#1 | |||||
"Spooning Leads to Forking" |
#2 |
sweet
nicely done
92 db1-205/135 99 ej8-daily grindin!AIM: ohsnapzafingcu Vouches: h22-hatch,Boostd92 16x7 te37's for sale! ---> http://www.hondamarketplace.com/show....php?t=2540920 |
#3 |
Nice write up.
*saved to notepad*
1992 (DA) Integra LS Stolen *07/08/06* Now if we don't go into the past and find out how we got this way, we will think that we were always this way. And if you think that you were always in the condition that you're in right now, it's impossible for you to have too much confidence in yourself, you become worthless, almost nothing-Malcolm X DA Squad Member #346 http://images.honda-tech.com/set1/smile/emwink.gif |
#4 |
saved to my computer!
~92 DA semi-built b18c1-T~ sold ~08 Mazdaspeed3 2.3-T~ |
#5 |
Very nice write.. But I can't seem to find the fuse on my block head?
#6 | |
whyd u even take the valve cover off?
(203) http://images.honda-tech.com/set1/smile/embeer.gif 97 GSR Life ended early by Bambi 98 S/Ced VR GTI... The Whistles go wooo wooo Quote:
#7 | ||||
why?
#8 | |
#9 | |
Just a personally preference for me.
#10 |
nice write up..
Old Honda-Tech forum > New Honda-Tech |
#11 |
#12 | ||
Its A LOT EASIER with the valve cover off so you can look at the markings on the cam gears to make sure you are at TDC. You turn the crank pulley.. which turns the belt... which turns the gears and you match up the markings to be at TDC for EACH cylinder when doing the Leak Down test. Good writeup btw
I'd hit it.............. WITH MY CAR!!! http://images.honda-tech.com/set1/smile/emsmilep.gif |
#13 |
i must be the only one who just puts a long 3/8" extension in the spark plug hole and rotates the crank till it i watch it hit TDC....i've been doin that for years...easier than takin off a VC or even takin ur dizzy apart..just my .02
got rid of the si and went old skool! |
| Bookmarks |
| Tags |
| check, compression, cylinder, engine, honda, kit, leak, leakdown, piston, read, ring, test, tester, testing, valve |
