Your thermostat opens and closes at certain temps to ensure proper rate of heat dissipation. This may negate the effect of changing to a primarily water based solution. Also the surrounding air temperature plays a big role in the heat exchange process. Maybe using a water solution with an engine block heater would do the trick for the wintertime.
I believe most people remove the thermo if they're on a race track. |
#6 |
that is so true.
i see the point now. |
#7 |
Great Information.
#8 |
yeah. You can run 200hp motors on stock radiators. No need to change them just because you did a swap. And I don't see how anything right here is supposed to add hp.
Swaps, engine work, street tunes cheap in Chicago area, pm me. |
#9 |
Nice info, to bad its almost totatly useless
a radiator won't give you ANY power
#10 | |
no power in these mods........../thread
#11 |
great post
#12 |
Okay it was just a catchy title, sorry there is not direct hp related info.
But it seem that you don't understand the fact of thermal efficency since that goes hand in hand with hp. So instead of me typing up a informative post about thermal efficency I suggest you do a little research.
#13 | |
But IMO that doesn't take away from the fact this is good usefull information. I'm personally am more concerned with efficiency, than hp numbers. |
#14 |
man can a mod change the title or something? its setting the tone for a lot of negative comments on a post that is informative.
#15 |
Okay mods please change the tittle..
Im reporting my self
#16 |
Awesome write up.
Vtec Protector Member #001 2007 GSX-R new toy Incredible |
#17 |
it is a good write up...also the cooling system effects the power more inderectly than directly, no none of those things will give you power but if your motor runs so incredibly hot it could overheat or create so much heat that you loose power
1992 honda prelude RIP http://images.honda-tech.com/set1/smile/emsad.gif 1994 acura integra gs-r with jdm b18c gs-r swap http://images.honda-tech.com/set1/smile/emthup.gif |
#18 |
nice...
- 93 Civic EX: DD - 93 Prelude Si-VTEC #905: Safe! Men's Almanac http://images.honda-tech.com/set1/smile/emthup.gif |
#19 |
Bump for more people to see.
#20 | |
Nice write up, and you didn't skip anything. People should know this stuff.
#21 | |
#22 | |
#23 | |
Second of all in GT 1-4 you can't change your raditor genious. You are changing the intercooler, that's what gains you power. God just stop...
#24 | |
Never actually played the game
#25 | |
Anyways you are confusing thermal efficiency and cooling system. Thermal efficiency is ability of the engine to use the thermal energy and change it into mechanical energy. Nothing to do with a cooling system. Cooling system just extracts all the thermal energy that wasn't trasfered into mechanical to prevent overheating. This is ****en dumb but I can't really explain it to you. Go take some physics classes or something.
| Bookmarks |
| Tags |
| 1992, charleston, chart, circulation, civic, coolant, cooling, del, flow, honda, il, integra, sol, system, tech |
