#601 | ||||||
#602 |
For those who have their fully built ls/v motors did u guys balance the pistons,rod and crank or just the crank itself? Another question my motor is almost built all i need is lsd other then i have everything for my motor anyways back to the question what am i going to expect when i first step on it? i have a 13 sec right now and i know this motor is going to be way different considering it my first b series motor being done.
#603 |
As far as my setup goes this is what i have so far B16 Head Skunk Pro Series Springs n Retainers Skunk Pro Series Valves Skunk Pro Series Stage 1 Cams Skunk Pro Series Cam Gears Skunk Pro Series Fuel Rail Edelbrock Victor X Intake Manifold Blox 72mm Throttle Body Cometic 84 headgasket B18 Block GE Sleeves 84mm bore GE Block Girdle CP Pistons Manley Turbo Tuff Rods ACL Rod Bearings Calico Main N Thrust Bearings ARP Headstuds Balanced Crank GSR Transmission CFT 1st Gear Longer Wavetrac lsd Competition twin disc clutch As far as the turbo kit were going with a pt67 precision turbo. I haven't bought the turbo kit just yet so i soon as i buy the kit i will let you guys know. This is everything i can think of right now of the top of my head. Let me know what u guys think about this setup thanks. My horsepower goal is going to be from 600-650 for now.... |
#604 | |
97 coupe- 13.8 boooost FTW http://images.honda-tech.com/set1/smile/emthup.gif http://www.honda-tech.com/zeroavatar/192549 |
#605 |
#606 |
here's my toy 93 delsol lv/vtec turbo stock motor for now,geting it tuned soon
#607 |
ls-v turbo WHAT YA THINK
-------------------------------------------------------------------------------- I have a ls-v plan to do this setup what kind of power ya think ill probably be making build head and stock block just a block guard with south florida turbo manifold with a gt35r t3 1000 injector,victor x manifold.... |
#608 | |
And the only way to determine what power a motor will make is to take it to the dyno and see. Everybody is gonna have a different opinion on what power a certain engine will make, which is useless. Set a power goal yourself, based on what kinda driving you're gonna be doing, and make sure your tune is spot-on.
Precision Powered Stock Integra LS (304 whp @ 14psi) '99 NBP TL (under VIP construction) Tuned at Adrenaline Autoworks |
#609 |
bump for all these nice setups
Curtis P IFLYBYEE™ http://images.honda-tech.com/set1/smile/embeer.gif EXECUTIVE AUTO COLLISION http://images.honda-tech.com/set1/smile/embeer.gif Forcefeds The Best Preformance Shop End Of Story... http://images.honda-tech.com/set1/smile/emthup.gif |
#610 |
bump. i hope i can start on mine soon!!!!
Brandon TEAL HATCH CLUB MEMBER #71 92 civic VX H22 12.91 on spray. on a quest for H2B in 09! 91 civic hatch B20b, F2 coilovers LSD |
#611 |
you guys think stock bottom block and a built head with a t3t4 turbo like at 7 or 8psi good for just a daily aint tryin to put alot of hp
Rest In Peace... Bernard Profeta Jr aka *Bloody B* 9/29/79-3/24/08 BIGG DREAMERS..."NEVER SLEEP!!!" |
#612 |
theres guys on here putting more boost than that to a stock set up, but im sure it would be fine with a good tune.
#613 |
koo thanks just too broke to build the bottom end right now
#614 |
no prob, we have all been there man..... shit, im there right now just deciding where to start.. haha
#615 | |
84.5mm sleeved block by golden eagle eagle rods 9:1 compression B16 head most likely ITR valvetrain and Cams will be using a miniram manifold possibly a 60-1 turbo because a good friend of mine is selling it to me 3inch exhaust/downpipe |
#616 |
does any1 run oversized valves and how much did they help
ej8 squad #502 |
#617 |
heres my set up..
