Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 11-20-2005, 10:25 AM   #1
djbrandonr
djbrandonr's Avatar
Default Balance Shaft Removal::HOW TO!!
So I decided to take some pics since I pulled these out the other day and couldnt find any write-ups w/ pics on how to do this. All in all it wasnt that hard (w/ a block out of the car) but sometime its just nice to see pics. BTW my helms was worthless IMO. Perhaps we can this stickie this to the FAQ's as well.
BTW my coochie hurts and I need a 56k beware cause I dont got DSL..lol..j/k
Tools:
Ratchet
10mm and 12mm socket
Flat tip screwdriver
Hammer
Balance Elim. Kit
So heres what were workin to today
First you'll need to remove the crank pully, then this sprocket will be on the shaft, but Im not gonna put it back on just for the pic. I think removing this part was the hardest part of the job..
First is the front balancer. If you look down youll see a hole.
I dropped a screw driver in the hole to keep it from rotating while I loosened the bolt holding the pulley on..
Then the pulley just comes off real easy
Then I removed the bolts around the shaft and the auto tensioner as well
On to the rear balancer. Remove the 2 bolts and one nut
And the housing should come off with the tap of a hammer or pryed w/ a flat tip to look like this
So here we are so far(plus the crank sprocket), we'll come back to the rear shaft pulley is a few. Remove the bolts that hold the oil pump to the block. Should be 4 bolts or so.
Start prying around the housing to free the pump. Just work around it till it pops loose. Remeber as well that the crank/oil pump sprocket is keeping the housing on there tight. Initially I used my screwdriver to pry the sprocket off some. I the stopped and cussed a few chioce words at my Japper ancestors and used the backside of a hammer to pry some more till it was almost at the end.
Now before you get the sprocket totally off you'll need to pull this metal guide out w/ a pair of pliers. If you dont...
You wont be able to get this washer past it as you pull the oil pump off.
With that done we should be able to pull the pump off at least an inch or so. Since we can were gonna pull the rear pulley off similar to the front, only the hole is between the pump and block.
*EDIT* There is actually a bolt to the right on the backside of the block that allows access to the hole in the shaft, but I didnt know till later on. So you can actually remove the pully before prying the housing.
And off it comes
Now we can pull the pump off. If you have yet to remove the lower sprocket fully I found the pump to be a good tool to yank forward and help knock it off the crank. How good that is for the pump I dont know, but it worked.
Now we have acess to the shafts. Theres 2 bolt holding the front shaft in and nothin holding the rear one on.
"Free at last, free at last" Just pull them out
The rear is on the right and front on the left, and now you done.
This took just shy of an hour and prolly would be a bit tougher in the car. Hopefully I dont need to remind you that you should've bought the kit to plug everything up unless your a true DIY'r. Hope this helps and let any posting begin. If I forgot something lemme know.
Modified by djbrandonr at 9:56 PM 11/20/2005
Modified by djbrandonr at 10:48 PM 11/28/2005
djbrandonr is offline   Reply With Quote
Old 11-20-2005, 10:34 AM   #2
SteveoBA8
SteveoBA8's Avatar
Send a message via ICQ to SteveoBA8 Send a message via AIM to SteveoBA8
Default Re: HOW TO:Balance Shaft Removal (djbrandonr)
Good job man, this should be in the Faq's.
94 BA8 H powered
Project Ruckus????
SteveoBA8 is offline   Reply With Quote
Old 11-20-2005, 10:37 AM   #3
92hondalude
92hondalude's Avatar
Send a message via AIM to 92hondalude
dont forget to turn the bearings 180 degrees to plug the oil ports Click the image to open in full size.
do you have to get the plugs pushed in by a mechine?
JDMPowerhouse comming soon!
7.61 @102MPH
92hondalude is offline   Reply With Quote
Old 11-20-2005, 10:49 AM   #4
LudeyKrus
LudeyKrus's Avatar
Send a message via AIM to LudeyKrus
Good post Click the image to open in full size.
Needs to be thrown in the FAQ's
1992 Prelude w/ H23-VTEC...handbuilt by me / 1991 MR2 Turbo
1982 Suzuki GS450 - the Rat/Cafe / 1978 Suzuki GS750 - Cafe Racer in Progress / 1977 Harley Sportster - the Chopper
LudeyKrus is offline   Reply With Quote
Old 11-20-2005, 10:51 AM   #5
Hawkze_2.3
Hawkze_2.3's Avatar
Cool, don't forget to show us how the installation of the kit goes. Click the image to open in full size.
'95 Prelude--intake, windshield washer lights, rear body kit, carbon fiber windows. '86 Mazda RX7--Chevy & Borg-Warner powered. '99 Honda CRV--Jurassic Park tour vehicle. '98 Chevy Lumina--what is that thing?
