lifted hood???
Old 01-26-2006, 09:10 PM
weezo182's Avatar
Default lifted hood???
i have seen on a few cars that the back side of the hood is lifted up a lil, how is this done and what the purpose? i basicly figure its for air flow, is it that great of a mod?
thanks for the help
Old 01-26-2006, 09:20 PM
ABK
ABK's Avatar
Default Re: lifted hood??? (weezo182)
Get longer bolts, and put some spacers on the hinges. If your hood flies up, it ain't my fault.
The purpose:
A. To let hot air out from the engine bay, increase cooling.
B. Just for show
Most people just do it for show.
The funny thing that it actually works.
Old 01-26-2006, 09:27 PM
midwesta's Avatar
Default Re: lifted hood??? (ABK)
it doesnt do ****,
its been proven.
Old 01-26-2006, 09:28 PM
weezo182's Avatar
thanks for the info, maybee if i do it i can get into the Ek squad
Old 01-26-2006, 09:30 PM
adictionbass's Avatar
Default Re: lifted hood??? (midwesta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midwesta &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt do ****,
its been proven.</TD></TR></TABLE>
have this proof? im interested
Old 01-26-2006, 09:42 PM
TorganFM.'s Avatar
Default Re: lifted hood??? (adictionbass)
It's cowl induction. Air doesn't come out of the back of the hood, it's sucked in.
Old 01-26-2006, 09:45 PM
Default Re: lifted hood??? (DanW)
that i know. but u cant say it doesnt keep the bay cooler
ABK
ABK's Avatar
oh yeah, you know on what they used that **** on first?
Fucken old chrysler police cars. They had issues with overheating. Guess what? Cheap solution. raise the rear of the hood up.
Yeah it doesn't do ****. Proven by who???
Old 01-26-2006, 11:00 PM
Voyage34's Avatar
works or not, its ugly as all hell
Old 01-26-2006, 11:01 PM
tsdenny's Avatar
Default Re: lifted hood??? (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">works or not, its ugly as all hell</TD></TR></TABLE>
i would have to agree
Old 01-26-2006, 11:05 PM
xEnderx's Avatar
Default Re: lifted hood??? (void_accord)
Alot of guys with ITB's do this to increase air flow under the hood. Apparently it helps with induction into the TB's when you have them facing towards the firewall. If you have a normal air induction system it is in the same category as Alteeza's and fart cannons.
Old 01-26-2006, 11:43 PM
BlueIntegraBoy's Avatar
I believe it has to do with hood clearance against the valve cover.
Old 01-27-2006, 12:35 AM
Circuit Star-29's Avatar
Default Re: lifted hood??? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Alot of guys with ITB's do this to increase air flow under the hood. Apparently it helps with induction into the TB's when you have them facing towards the firewall. If you have a normal air induction system it is in the same category as Alteeza's and fart cannons.</TD></TR></TABLE>
Thats the proper use. Anytime you have Carbs or throttle bodies this can be useful. however, its really not that effective. Routing tubing from a vent in the fender are works best because of the pressure difference. Either way though.
This was idea was made hugely popular by the AE86 crowd in the early 90's.
Old 01-27-2006, 03:48 AM
Vero's Avatar
Doesnt do anything if you arn't moving.
It does work if you are. My buddies integra would run way to hot in the bay until he propped it up up. He only did it about half an inch or so, but it definatly helps.
There was a kid on here with a SOHC Turbo pushing about 300 whp who was using about 2" spacers. He needed them not only for clearance on the manifold, but he said it drastically helped with engine bay heat.
I'd like to see the charts prooving them wrong.
Old 01-27-2006, 04:14 AM
old man neri's Avatar
Search, covered to death
https://honda-tech.com/zerothread?id=1473698
https://honda-tech.com/zerothread?id=1415891
https://honda-tech.com/zerothread?id=1435291
Cheers.
Old 01-27-2006, 05:12 AM
ek_99_SiR's Avatar
Default Re: lifted hood??? (old man neri)
unless u have itbs dont do it.. its ugly
Old 01-27-2006, 05:29 AM
Slow EJ8's Avatar
Im with this guy.
Old 01-27-2006, 05:39 AM
hotimportcrx's Avatar
idk... my crx overheating problems on my b16 turbo improved alot after this
Old 01-27-2006, 05:41 AM
Royal_C!ty's Avatar
i like it
Old 01-27-2006, 05:42 AM
Vero's Avatar
Default Re: lifted hood??? (ek_99_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR &raquo;</TD></TR><TR><TD CLASS="quote">unless u have itbs dont do it.. its ugly</TD></TR></TABLE>
serves a lot more purposes than just ITBs.
I agree though, It does look tacky if your doing it without purpose. I can accept it for a fully built n/a or turbo car, but not on your stock d15b7; even if it is a power machine.
Old 01-27-2006, 07:01 AM
ek_99_SiR's Avatar
Default Re: lifted hood??? (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero &raquo;</TD></TR><TR><TD CLASS="quote">
I agree though, It does look tacky if your doing it without purpose. I can accept it for a fully built n/a or turbo car, but not on your stock d15b7; even if it is a power machine.</TD></TR></TABLE>may serve more purposes...but unless you gain hp...its worthless
Old 01-27-2006, 07:07 AM
fwdtamiya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR &raquo;</TD></TR><TR><TD CLASS="quote">may serve more purposes...but unless you gain hp...its worthless</TD></TR></TABLE>
Did you miss the part about a cheap fix for people overheating?
Old 01-27-2006, 07:12 AM
ek_99_SiR's Avatar
Default Re: lifted hood??? (fwdtamiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwdtamiya &raquo;</TD></TR><TR><TD CLASS="quote">
Did you miss the part about a cheap fix for people overheating?</TD></TR></TABLE>must have... i ussally like to fix the problem...the right way
Old 01-27-2006, 07:18 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR &raquo;</TD></TR><TR><TD CLASS="quote">must have... i ussally like to fix the problem...the right way </TD></TR></TABLE>
Lets see.... 300dollar radiator.... and another 100 in fans.... or 1buck in bolts/spacers... tough one...
I did this on my turbo beater to relieve some of the underhood heat. It also by a side product allowed me to cram a large wastegate onto the top of an HF manifold and allow it to barely clear the hood . Its ugly... but I don't care... its functional.
Old 01-27-2006, 07:50 AM
ek_99_SiR's Avatar
Default Re: lifted hood??? (splitime)
ah u gotta point but i like my body lines to match up
Quick Reply: lifted hood???