b18a1 bottom end completly stock b16 head rocket valvetrain ctr cams str intake mani sls topmount garrett t3/61 HO precision 1000s walbro 255 intank tuned on crome pro jdm b16 lsd trans hasport rear monut ![]()
11.75 @120 stock block ls/vtec @ 12 psi full interior jdm front integra |
#618 |
My setup:
To be instaled within the next month or so! b18b bottem end Wiseco Pistons 81.5mm Golden Eagle Rods Golden Eagle Ls/Vtec kit Stock jdm b16 head skunk2 intake manifold b16 trans Act flywheel Comp. stage 4 clutch Full-Race ramhorn mani .60 trim Garrett turbo Full-Race down pipe Tial 44mm Wastegate Greddy Type S BOV Rc 750's Tuning will be done by J-K Tuning Neptune Still got alot more stuff to pick up but hoping to make 400hp Anyone else make 400 on a similar setup???
92 Dx Hatchback- The Bread and Butter Full-Race/InnovativeMotorWorks/J-K-Tuning 445whp / 325tq @ 20psi |
#619 |
nobody is running at least power steering lol. i had to cut my a/c but that was the limit!
#620 |
what hp are wiseco pistons rated at ??????????????
ej8 squad #502 |
#621 |
1989 Honda CivicMy Garage Join Date: Sep 2002
Last year I had this set up B18b stock sleeves,itr head and gt35r.Made 490hp and went 10.52@142.
This year set up ( Almost ready ) Motor: GE Sleeved B18b 81mm cp pistons 9.1 comp eagle rods acl bearings GE ls vtec conversion stock ls crank ITR head pnp Ctr cams Supertech 1mm os valves Supertech valve springs and retainers Victor X IM Blox 75mm TB Fuel: Rc 1000cc injectors FJO inj driver Fullblown fuel rail ( -10an ) FR Fuel sump Aeromotive A1000 fuel pump and filter Aeromotive FPR Tranny Gsr with 4.05 Mfactory PRO FD Mfactory 1st gear Clutchmasters twin stage 7 Dss stage 5 axles Managnent Hondata S300 with gear dependent Aem Boost controller Crane cams ignition Crane cams external coil Turbo Precision SC6262 billet turbo FR Ramhorn manifold Tial 44mm wastegate Tial 50mm Q BOV Custom 3" DP EBay intercooler Custom ic piping Custom oil catch can with -10 pipes Wheels Lenso XPD 24.5/9/13 with MT Lenso XPD-r 24/3.6/15 This is this year's set up Hoping for 600hp and high 9's on an EF civic 2450lb w driver
Civic EF 680hp@34psi .... ..Hoping for 9's this year
#622 |
1995 Acura IntegraJoin Date: Aug 2007
Engine:
B18C1 Head B18B Block ITR Cams Skunk2 Cam gears Edlebrock Victor X IM 750cc RC Injectors 255lph Walboro Peakboost Ramhorn Manifold T3/T4 Garret 57trim Tial WG/BOV Hondata S300 w/boost 3" DP 3" Vibrant Exhaust Hasport Motor Mounts 317whp @ 7200rpms 9.5psi Suspension: Eibach Sport KYB AGX's Full-Race Traction Bars 17" Motegi wrapped in Nitto's Interior: Bride Seats Schroth Harness w/ Harness bar ![]() ![]() ![]() ![]()
95 Integra LS-T (was)222whp 170tq (was) 260whp 202tq @9psi LS/Vtec... 317whp@ 9.5psi |
#623 |
^^^NICE....... your car made good power at 7200rpm. BTW i like your car. how much did he charge you to tune your car
#624 |
The tune was $550... but he helps me out alot since I do a lot of business with him. I would recommend Anthony to all my buddies!
#625 | |
Servion tuned93 4dr Honda Civic TO4 R 631 whp 438TQ 1.6 60' 11.4 @ 122 on 15 psi |
| Bookmarks |
| Tags |
| 25x87, 601, 98, b16, boost, crx, hasport, low, ls, lsvtec, mh, slicks, supercharged, tuning, vtec |
