Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 10-28-2005, 10:49 AM   #1
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
Send a message via AIM to CustomVW
Default What causes EXCESSIVE moisture in exhaust?
I have a 1989 CRX HF. It is completely stock. I just put on cap/rotor/plugs, air filter, new valve cover gasket kit and changed the oil change. The car has had this issue since I got it a few weeks ago. It used to want to stall out if i reved it for a while and then let off the gas, now it runs very well no matter what i do to it but there is tons of moisture coming out the tailpipe. If I really rev it it makes a puddle.... doesn't smell or look like coolant... there is some smoke too, looks white, but doesn't smell sweet and there is no oil or bubbles in the coolant which is in the new radiator. Click the image to open in full size.
2006 Pilot EX 4WD
1994 Civic EX Coupe
1989 CRX HF w/SI swap
CustomVW is offline   Reply With Quote
Old 10-28-2005, 10:57 AM   #2
strictlyimport
strictlyimport's Avatar
Default Re: What causes EXCESSIVE moisture in exhaust? (CustomVW)
Its just moisture and its perfectly fine..... as far as what it is, I don't know.
1988 CRX SI - Parting out
First Gen B16- for sale (complete swap including linkage $1900)
**NEW**
2004 Civic Si
strictlyimport is offline   Reply With Quote
Old 10-28-2005, 11:25 AM   #3
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
Default Re: What causes EXCESSIVE moisture in exhaust? (strictlyimport)
I am concerned that the Inspection ref here in NJ will fail me for "visible smoke" and not buy that it is just moisture... Click the image to open in full size.
2006 Pilot EX 4WD
1994 Civic EX Coupe
Old 10-28-2005, 11:28 AM   #4
vtecn8ive
vtecn8ive's Avatar
Send a message via ICQ to vtecn8ive Send a message via AIM to vtecn8ive
perhaps water is trapped in cat
91 Civic Rt4wd+d15z1
90 Crx HF stock+some goodies Vouches
vtecn8ive is offline   Reply With Quote
Old 10-28-2005, 11:49 AM   #5
JSpin
JSpin's Avatar
Send a message via AIM to JSpin
Default Re: What causes EXCESSIVE moisture in exhaust? (vtecn8ive)
a lot of cars do it, and it's usually ok; water is a natural by-product of combustion. have a look at a few tail pipes next time you're in traffic and take off from a stop light.
'06 GSXR1000
'07 Busa
'88 civic 4dr, b-series turbo powered by: 1.8 b16, precision sc61, aem ems, blah blah blah
JSpin is offline   Reply With Quote
Old 10-28-2005, 11:51 AM   #6
Tyson
Tyson's Avatar
its your catalytic converter working well. you wont be failed for this...
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline   Reply With Quote
Old 10-28-2005, 12:58 PM   #7
strictlyimport
I don't think that it is visible smoke, just evaporation from the water. Does it leave a cloud of smoke, or does it disappear quickly?
**NEW**
2004 Civic Si
Old 10-28-2005, 01:18 PM   #8
Outsane
Outsane's Avatar
Send a message via ICQ to Outsane Send a message via AIM to Outsane
Default Re: What causes EXCESSIVE moisture in exhaust? (Tyson)
Outsane is offline   Reply With Quote
Old 10-28-2005, 01:20 PM   #9
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
It leaves a cloud, but that disipates in the same amount of time as I was reving it..
I woulkd love to think its just steam, but something just dosn't seem right about it... my 90 crx never has done this... Click the image to open in full size.
2006 Pilot EX 4WD
1994 Civic EX Coupe
Old 10-28-2005, 01:48 PM   #10
zrk666
zrk666's Avatar
i own a 90 crx hf that i bought as a shell and put a stock d15 in it to save gas and money. it has been doing the same thing. if it doesnt smell like coolant or oil you should be ok. i dont know if it could be the cat because this is the first car that i have ownd with a cat!
90 HF CRX
WTB F22B1 SOHC VTECHw/manual trans
zrk666 is offline   Reply With Quote
Old 10-28-2005, 01:51 PM   #11
rsca_crx
rsca_crx's Avatar
really, it is. Žnuff said. Click the image to open in full size.
for sale:
91 EX knuckles
*mint* crx si sunroof assembly. red.
mpfi obd-0 distributor (si, hf, ex)
mpfi resistor boxes
crx hf front swaybar
(8) 91 si wheels.
tons of interior stuff in good shape. (28k on car)
bumper supports + f. crossmember
jdm sir radiator and core support
i need:
88 (or 89hf) crx exterior door sash's and seatbelts
rsca_crx is offline   Reply With Quote
Old 10-28-2005, 04:16 PM   #12
GreenBean
GreenBean's Avatar
Default Re: What causes EXCESSIVE moisture in exhaust? (rsca_crx)
Amen.
Moisture, or water vapor is present in the exhaust as a by-product of combustion and the catalytic converter.
