Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 12-12-2005, 07:19 PM   #1
CA6VTEC
CA6VTEC's Avatar
Send a message via AIM to CA6VTEC
Default ARP ROD BOLTS Torque Specs
<FONT COLOR="royalblue"> I just picked up some eagle rods w/ the arp rods bolts, but they didn't come w/ the torque spec sheet.. I tried going to arp, but my shitty 56k is killing me. </FONT>
(\__/)
(o.O )
CA6VTEC is offline   Reply With Quote
Old 12-12-2005, 07:32 PM   #2
onepoint6i
onepoint6i's Avatar
Default Re: ARP ROD BOLTS Torque Specs (CA6VTEC)
what bolts did they come with? more than likely 5/16" ARP 2000-3/8" bolt head?
you should invest in a Rod bolt stretch gauge, much more accurate than a torque wrench for Arp rod bolts..
onepoint6i is offline   Reply With Quote
Old 12-12-2005, 09:28 PM   #3
Sliced Beard
Sliced Beard's Avatar
Default Re: ARP ROD BOLTS Torque Specs (onepoint6i)
I suggest you measure the rod bolt stretch and set them to ARP specifications. Call up ARP and they will give you the exact specification.
I have a stretch guage that I could set your stretch for you with but I am too far away. Your best bet is to either torque them to factory +2 ft-lb or send it off to the machine shop and have them measure it to proper stretch.
-yo yo momma
Sliced Beard is offline   Reply With Quote
Old 12-12-2005, 10:17 PM   #4
budsmachine
budsmachine's Avatar
Default Re: ARP ROD BOLTS Torque Specs (DirtySol)
Do not torque to factory specs!!!!! most all eagle rods untill recently use 5/16 bolts (close to 8mm). factory b16 and b18c rods have 9mm bolts. if you torque to factory 33lbs you will over stretch the bolts possibly causing breakage. call eagle 662-796-7373, they will need to know the socket size of the head and the markings on the head(eagle8740 or eagleS2000 i think).
[url="http://budsmachine.com"]http://budsmachine.com[/url]/
budsmachine is offline   Reply With Quote
2000, 38, 9mm, arp, b18c, bolt, bolts, eagle, rod, series, spec, specifications, specs, stretch, torque, tq
