Old 01-01-2006, 03:22 PM   #1
Project_EK
Project_EK's Avatar
Default How often do you rotate ur tires???
What up,
I just got some new rubber so i wanna try n keep em as fresh as possible. my car is lowered about 3 inchs BTW! i was thinking like every 3 weeks?!?!
lemme know
EK hatch - 10.95@136 *sold
Getting the itch again!!
!!Dedication is key!!
Project_EK is offline   Reply With Quote
Old 01-01-2006, 03:28 PM   #2
EGDC2CIVIC
EGDC2CIVIC's Avatar
Default Re: How often do you rotate ur tires??? (EKhatch219)
i rotate mine every other oil change, so 5500- 6000 miles
Originally Posted by TeamDoubleClutch
Now, back to the head gasket issue. The black si is faster then the red and blue si's. This is because the black si's have a 2 layer head gasket. The red and blue si's have a 3layer head gasket. Does any1 know if this could be the case
Ok, for all you guys that think I am fool of ****. Go find a black si, remove the head and count the layer on the head gasket. Now go to a red or blue si and do the same thang. I have pulled so many heads off of si's.
EGDC2CIVIC is offline   Reply With Quote
Old 01-01-2006, 03:37 PM   #3
JunY
JunY's Avatar
Send a message via AIM to JunY
I do mine every Oil change. Click the image to open in full size.
JunY is offline   Reply With Quote
Old 01-01-2006, 03:47 PM   #4
dohcVTECeg2
dohcVTECeg2's Avatar
nic3guyeddie
Send a message via AIM to dohcVTECeg2
Default Re: How often do you rotate ur tires??? (JunY)
i usually do it everey oil change as well. i like doing all that **** at once while im working on my car
dohcVTECeg2 is offline   Reply With Quote
Old 01-01-2006, 03:48 PM   #5
Draggin99Si
Draggin99Si's Avatar
Default Re: How often do you rotate ur tires??? (dohcVTECeg2)
every 6k miles
1999 Honda Civic Si RESTOMOD
99% ORIGINAL and bone stock!
Draggin99Si is offline   Reply With Quote
Old 01-01-2006, 03:49 PM   #6
95sivee
95sivee's Avatar
Default Re: How often do you rotate ur tires??? (Draggin99Si)
do you have camber kit on your car?
95sivee is offline   Reply With Quote
Old 01-01-2006, 03:51 PM   #7
The_Head
2014 RAM 2500
My Garage
The_Head's Avatar
Default Re: How often do you rotate ur tires??? (EGDC2CIVIC)
+1
2004 Honda Interceptor
The_Head is offline   Reply With Quote
Old 01-01-2006, 04:14 PM   #8
Royal_C!ty
Royal_C!ty's Avatar
iTrader Rating: (3)
Default Re: How often do you rotate ur tires??? (The_Head)
I dunno i guess call me a lazy, i rotate mine every other oil change lol
Checkout My Blog for coverage of the Northwest Honda/Acura scene
www.royalgarage.wordpress.com
Royal_C!ty is offline   Reply With Quote
Old 01-01-2006, 04:15 PM   #9
wushubrian
wushubrian's Avatar
Default Re: How often do you rotate ur tires??? (eg8kid)
I do mine twice a year.
wushubrian is offline   Reply With Quote
Old 01-01-2006, 05:21 PM   #10
civic_in_LA
civic_in_LA's Avatar
I never rotate my tires period. I just know that I replace my front tires more frequently than the back ones.
There really is no need to rotate tires. It just ensures that at the end you have to buy the four tires at one time.
I dont mind replacing two sets of front tires for every set of back tires.
civic_in_LA is offline   Reply With Quote
Old 01-01-2006, 05:38 PM   #11
EJ4door
EJ4door's Avatar
Default Re: (civic_in_LA)
I do the same thing lol
Nobody dies a virgin.... eventually life screw us all
Halo 2 GAME TAG: <U>K1LLER82</U>
EJ4door is offline   Reply With Quote
Old 01-01-2006, 06:25 PM   #12
old man neri
old man neri's Avatar
This is only partly true. You are also suppose to rotate your tires left/right (unless they are directional) this compensates for any slight differences from one side to the next. The rear ones go straight to the front and the front ones go to the diagonally opposite corner.
If you have dropped your car 3" and don't have a camber kit rotating your tires will do nothing. It will wear down the inside of you tires regardless on what corner of your car they are on.
old man neri is offline   Reply With Quote
Old 01-01-2006, 06:28 PM   #13
EX-T
1999 Honda Civic
EX-T's Avatar
@dgrantg inebriatedGDubb GDubb615
If you don't have a camber kit, I'd suggest getting one...it was one of my best investments towards my car...besides my cam... Click the image to open in full size.
