Manual window crank removal
Old 12-15-2005, 11:50 PM
1989CivicSi's Avatar
Default Manual window crank removal
How do you remove the window crank from the manual window doorsills? Was about to take a flathead screwdriver to it, but thought twice ...
Old 12-16-2005, 12:41 AM
Donkey85's Avatar
Default Re: Manual window crank removal (1989CivicSi)
there is a little metal clip that hides behind the window crank that pins it to the regulator. what u do is get a little pick and pull it right out and off comes the handle
Old 12-16-2005, 12:54 AM
ef92b's Avatar
yep, that will do the trick.
just look under the crank, there's a small rectangular shaped opening just enough to insert the flat tip of the screw driver. slowly pry that U-shaped clip that locks the crank/handle from the shaft.
see the pic. sorry for my poor illustration
Old 12-16-2005, 08:02 AM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Default Re: Manual window crank removal (ef92b)
click on picture to view:
Old 12-16-2005, 08:08 AM
EL Vap133's Avatar
Once you do it, you'll think it's soooo easy from then on.
Old 12-16-2005, 08:31 AM
quis23's Avatar
Default Re: Manual window crank removal (EL Vap133)
use a peice of string to pop it rigth out
Old 12-16-2005, 08:38 AM
crxtreme89h's Avatar
Default Re: Manual window crank removal (quis23)
Use one of these and keep it real
Old 12-16-2005, 12:28 PM
Default Re: Manual window crank removal (crxtreme89h)
Thanks for all the replies . I was originally gonna just pull the crank off haha, good thing I didn't .
Old 12-16-2005, 01:14 PM
88DXCRX's Avatar
You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip..
To re-install,position the clip as shown in the second picture,
Hold the handle in the postion you want it and give it a slight smack
and it will pop right on..
Old 12-16-2005, 10:03 PM
progress's Avatar
Default Re: Manual window crank removal (88DXCRX)
[QUOTE=88DXCRX]You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip QUOTE]
I was just about to suggest this! Works like a charm.
Old 04-06-2013, 09:11 AM
Margaret Ruybal's Avatar
Icon2 Re: Manual window crank removal
I was rolling up my window on driver side when it just got harder to turn and it just shattered
now I need to replace it but where do I start to remove the side panel
Btothe3rdDegree
04-19-2004 03:22 PM
okman16
26
11-09-2003 12:48 PM
Quick Reply: Manual window crank removal