GreenBean is offline   Reply With Quote
Old 10-29-2005, 12:27 AM   #13
killa rex
2006 Honda Motorcycle
My Garage
killa rex's Avatar
Default Re: What causes EXCESSIVE moisture in exhaust? (GreenBean)
yeah it's just water in the moffler..i had the same issue when i got my rex..just drive it around for a couple of days and it should be gone
MotoGP 2009 Teams
killa rex is offline   Reply With Quote
Old 10-29-2005, 03:27 AM   #14
StorminMatt
If there is excessive water in the muffler, then it is likely caused by taking numerous short trips that don't allow the exhaust system to warm up sufficiently to boil out the excess water. Try taking the car for a long drive. This will probably get ridof all the water.
VTEC or non-VTEC? BOTH!
1988 B20Z Civic DX 4DR Sedan
1988 B18C5 CRX DX
1995 Allmotor GSR (All motor, no car!)
Coming soon: 1989 D15Z1 Civic STD HB - The Gas Saver!
StorminMatt is offline   Reply With Quote
Old 10-29-2005, 03:36 AM   #15
BlueShadow
When you go to smog your car you wanna drive it hard and for at quite bit of time. Once the car has been running for a long time all the metal in the exhaust system will be hot enough to where the condensation and water collected will be evaporated and blown out of the exhausts.
BlueShadow is offline   Reply With Quote
Old 10-29-2005, 05:28 AM   #16
VegaS10
VegaS10's Avatar
My rex did the same thing when i first got it. The previous owner had no cat whatsoever. Used to leave large black puddles when I revved it in the driveway. I put a new high flow cat on it...no puddles.
VegaS10 is offline   Reply With Quote
Old 10-29-2005, 06:02 AM   #17
george34
george34's Avatar
Default Re: (VegaS10)
I have noticed a lot of liquid and i have decided that it is just water; like everyone has said. I don't drive my car for long at all at a time maybe 10 mins so the whole water build up thing is probably happening to me.
Also about the smoke i'm having the same problem as u and do not kniw if it is condensation or a blown HG. I think my car smpked a little when it was summer so i think i have a blown HG.
CRX <U>"IT'S A ROCKET"</U>
george34 is offline   Reply With Quote
Old 11-03-2005, 08:16 AM   #18
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
Well it looks like my "white" smoke is really "blue" smoke..... i am going to buy a compression tester and start there, but why would it run "seemingly" perfect but smoke like a chimney???? Click the image to open in full size.
2006 Pilot EX 4WD
1994 Civic EX Coupe
Old 11-04-2005, 12:01 AM   #19
killa rex
My Garage
killa rex's Avatar
ur running too rich
MotoGP 2009 Teams
Old 11-04-2005, 01:46 AM   #20
gutterslide
gutterslide's Avatar
Send a message via AIM to gutterslide
Default Re: What causes EXCESSIVE moisture in exhaust? (StorminMatt)
[url="http://www.fourthgenhatch.net"]<FONT COLOR="black">fourthgenhatch.net</FONT>[/url] | [url="http://www.hondacivicwagon.com"]<FONT COLOR="black">hondacivicwagon.com</FONT>[/url] | [url="http://www.cb7tuner.com"]<FONT COLOR="black">cb7tuner.com</FONT>[/url]
[email="fourthgenhatch@gmail.com"][B]<FONT COLOR="teal">Got a good EF DIY? Submit it to FourthGenHatch.net</FONT>[/B][/email]
gutterslide is offline   Reply With Quote
Old 11-04-2005, 02:28 AM   #21
george34
george34's Avatar
Default Re: What causes EXCESSIVE moisture in exhaust? (gutterslide)
The short trips that i always take may have had moisture in my exhaust. I have taken my car for longer drives since this thread and there is now no smoke.
Old 11-04-2005, 06:20 AM   #22
SETI20
SETI20's Avatar
Send a message via ICQ to SETI20 Send a message via AIM to SETI20
floor it for a good 5 minutes to get rid of excess moisture in your exhaust. This is what causes most of the rusting on non stainless exhausts.
Flickr
SETI20 is offline   Reply With Quote
Old 11-04-2005, 06:46 AM   #23
NACvicSi
1994 Honda Del Sol
NACvicSi's Avatar
TheSylntChamber
Send a message via AIM to NACvicSi
blue smoke it oil smoke
NACvicSi's For Sale Thread --> http://hondamarketplace.com/showthread.php?t=2572587
94 Del Sol Vtec EG2, 97 Civic Hatch CX, 05 SS S2000
NACvicSi is offline   Reply With Quote
Old 11-04-2005, 09:09 AM   #24
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
Default Re: (SETI20)
Did that, no change....
2006 Pilot EX 4WD
1994 Civic EX Coupe
Old 11-04-2005, 09:11 AM   #25
CustomVW
1989 Honda CRX
My Garage
CustomVW's Avatar
Default Re: (NACvicSi)
I know, and I suspect valve seals, but I just don't understand why it still runs so well (well at least in the parking lot, never had it on the road)....
2006 Pilot EX 4WD
1994 Civic EX Coupe
car, catalytic, cb7tuner, coming, condensation, crv, engine, exaust, excessive, exhaust, honda, hot, moisture, normal, pipe
