1990 Honda Accord Shakes like crazy at idle..
Old 01-06-2006, 01:25 PM
standbackimapro's Avatar
Default 1990 Honda Accord Shakes like crazy at idle..
2 Things, my car shakes pretty intenstly when its at idle, i noticed that it pretty much stops when i put it in neutral, but if its in gear it shakes alot
Spark Plugs, wires, cap/rotor, all new,
The sparkplug tube seals are leaking so i have oil on my plugs.. could that be it?
someone suggested i take off the throttle body and adjust it and clean it
Old 01-06-2006, 01:45 PM
Honda-Master's Avatar
Default Re: 1990 Honda Accord Shakes like crazy at idle.. (standbackimapro)
broken motor mounts,,,,,,,,, chk the rear and frt
Old 01-06-2006, 03:23 PM
P_Adams's Avatar
chk my sig. Humorous but true.
It gets so bad, the steering wheel jumps 1/2" when it's in gear
P
Old 01-12-2006, 08:07 PM
jepoy3227's Avatar
i have the same problem, i have a 91 accord lx. Were you able to solve the problem? I am about to her for a major tune up. What are the parts that i need to replace? It has 165k mileage. Can you provide a list for the complete list when performing a major tune up? Thanks
Old 01-12-2006, 08:12 PM
92ehatch's Avatar
Default Re: 1990 Honda Accord Shakes like crazy at idle.. (jepoy3227)
look at that rear mount, at first it looks ok, but if you look closer you see it bouncin like it had hydrolics on it. mine is same way. 40 dollar part at advance, im gonna change mine first day off work
Old 01-12-2006, 08:17 PM
P_Adams's Avatar
Major Tune-up;
Part: / Suggested Manufacturer
Spark Plugs (4) (NGK)
Spark plug Wire Set (1) (Honda)
Distributor Cap (Honda)
Distributor Rotor (Honda)
Pcv Valve
Air Filter
Fuel Filter
Can / Bottle Injector Cleaner
bad Vibration?: My wifes '89 Accord Auto needed the Rear Transmission Mount
P
Trunkzdbz
05-17-2014 12:21 AM
MKIRSCH02
02-02-2013 01:34 AM
multitec
02-02-2009 05:21 PM
rfossett
03-09-2007 04:26 PM
fever502
01-09-2006 05:49 PM
Quick Reply: 1990 Honda Accord Shakes like crazy at idle..
