engine make wierd whistle noise
#26
very good. yes its a b18c1. does anyone have a diagram of these parts for reference.. thank you very much vegas for the info, and i think u may be right.it does sounds like its coming from the throttle body area. its funny how a hood can make sounds bounce off everywhere..
#27
Re: engine make wierd whistle noise (civicdreamin)
Originally Posted by civicdreamin
so im having a similar problem i think.. its a 2000 integra gsr sedan.
heres some videos of when its cold, and after its warmed up..
I really need help figuring out whats making the whine in the engine.
Any help is great
This is Cold engine.
This is warmed up
It seem like it comes and goes sometimes and maybe not as loud sometimes..
it had had recent timing belt changed maybe 10k or so ago and trans flush..All service as been kept up to date.. 114000 miles and runs great..
ps i did a search and this thread is the only one i found on this topic back from 2002.. it does not look like anyone came to a conclusion on what it is.. plz help
Modified by civicdreamin at 5:34 PM 11/12/2008
Any help is great
This is warmed up
You guys crack me up!
The whistle you hear is nothing more than that air filter. Close your intake box and BAM! Like magic; no more whistle.
LMAO. Hilarious how people can get so paranoid.
PS: I think the whistle is kind of cool (sound like the car has something crazy in the hood) I take my box off once a while for $h!ts and giggles. No performance advantages of having it off BTW (to me it actually feels less reactive and annoying at WOT).
#29
Re: (SkaiWu)
sorry wrong answer Freshazzburu. trust me its not the stock air box that i have on..lol
i can here the air being sucked into the air box and it does not whine like this.. lol
well i took a screw driver and it does seem like it gets stronger around the throttle body but still not 100%.. ty for all your replys
Freshazzburu is not a dam whistle its a Whine and its loud lol
#30
I'm Huge In Japan
Re: (civicdreamin)
Sorry bro I don't really have access to a diagram right now, or a car for that matter to take it apart & show you. But it's really not too difficult, on a scale of 1-10 it's about a 2. Pick up a Haynes Manual from the store while you're out getting intake cleaner.
The easiest way to check is just to pull off your intake assembly; there's two holes right before the butterfly, the bottom one goes through the FITV. Put your finger over it, & the squeal should stop.
If not, try the other hole since you have the intake off, it might be your IACV (Idle Air Control Valvev - it's basically another FIT valve but not as useless).
#31
Wow I'm surprised nobody mentioned timing belt tensioner. It also could be a pulley or a belt. When the engine is idling, place your ear around the engine bay and give us an idea of where the noise is coming from.
#33
I am having the same issue with my B16a...I took the intake off and its coming from the throttle body....and its only at idle when it does it. when Im driving it goes away ill try that fit valve when I get back into port
#34
well i still have not had time to take it to the shop to have them look at it.
im thinking its still from the intake area but i also wonder if it could be the power steering bearings.. hmm
i will update when i find a cure.
#35
doesn't sound your doing anything to isolate the problem. I took of my intake and held my hand up to my throttle body were the noise was coming from. at a certain angle with my hand covering it the noise stops. I am wondering if the plate has been bent which would cause more air then normal to get into the intake mani at idle causing idle surge which is the computer correcting for the increase in air coming through at idle. The car drives fine. However its an annoying loud like a wleded civic tailpipe as well as the idle surge at 15-20
#36
My 1999 GSR Sedan has 127K on the odometer and is making a similar noise. Its definitely from the left side of the engine. Its loudest around the timing belt area. Unsure if its t-belt rubbing the VC or something like the alternator, PS, AC compressor or the accessory belts..... Thanks!
#39
Hate to bump an old thread, but i am having this same problem, and there seems to be no solution posted here.
My whistle sound is coming from the #1 cylinder, clear as day when i put my head on the valve cover. It's right in that area. I did a valve adjustment and this sound is present when my car warms up, after reassembly. Any thoughts?
#40
I'm quite shocked no one has mentioned the brake booster in this thread, when they start to go out they can cause a whistling noise, which in reality is a vacuum leak. Most people forget also sound does travel and can be hard to pin point where its actually coming from. But I'd check that, is what i usually find to be the problem when working in my shop.
#41
I'm Huge In Japan
I saw *****, so I'm responding. You probably have something stuck in your cylinder head, have a bad cam journal, a lubrication problem, or mice. I'd say it's probably mice.
#42
i to also get a whistle only when i give it gas for about a second and its weird, its kinda annoying but it hasnt affected the way i drive
ringgold
07-03-2005 04:22 PM
Twiet
12-06-2004 02:04 PM