Hawkze_2.3 is offline   Reply With Quote
Old 11-20-2005, 10:54 AM   #6
djbrandonr
djbrandonr's Avatar
Default Re: HOW TO:Balance Shaft Removal (92hondalude)
Thats what they say. I dont have the kit yet actually. I just got the block the other day and got al excited for my build here after winter that I just started tare'n **** apart.
Old 11-20-2005, 02:08 PM   #7
bigz187
bigz187's Avatar
i know its kind off topic..but what would happen if the balance shaft belt broke?? And could u still drive the car??? Is it possible to remove the belt with the motor still in the car???
bigz187 is offline   Reply With Quote
Old 11-20-2005, 03:07 PM   #8
EGmikeH22
* B A N N E D *
Send a message via AIM to EGmikeH22
i removed the belt with the engine in a civic, with the lower timing belt cover on,
yes its possible, just make sure the car is off.
EGmikeH22 is offline   Reply With Quote
Old 11-20-2005, 05:46 PM   #9
mgags7
mgags7's Avatar
i doubt you could do this in car....the shafts probably couldnt fit out.....but it may work...
good post though Click the image to open in full size.
mgags7 is offline   Reply With Quote
Old 11-24-2005, 09:10 AM   #10
high_revs
high_revs's Avatar
Send a message via AIM to high_revs
nice diy...
2005 silverstone S2000
k&n intake, megan 3" exhaust...13.607 @ 103.65
high_revs is offline   Reply With Quote
Old 09-01-2006, 03:40 PM   #11
djbrandonr
djbrandonr's Avatar
Default Re: (SB tuning)
All right lets finish this **** off. I finally got a half day off from my 7 day a week jobs.
Okay so you gotta have the balance shaft elim. kit to do this obviously. Now youre gonna need a press of some sort. If you lucky like me to have a neighbor/landlord that just so happens to be a blacksmith that has all the tools in the world you just might have one of these in the garage. Its a press, but doesnt require electricy or air.
First I started w/ the oil pump and the balance shaft plugs. Like so..
Press in the left one
Press in the right
They recommend using loctite sleeve retainer if pressing these plugs into a used oil pump. Then you put on the bling blingin' rear balance shaft gearcase cover and the pump plugs are done.
Now onto the girdle. The ones circled in red need to be removed. Remove the dowel pins sticking out w/ a pair of vise grips. Itll sandwich a bit, but thats okay and twist it till it comes out.
On a side note if your a dumbass like I was, I was all excited about getting going on the kit that I didnt remove the main caps and pulled the first dowel outta the cap and found the plugs didnt fit. That is why. Nick @ kaizen was nice enough t assist me through my own mental retardation...lol...
So remove the one dowel on top and the 3 on the bottom.. Heres they are only to be replaced..
By these..
The big one of the 4 goes in location "C" (see girdle pic) The other 3 are in the "D" spot...hmmm to bad there isnt a "G"spot in this install...lol...
So now we press those in
Till theyre all in like so..
Now plug "C" should be pressed in so that no more than .360" is protruding and "D" is no more than .405" out so that the main caps can seat properly. So I measure..
And its "money Mikey, your so f'n money"
Then I tapped the main caps back on to make sure everything is flush and pressed in far enough
See no gaps in seating
Lastly we need to block an oil passage in the block that runs to one of the shafts.
The top center hole. For reference the back of the block is at the top of the pic and flywheel would be to the right.
So you go in w/ a 11/32 drill bit into the hole. Youre really just reaming the whole out IMO not tearin through mass amounts of metal. Drill till you get to the back of the bearing..
Then you bust out the supplied tap..and yes it really is shiny as excalibur..
You use a 12pt. 10mm socket and tap the hole you just drilled enough to get the supplied plug in. Sealent recommended.
Now you done. Overall this is pretty easy install w/ the block out. You could probably do this w/ the block in, but Im not sure if you could get the shafts out. Difficulty wise its more of a PITA to raise my car up a few inches for winter than it was to do this kit.
Old 09-01-2006, 03:51 PM   #12
DIRTYsouthBB6
DIRTYsouthBB6's Avatar
There have been a lot of great posts in this forum today, including this one. Now we need the moderators to start adding to the resource threads.
DIRTYsouthBB6 is offline   Reply With Quote
Old 09-01-2006, 04:06 PM   #13
MadCityLude
Guest
Posts: n/a
Default Re: (DIRTYsouthBB6)
I sent a request for this to be in FAQs. Damn good writeup bro!
Old 09-01-2006, 04:22 PM   #14
98vtec
Gone Fishin'
1998 Honda Prelude
98vtec's Avatar
efi.logistics.by.blake.barr bbmoto
damn right, getting back to where we were a few years ago.
