> Honda Accord (1990 - 2002)
Old 01-13-2006, 05:20 AM   #1
ezwind72
ezwind72's Avatar
Default 1995 Honda Accord Speedometer problem.
My '95 Accord appears to have an intermittent issue with the speedometer. It'll be working and then suddenly it'll just drop to 19mph and stay there. Does anyone know what this could be?? Cable? Sensor? I've only had the car for a short while and this is the first Honda I've ever driven so I'm not quite sure where to start. Thanks!
ezwind72 is offline   Reply With Quote
Old 01-13-2006, 06:24 AM   #2
P_Adams
P_Adams's Avatar
Default Re: 1995 Honda Accord Speedometer problem. (ezwind72)
If you had the "Service Engine" lamp coming on as well, I'd suspect the VSS (Vehicle Speed Sensor). Without any additional symptoms, it points more directly at the Speedometer itself.
Does it do it after any particular event; ie: hit a bump, stop suddenly. ETC
P
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline   Reply With Quote
Old 01-13-2006, 07:01 AM   #3
ezwind72
ezwind72's Avatar
Default Re: 1995 Honda Accord Speedometer problem. (P_Adams)
The sevice Engine LED is not on. It seems to be random. I'll just be driving along and then it suddenly stops working, no rhyme or reason to it.
Old 01-13-2006, 12:58 PM   #4
aws140
aws140's Avatar
i had this exactly same problem except after a while it became WAY worse. one minute itd register 0 and then the next id be going around 180. i bought a new speed sensor and it didnt fix it. i ended up having to install a new speedometer. its not much trouble, get a haynes manual and its a breeze. same goes for the speed sensor. if you end up finding out it sthe speed sensor i have one ill sale you for cheap.
aws140 is offline   Reply With Quote
Old 01-13-2006, 01:34 PM   #5
ezwind72
ezwind72's Avatar
Default Re: (aws140)
Cool! Thanks very much! I will definitely take a look at the speedometer itself first. If it ends up being the sensor I will let you know. Thanks everyone for the help!
Old 01-13-2006, 08:13 PM   #6
P_Adams
P_Adams's Avatar
Default Re: (ezwind72)
You're correct to suspect the Cluster/connection first.
When the VSS decides to take a powder, it will set a "Service Engine" Lamp, a DTC will be set and available to scan and it can effect no only the engine performance but the Transmission as well.
You're seeing none of that
P
Old 09-08-2010, 01:31 PM   #7
syncity6
Icon6 Re: 1995 Honda Accord Speedometer problem.
I have an 95 accord ex and my speedometer goes up and down then just stops after i drive for a while.It allso stalls when i peass the gas,the check engine light goes on and off . I can fix most things on the car myself but i cant find out whats wrong i have taken the car to a few shops but they seem lost themselves if any one has any idea what this is i would love to know thanks.
syncity6 is offline   Reply With Quote
Old 09-08-2010, 03:04 PM   #8
htekken
htekken's Avatar
a lot of ppl have been having this problem lately it seems. you havent considered replacing the VSS? its only a $15 shipped part, new aftermarket on ebay. from my experience, my CEL was very sporadic and random. it would not turn on every single time. just whenever it felt like it.
94EXG77MCD7WWTAEMCAIDIYSS2KHIDDZD1
htekken is offline   Reply With Quote
Old 09-08-2010, 03:13 PM   #9
Sorcerer
Does anyone know if the sensor gear (under the VSS) will spin with the front wheels off the ground and someone spinning the tire?
I'm trying to figure out why my new (JDM used) VSS is cutting in and out
Sorcerer is offline   Reply With Quote
Old 09-09-2010, 10:12 AM   #10
rastarythm
P
W/ no disrespect intended, how true is this? I've been having the same speedometer problem and I was told that it was the VSS sensor in my tranny that was causing this. I haven't had the car too long as well. When driving the car kept hesitating until it finally decided to start stalling. After being told by some mechanics that this (the hesitation) was normal for Vtecs until I took it to a tranny shop (strictly trans) & they told me it was the 4th gear. B/c its a automatic (94 Accord Vtec 2.2L) nobody wants to rebuild it (my tranny people told me $2400). I just bought one from everdrive.com for $1000 w/ a 3yr warranty. That's the best that I could do. I'll have it installed for $250.
rastarythm is offline   Reply With Quote
Old 09-09-2010, 10:22 AM   #11
chikin pickle
The VSS is geared to the transmission output shaft. If the output shaft is spinning, the gear will spin regardless of whether or not the wheels happen to be on the ground.
chikin pickle is offline   Reply With Quote
1995, 20, 95, accord, honda, install, installation, intermittent, manual, problems, sensor, speed, speedometer, symptom, working
