Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 12-25-2005, 07:38 PM   #1
george34
george34's Avatar
Default how do I break lock tight?????
I have a motor mount screw on my r/c car that is held in by lock tight. I have already stripped the screw very bad. The only thing that I can think of that is holding this one screw in so tightly is becauseof the lock tight. What can i do to make the lock tight break free, so I can get the screw out???? Thanks.
CRX <U>"IT'S A ROCKET"</U>
george34 is offline   Reply With Quote
Old 12-25-2005, 07:47 PM   #2
Skunk.Werks
Skunk.Werks's Avatar
iTrader Rating: (2)
Send a message via AIM to Skunk.Werks
Default Re: how do I break lock tight????? (george34)
torch it up, slot it, and work on it with a flat head or..
drill it out
Skunk.Werks is offline   Reply With Quote
Old 12-25-2005, 08:20 PM   #3
george34
george34's Avatar
Default Re: how do I break lock tight????? (Skunk.Werkz)
I don't want to drill it out b/c I need to be able to put a new screw in.What would I slot it with?
Old 12-25-2005, 08:29 PM   #4
Starrman85
Starrman85's Avatar
Send a message via AIM to Starrman85
sounds like lock tight is doing it's intended job.
06 Subaru Legacy Limited
92 Accord EX Coupe - SOLD
Starrman85 is offline   Reply With Quote
Old 12-25-2005, 08:34 PM   #5
SHystrdyGSRtdy
SHystrdyGSRtdy's Avatar
Send a message via AIM to SHystrdyGSRtdy
heat... slot it with a dremel.
http://www.honda-tech.com/zerothread?id=1588533 &lt; <FONT COLOR="red">FS: Turbo Heatshield</FONT>
SHystrdyGSRtdy is offline   Reply With Quote
Old 12-25-2005, 08:47 PM   #6
bustdesenuts
bustdesenuts's Avatar
Send a message via AIM to bustdesenuts
Blue: Can be removed with hand tools
Red: Apply heat to remove
Green: Apply heat to remove
have you tried a vise grip to get it out?
'07 G35 Sedan - Stella
'01 Prelude - Raquel *Sold*
'05 R6 - Mystiq *Sold* http://images.honda-tech.com/set1/smile/emsad.gif
bustdesenuts is offline   Reply With Quote
Old 12-25-2005, 08:56 PM   #7
Ajax
Ajax's Avatar
Default Re: (bustdesenuts)
Heat it up, use vice grips. Unless you accidently knock the top of the screw off, there is never a time when this won't work. Click the image to open in full size.
Ajax is offline   Reply With Quote
Old 12-26-2005, 04:18 AM   #8
george34
george34's Avatar
Default Re: (Ajax)
I will try a vice grip and tell you guys how it worked.
break, breaking, free, green, heat, lock, locktight, loose, remove, removing, s2000, scerw, threaded, tight, tite
