Indicator lights on Auto Shift column (P, R, N, D, 1, 2)
Old 12-31-2005, 09:25 AM
uschonda's Avatar
Default Indicator lights on Auto Shift column (P, R, N, D, 1, 2)
98 accord lx sedan, automatic. Noticed that at night, on the automatic shift column indicator, it doesn't light up.
Is it suppose to? I've never paid attention until I realized it was pretty dark at night in the center console area.
If it is, i'm sure you can replace it but the center console and shift column looks pretty tough to dismantle just to change a bulb.
any help would be great. thanks
Old 12-31-2005, 09:41 AM
P_Adams's Avatar
Default Re: Indicator lights on Auto Shift column (uschonda)
If you're speaking of the shift quadrant at the control lever, Yes- there's a bulb specifically for illuminating it.
On the 5th gen Accords it requires pulling the rear console and front console upper trim to gain access. About 6 screws if I remember correctly.
The 6th Generation Accord appears easier
http://www.hondaautomotivepart...82%29
http://www.hondaautomotivepart...NSOLE
But it still appears you have to take the top trim plate (W/Cupholder) out to gain access.
P
Edited for clarity & illustrations
Modified by P_Adams at 9:09 AM 1/1/2006
Old 12-31-2005, 09:37 PM
Slats's Avatar
Default Re: Indicator lights on Auto Shift column (P_Adams)
Should be able to carefully pry off the ring around the shift gate to access the light. I would replace it with LEDs. I've done that and it makes it much brighter...check out http://www.superbrightleds.com
Old 01-01-2006, 06:24 AM
YeuEmMaiMai's Avatar
Default Re: Indicator lights on Auto Shift column (Slats)
Unless you want to take your car apart I would just used the indicator on the dash...........
alpha honda fan
04-29-2013 04:20 AM
sixtodc2
08-22-2006 03:38 PM
Monkey Z.
02-07-2005 03:25 PM
ernestoG
08-25-2004 06:03 PM
Quick Reply: Indicator lights on Auto Shift column (P, R, N, D, 1, 2)
