| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
well its a b18b turbo in an eg.. it revs up and downallll day.. replaced teh iacv still reving up and down.. what else can it be? not a vacuum leak. thanks.
#2 |
i had this problem in my car for over a year it can be anything from
low coolant map sensor blown head gasket iacv fast idle valve try unplugging the tps sensor and adjusting the idler screw or the screw under the throttle body that will also adjust the idle |
#3 |
look for a vacuum leak...maybe a vac hose with a leak?
WE SELL Benson Machine Sleeved blocks & cranks SuperTech SS Valves, Dual Springs, Ti Retainers CP Pistons & rings ACL Bearings Pauter - Eagle - Manley Rods DriveShaftShop Axles ATI Dampners BDL/STR Products PWR Radiators & Intercoolers Quaife Dif Head porting by PortFlow now available Custom built race and street engines..K, B, H, F, D cores in stock Have a Question?..Call 714.688.0222 (shop) [url="http://www.laskeyracing.com"]http://www.laskeyracing.com[/url] |
#4 |
Try the FIT valve
92 civic build in teh works 07 Suzuki DRZ400SM 90 CRX HF LS-T 11.67@121 http://images.honda-tech.com/set1/smile/emthup.gif SOLD http://images.honda-tech.com/set1//smile/emcrook.gif |
#5 |
Take off the upper IC pipe and cover up one of the two hole inside the throttle body and see if the surging stops. If it does then it is the fast Idle valve.
9.36@159sfwd 9.00@167mph Exedy-Full Race-Exospeed-Hondata- Turbos Direct-Arias pistons |
#6 |
It could also be your TPS. Check engine light?
#7 |
if its not a vacuum leak , have you checked the tps? ......or the iacv?
vouches:freezyfreeky/rydaddy/unknown_member/JDrock86/maRcus of EF squaD/ nostreble/punoy69/imjac1/xamraci/stripped honda/sparco562/five liter eater/JiZzEr/hondafever369/oOoEG6oOo/mtkhalid/jawsiiv/DeviousCTR/delsol8017/Michaelsonaim |
#8 |
nope no check engine light
whats weird is that i had this problem before.. and then it went away completely then after i put in seafoam it came back and never went away.. changed teh iacv yesterday still happening umm messed w/ the thing under teh t/b oopen the two screws put it back ntohing.. was low on coolant. but taking out the intake pipe.. i'd have to do soomuch work what else can it be? |
#9 |
did you unplug the tps plug and adjust the idle?
also when you are changing sensors make sure to reset the ecu whats sea foam? |
#10 |
sea foam is something to clean out ur internals. i dunno made my car worst if u ask me
#11 | |
http://www.honda-tech.com/zerothread?id=1059690
[B] I <FONT COLOR="red">♥</FONT> my Honda[/B] 1992 EH3 - stock motor w/ 286k [b]R.I.P damn people who dont have insurance and total your car!![/b] [B]vouches[/B] in bio [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img] <FONT SIZE="1"><FONT COLOR="d60000">[b]ROLL TIDE!!</FONT></FONT>[/b] |
#12 |
Did it do this before you went turbo?
Its pretty much got to be a vacuum leak dude. It almost ALWAYS is. |
#13 |
look under your intake manifold there are a bunch of plastic nipples for vacum that always break off
Snyder Racing Heads If you need Head work as far as port,valve jobs ect.. surfacing, sleeving,boring,hone,full engine assembly blueprinting Contact me we use state of art machines that you will find in all CUP shops Lemon_ice_4u@hotmail.com |
#14 |
nope was alraedy turbo'd
ill try to find it soon gets annoying after some time
#15 |
i bet it's a vacuum leak....if not use a voltmeter to check ur TPS sensor...i don't think it would be ur map did you change any ECU stuff lately.....what EMS u runnin???
http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif props to FULL-RACE, ERL, HEADGAMES, LOCASH, CHRONIC CAR AUDIO http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthdown.gif FAWK PROSTREETONLINE http://images.honda-tech.com/set1/smile/emthdown.gif http://images.honda-tech.com/set1/smile/emthup.gif Lucid Design's http://images.honda-tech.com/set1/smile/emthup.gif Shift Fast.net http://images.honda-tech.com/set1/smile/emthup.gif Chronic Car Audio http://images.honda-tech.com/set1/smile/emthup.gif |
#16 |
After using seafoam you should reset your computer cuz it gets tricked into thinking its running rich and takes a while to relearn, also i have heard of seafoam ruining o2 sensors and have had a bad o2 make my n\a gsr motor rev like that till I changed it. FYI: to reset computer remove 7.5 backup fuse in engine compartment for 10 sec or neg battery terminal
East Coast Chopstix (Leader) eastcoastchopstix.com [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] |
#17 |
1995 Acura Integra |
Take off the pipe going into your throttle body after its warmed up, put your finger over the hole inside on the bottom of the tb. If it's pulling suction then your fast idle thermo valve is bad.
#18 |
might alos be air pockets in your coolant
#19 |
throttle body gasket? mine did the same thing. spray carb cleaner around it..if it wants to die out then thats it..
#20 |
mine also did the same thing when i blew out my throttle body gasket
*1992 Honda Civic Hatch - JDM B16A - SC61 Turbo -Dyno'd 296whp @ 10psi (street tuned on uberdata by me) *2007 Honda CBR 1000rr - 9.59 @ 141mph |
#21 |
1992 Honda Civic |
mine also had this problem recently, i knew what it was never really fixed it. well till sunday. it was the FIT, but there are soo many different things that would make it do it. if no vac leaks. can only be the TB gasket or the FIT
#22 |
TPS calibration.
Previous cars 94 Red EG9 b16a-94 Black Impreza WRX -95 Black EG9- 97 Black ST205 GT4 - 96 CW ITR- 02 Black AP1 S2000-99 CW ITR Current 00 black ITR 81.5mm B18c6-built t3/t4E BOOST |
#23 |
geeeeez my car has been revving up at down from 1k to 3k when its sposed to be idling and theres tons of crap i have to check
oh well...i love working on my car
| Tags |
| 1361, 2002, 2004, acura, automatic, car, check, civic, crv, engine, honda, idles, idling, integra, keeping, revs, s2000 |
