| Welcome to Honda-Tech! | ||
#1 | ||
I've got a 92 eg8 and my steering wheels squeeks pretty loudly whenever I turn left. It ONLY happens when I turn left, and it ALWAYS happens when its cold outside. In the middle of the summer I don't really notice it, so if its happening then its a lot quieter. It isn't any harder to turn than usual and I've noticed no other problems with it, but its really annoying and embarrasing if I have passengers in the car. Anyone know what this could be?
EDIT: For clarification, the sound is coming from behind the steering wheels somewhere. There is nothing wrong with the suspension/tierods or anything, and it can only be heard inside the cab. Modified by transpar_nt at 8:30 PM 12/18/2005
<FONT COLOR="#003366"></FONT> |
#2 |
RIP 1032
2006 Yamaha YZF-R6Join Date: Nov 2003
check all your boots in the suspension (axels, steering rack, etc...) also, check your steering column maybe it needs to be greased up a bit?
#3 | ||
The thing I can't figure out is why it only happens when turning left. If it needed greasing, wouldn't it make sound both ways?
#4 |
with the key all the way to the on position(this will release the steering lock)
have a friend turn the steering wheel left while you stick your head under the wheel and see where the noise is coming from. i had a loose bolt under there before, can't remember if it made any noise, but it was just loose, and I think it was somehow attached to a spring on the steering rack. that could be your problem, that spring might be compressing and decompressing when you turn left.
My Vouch Thread http://www.honda-tech.com/zerothread?id=646474 VX/CX owners: Can't get rid of that pesky code 1? http://www.honda-tech.com/zerothread?id=1513794 |
#5 |
sounds like a power steering issue, either the pump or the rack..........
| Tags |
| car, del, honda, left, power, rack, sol, sqeaks, squeakes, squeaks, squeals, squeeks, steering, steery, turn, turning, wheel |
