#1 | |||||
#2 |
WE WANT PICS!
.I like your explanation with what a leakdown is, this will help out plenty of people. |
#3 |
Sorry i dont know how to put the pic in here, i only have it on paper, hence the typing!!
But hey i shoulda known, some else got it. they posted this link in another thread as i was typing mine. Sheesh!!! http://www.xs11.com/tips/misc/misc3.shtml This link courtesy of Snail. Thanks buddy Modified by JustG at 9:36 PM 1/18/2006 |
#4 |
Very nicely done. That link did a good job on the picture.
93 B18C-<FONT COLOR="red">T</FONT> DX coupe <FONT SIZE="2"><FONT COLOR="red">Janer Performance</FONT></FONT> <FONT COLOR="blue">-Engine Building-</FONT> -Turbo Install- <FONT COLOR="green">-General Mechanic-</FONT> -We Sell BDL http://images.honda-tech.com/set1/smile/emthup.gif - PM for good deals. http://images.honda-tech.com/set1/smile/emthup.gif Vouch Custom Clutch Lines RIP Earl Laskey 12.1.06 You will be missed! http://images.honda-tech.com/set1/smile/emsad.gif |
#5 |
Thanks justg
#6 |
with 17 posts
good stuff add it to the faq!!
#7 |
good info
#8 |
Now I have to just figure out how to use it
![]() Great info
"So whats the deal with politics? I don't get it...Am I right people? ![]() ![]() "
#9 |
haha same here ^^^
Good stuff though.
#10 | |
quote-with 17 posts good stuff add it to the faq!!
Ya i know i only have 17 posts but that doesnt mean i havent been here long. I usually just read and research, i will only put in my 2 cents if im sure. none of this "well it might be this or it might be that..." Thats what everyone should do on their own, thats trouble shooting .then ask if your stumped. But hey we're all here to help each other one way or another right! Quote:
Basically, you measuer the amount of air you put in the cylinder, from your air compressor, like 100 psi. Since the cylinder is at tdc on compression stroke, it should be sealed tight. so now, when you put 100psi in and wait for 5secs, any air that escapes is the percent of leakdown you have. 100psi in---wait 5 secs---80psi left=20% leak down if you leave it long enough, every cylinder will leak to an extent. hence 5SECS if you realize you have high leakdown you can apply the air again and listen to where it is escaping to determine the repair you have to do. Hope that sums it up a lil better and quicker!
#11 |
I'm a Jackass
Very nice. Much props for the info!
#12 |
Great Info! this will help me out sometime
n/a d series is like running a 5k marathon with one leg. '96 Midori Green CX Vouches: nw. dave, Ej8, 4gen, TurboSmart, oxSLEEPERxo, flat-blk-HB, 1sckcvc, blackccoup, dubdeuce, yoej8, Bone Stock, civek, krazie4vtec, fullboostin, JDM_EM1, PYITR821, Sille98, civic00_dude, SikofFalln, dornon13, TurboEM1, ekay. jay, Fallen86, HI-CHEW KID, urname7698, ham, IWANTAHB, boostd92, MinorObsession |
#13 |
bump!
#14 |
*RIP: TT Truong* |
#15 |
Where can you buy the fitting that goes into the spark plug hole? You said you had one from a previous leak down tester.
edit: read the other thread. The author used a drilled out spark plug. |
#16 | |
#17 | |
BTW thanks for the props thisisntjared! |
#18 | |
double post ownz me.........
doublej http://images.honda-tech.com/set1/smile/emsmile.gif RIP Earl |
#19 | |
Bringing this back. Very cool post. I just made my own tester tonight in my shop at work using this tutorial and thought I would post some picts so that we could have a description and pictures in the same thread.
Pictures of separate pieces..... ![]() The pieces are (from right to left, which is also the direction of flow) listed below... 1) 1/4npt male to mail quick disc 2) 1/4npt female to female ball valve (Decided to use this instead of damper valve, also more correctly called an orifice. . I will just ease the pressure in by opening this valve slowly) 3) 1/4npt male to male check valve (Not really needed but I liked it. It would be needed if the reg valve did not have an internal check) 4) generic regulator (250psi max inlet, 100psi max outlet) w/internal check valve and 0-100psi gauge. The gauge measures regulated pressure. 5) 1/4npt male to female quick disc The pieces will differ from tester to tester and I gave reasons why I used what I did. Also, the flow on the regulator I had went the opposite way of the one shown in the previous diagram that is why mine looks as if it were backwards. All put together..... ![]() And tested for leaks.... ![]() Hope this helps someone else, cause it helped me out. I will just use the hose from the compression tester that I have.
#20 |
yay, for piece list + pics
this will help me lots
( )( ) ( 0'o) WAT (/--) |
#21 |
Wow.
Looks like it's just a gauge with a spark plug threaded end and a valve to keep back-feeding or added air from the compressor. Is there anything else I'm missing? Very cool, btw. I feel like I have to leakdown test my car now .
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E |
#22 |
Now this is what Honda-tech is all about. Good stuff here guys
#23 | ||
-The comp tester is just a gauge that you hook up to where the spark plug was. -The leakdown tester is a regulator so that you can determine how much air pressure you have put into the cylinder and after a set amount of time you can calculate how much air you have lost. You need a check valve somewhere in the system to accomplish this. Otherwise, the air would just be pushed back out of where it was put in at instead of where the potential problem might be. I.E. the hg, valveseals or piston rings.
#24 | |
This is great info. In fact, compression testers are not that great of a tool for really finding how good your engine is sealed up. Leakdown tests on the otehr hand are GREAT and tell you a LOT more about the condition of your engine.
Everyone one needs to know how to do this test. Also, I didn't see it mentioned; When you do the test make sure your car is warm. If its cold the metal may have not expanded and you may get a higher leakdown that what you actually have... So this test doesn't really work on engines that have been out of cars for awhile. (I tested my b18 before I bought it and it was at 60%. I bought it anyways and when I put it in my car and drove it for about about a week and tested it again and it tested at 5%! pretty damn good.)
#25 |
Whats this? Something actually useful on HT?
-Ryan I hate my car. |
| Bookmarks |
| Tags |
| build, leak, leakdown, make, making, stroke, tester |