Mercedes-Benz Systems Technician
Pescador Perception Sport 12.0 w/ 30# Minn Kota
1998 H2B Turbo Prelude - project
98vtec is offline   Reply With Quote
Old 09-01-2006, 10:04 PM   #15
Hawkze_2.3
Hawkze_2.3's Avatar
Default Re: (98vtec)
It's all up to us. Click the image to open in full size.
I wish I didn't have 56k BS right now so I could see these pics. Looks like an awesome write-up. Click the image to open in full size. Click the image to open in full size.
Old 09-01-2006, 10:50 PM   #16
Beau Gotti
Beau Gotti's Avatar
Send a message via AIM to Beau Gotti
Pretty Informative. i didnt relize that kit came with all the stuff internally for the motor, i thought it was just the pump plugs. it might acctually be worth dishin out the money for the kit.
great how-to. im about to start tearing down this h22 i have had in teh garage for like 38748724 years and do something with it i guess lol
1994 Honda Civic DX - RHD FUCKERS!!!
HPK member - 79
LS/VTEC- PR3 Skunk2 AEM Supertech AEBS ACL ARP Corbeau Autometer ST ASR
Beau Gotti is offline   Reply With Quote
Old 09-03-2006, 02:49 PM   #17
-Bionic-
Former Sponsor
Send a message via AIM to -Bionic-
Default Re: HOW TO:Balance Shaft Removal (bigz187)
My balance shaft belt broke a few weeks ago, and it also damaged the timing belt, so the shop told me to install a new timing belt and not to replace the secondary belt.
Now, I am torn between people telling me to put the balance shaft belt back on, and those telling me to get the kit to completely remove it.
My car is out of commision as it's getting ready for boost, but with turbo and potential vibration...is this a good combination?
Great write up Click the image to open in full size. Wish my neighbour had the tools too. Click the image to open in full size.
-Bionic- is offline   Reply With Quote
Old 09-03-2006, 02:53 PM   #18
ECX
* B A N N E D *
Send a message via AIM to ECX
Default Re: (LudeyKrus)
ECX is offline   Reply With Quote
Old 09-04-2006, 12:08 AM   #19
del_parker
del_parker's Avatar
Default Re: HOW TO:Balance Shaft Removal (-Bionic-)
You can run it with just the balance shaft belt removed.
del_parker is offline   Reply With Quote
Old 09-04-2006, 06:11 AM   #20
94draglude
94draglude's Avatar
Whats the Benifits/Difference between just removing the balance shaft belt or doing the balance shaft elimination kit?
94draglude is offline   Reply With Quote
Old 09-04-2006, 07:43 AM   #21
high_revs
high_revs's Avatar
more oil pressure becuase none of the oil is being used to lubricate the shafts and less rotational assembly loss.
Old 09-04-2006, 07:57 AM   #22
2lude4u
2lude4u's Avatar
& less weight on your front end for better balance & acceleration
2lude4u is offline   Reply With Quote
Old 09-04-2006, 07:59 AM   #23
high_revs
high_revs's Avatar
Default Re: (2lude4u)
Originally Posted by 2lude4u
& less weight
your right, about 22lbs lightwer w/o the shafts and all the crap that runs them Click the image to open in full size.
Old 09-05-2006, 03:17 PM   #24
96-EJ6 B18C
96-EJ6 B18C's Avatar
Send a message via AIM to 96-EJ6 B18C
Good write-up, thanks for sending me the link. Click the image to open in full size.
No need to rotate the bearings with our kit, the plugs block the oil supply to the bearings.
-KAIZENSPEED- ASE Certified, EFI-U Accredited......IN-HOUSE DYNO DYNAMICS DYNO!
Engine Building, Swaps, Dyno Tuning, ECU Chipping, H22 Balance Shaft Elimination kits.
TiAL, Precision, Hondata, eCtune, Injector Dynamics, Benson Sleeving...
96-EJ6 B18C is offline   Reply With Quote
Old 09-05-2006, 04:37 PM   #25
high_revs
high_revs's Avatar
i've been running this kit since january, great stuff Click the image to open in full size.
accord, align, balance, balancer, balancing, bearings, eliminate, h22, h22a1, honda, prelude, removal, remove, shaft, shafts
Similar Threads
The official auto to manual ECU conversion thread lunarcry Honda Prelude 83 01-02-2014 06:57 PM
pics of painted steelies SILVER97EX Honda / Acura 370 10-06-2013 03:49 PM
oil cooler install pics! drift2004 Acura Integra 9 07-05-2013 04:48 PM
new exhaust done turbotypeR@SPEC Forced Induction 40 03-29-2013 07:46 PM
