91 Accord Blower Motor
My climate control doesn't blow on my 91 Accord. For a while it would work some times and not others; seeming to randomly work and not work. Now I turn it to any setting and there is no air comming out. So I assume this is the blower motor?
I checked the fuse and it's good, is there anything else I should check or that this could possibly be?
If it is the blower motor should i get one new or would one pulled from a junk yard be a good risk?
Estimate on how much skill this would take with 1 being someone who can't put air in there own tires and 10 being a certified mechanic.
Thanks for the help!
Re: 91 Accord Blower Motor (rdiggidy)
well test for power and use the fan speed control **** to turn it on and see if your test light lights up? but these are prone to having bad blower motors! and let me tell you they kinda suck to do most people take the a/c evap out but i just take the ecu and cover out instead to allow for enough room to take the blower motor housing out just go get a helms manuel and do it. i would not get a junk yard one tho!
at the right side under dash on the blower motor assenbly there are some brown plugs 1 has 2 wires a yellow/black ( power ) and a blue/red ( ground ) make sure you have both ,, if you do replace motor,,,,,,,the DEADZONE ( AUTOZONE ) sells them cheap..i would not install a used 1 from a salvage yard and factory ones are expensive
tmiani59
07-03-2019 03:38 AM
DSKlos
12-07-2006 04:09 AM