Balls out
99 FBP EM1 built and boost'd D16Y8
06 IP G35 Coupe I/TP/E, Tein S Tech Springs
EX-T is offline   Reply With Quote
Old 01-01-2006, 06:29 PM   #14
wushubrian
wushubrian's Avatar
Default Re: (old man neri)
so true... please buy a camber kit cuz your going to spend more on tires anyways...
Old 01-01-2006, 06:54 PM   #15
skrewdriver88
Send a message via AIM to skrewdriver88
Default Re: (wushubrian)
Every other oil change
skrewdriver88 is offline   Reply With Quote
Old 01-01-2006, 07:11 PM   #16
JDMlyfestyle
JDMlyfestyle's Avatar
Send a message via AIM to JDMlyfestyle
i jsut keep the back ones and burn off the front ones.. once the front ones are gone and i get new fronts and put em on the back Click the image to open in full size.
JDMlyfestyle is offline   Reply With Quote
Old 01-01-2006, 07:13 PM   #17
Ricey McRicerton
Former Moderator
Ricey McRicerton's Avatar
Default Re: (JDMlyfestyle)
Haha, you guys are either on to something, or lazy as ****.
I do mine (front to back because they're directional) every 6-8k.
13 STi
04 4Runner
93 VFR750F
06 VFR800
Ricey McRicerton is offline   Reply With Quote
Old 01-01-2006, 07:27 PM   #18
wushubrian
wushubrian's Avatar
It all depends on how you want to drive and change your tires....
Old 01-01-2006, 07:29 PM   #19
cambopheonix56
cambopheonix56's Avatar
Default Re: How often do you rotate ur tires??? (wushubrian)
6k
Vouches: civic_speed99, accordinglyevil, 95greenteg, 92integra_gs, whiteef6, travis420
cambopheonix56 is offline   Reply With Quote
Old 01-01-2006, 07:30 PM   #20
JDMlyfestyle
Default Re: (Ricey McRicerton)
well i got Summer and winter tires..
and i barely put 8k mileson my car a year
Old 01-01-2006, 07:57 PM   #21
robert_v
robert_v's Avatar
i never rotate mine either. its been like 1 year and 6-8 months since i bought new tires and they are still in great condition (no camber kits either)
robert_v is offline   Reply With Quote
Old 01-04-2006, 10:04 PM   #22
civic_in_LA
Yeah really, there is no need to rotate tires.
I had my car since it was new, in 97, and never did I rotate tires. The whole tire rotation thing is a scam and big conspiracy.
Im running on stock tires, they are cheap as **** and not rotating them has no negative impact on them. Like I said, only the front tires get replaced first. Then keep an eye out and eventually the rear ones will go.
Old 01-04-2006, 10:12 PM   #23
anony95ex
anony95ex's Avatar
Send a message via AIM to anony95ex
Generally, in FWD (and some FWD-based AWD vehicles), rotate them every oil change. FWD really eats up the front tires, and rotating them will actually increase the time between tire purchases. Sure, you'll probably have to buy all 4 at one time, but why buy an extra pair of fronts when they could last until you need all 4 if they're rotated? With RWD vehicles (and most RWD-based 4WD trucks), you can rotate every other oil change (or even less frequently) and be fine. FWD is, IMO, one of the worst design traits to ever hit cars...unfortunately it's so common that finding a RWD car is actually a PITA. It's great that several manufacturers (most notably Chrysler) are going back to a basic RWD layout...damn I hate FWD, I drive it because there's no other choice.
That's with older bias-ply tires. Radial tires, directional or not, are supposed to be rotated front-to-back, not crossed. It can cause uneven wear and slipped belts inside the tire, I've seen that happen too many times when people cross-rotate radial tires.
1987 Jeep Cherokee
2000 Mustang GT
1997 Pontiac Grand Prix GT
1995 Honda Civic EX &lt;--- SOLD!
anony95ex is offline   Reply With Quote
Old 01-04-2006, 10:21 PM   #24
EK k kay
EK k kay's Avatar
Default Re: (anony95ex)
When you guys say "rotate tires" do you mean actually removing the tire and remounting it either in the opposite direction (non-directional tires) or onto another tire on the other side of the car (directional tires)? Or do you mean swapping the front wheels with the rear wheels?
EK k kay is offline   Reply With Quote
Old 01-04-2006, 10:24 PM   #25
anony95ex
anony95ex's Avatar
Default Re: (EK k kay)
Just moving the wheels around on the car (usually front-to-back and vise-versa), it has nothing to do with removing the rubber tire from the metal wheel. If you walk into a dealership and ask for a tire rotation, this is what they're gonna do.
1987 Jeep Cherokee
2000 Mustang GT
2004, 2006, accord, car, cross, directional, honda, radial, recommend, rotate, rotating, rotation, si, tire, tires, ur
