Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura TSX
Old 10-21-2005, 07:04 AM   #1
Dougie Pants
Dougie Pants's Avatar
Send a message via AIM to Dougie Pants
Default K24A1 vs K24A2 vs K24A4 Short Blocks
So I'm not getting many answers from the boys and girls on K20A.org on this. I know that the K24A1 has lower compression than the K24A2 and does not have the Oil Squirters as well. Are there any other differences like main caps or girdle?
[img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [B]Odorless Imports Photographer[/B] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
[b]FS: Advan RG's 15x6.5 +35[/b]
[url="http://honda-tech.com/zerothread?id=1797591"]http://honda-tech.com/zerothread?id=1797591[/url]
[b]FS: J抯 Racing 50RR Full Hand Made Titanium Exhaust[/b]
[url="http://honda-tech.com/zerothread?id=1824839"]http://honda-tech.com/zerothread?id=1824839[/url]
Dougie Pants is offline   Reply With Quote
Old 10-22-2005, 04:35 PM   #2
ZygSpeed
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Dougie Pants)
What year cars have those motors?
ZygSpeed is online now   Reply With Quote
Old 10-27-2005, 08:28 AM   #3
Nikos
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (zygspeed)
Well,
these are the accord, element, crv and tsx blocks.
Are you asking about bare blocks or what?
Each girldle comes with the block so you cannot buy one on its own. In case you want to mix and match, you could have it decked etc...
All these blocks for the most parts use the same parts. yes, the TSX has oil squirters but when sleeving a block we have been adding the oil jets to non tsx k24a blocks.
Only major difference in bare blocks is that the CRV block can take a type s oil pump with less trouble then a tsx, accord, element block.
here's how a type s oil pump is fitted on an accord block
Nikos is offline   Reply With Quote
Old 10-29-2005, 01:10 PM   #4
Oregon
* B A N N E D *
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Nikos)
Contact chad_everson on Honda-tech He's knows ALOT about K-series Click the image to open in full size.
Oregon is offline   Reply With Quote
Old 10-30-2007, 07:57 AM   #5
onefstek
onefstek's Avatar
Send a message via AIM to onefstek
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Oregon)
Chad don't know crap. You can tell him I said so. Click the image to open in full size. Click the image to open in full size. lol
2013 All Motor | 92 Civic h/b | 10.503@130.2mph 88bore x 99stroke 2050 lbs
Custom Headers : www.aspheaders.com
ASP | Drag Cartel Industries | Kinsler Induction | Competition Clutch
onefstek is offline   Reply With Quote
Old 10-31-2007, 12:02 PM   #6
evertp1
evertp1's Avatar
I HOPE THIS HELPS
K24A1
* Found in:
o 2002-2006 Honda CR-V
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 9.6:1
+ Power: 156 hp (119 kW) @ 6000 rpm
+ Torque: 162 ft路lbf (220 N路m) @ 3600 rpm
+ Redline: 6500 rpm
K24A2
* Found in:
o 2004-2008 Acura TSX
+ Compression: 10.5:1
+ Power: 200 hp (147 kW) @ 6800 rpm (2004-2005)
+ Power: 205 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04
+ Torque: 166 ft路lbf (225 N路m) @ 4500 rpm (2004-2005)
+ Torque: 164 ft路lbf (222 N路m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04
+ Redline: 7100 rpm
K24A3
* Found in:
o 2003-2006 Honda Accord (Europe, Japan, and Australia)
+ Power: 189 hp (140 kW) @ 6800 rpm
+ Torque: 164.5 ft路lbf (223 N路m) @ 4500 rpm
+ Redline: 7000 rpm
K24A4
* Found in:
o 2003-2005 Honda Accord, 2003-2008 Honda Element
+ Compression: 9.7:1
+ Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
+ Torque: 161 ft路lbf (218 N路m) @ 4500 rpm (@4000 rpm in 2007/2008)
+ Redline: 6500 rpm
K24A8
* Found in:
o 2006-2008 Honda Accord
+ Power: 166 hp (124 kW) @ 6000 rpm (2006/2007)
+ Power: 177 hp (132 kW) @ 6500 rpm (2008 LX) and 190 hp (140 kW) @ 7000 rpm (2008 EX)
+ Torque: 160 ft路lbf (217 N路m) @ 4250 rpm (2006/2007)
+ Torque: 161 ft路lbf (218 N路m) @ 4300 rpm (2008 LX) and 162 ft路lbf (220 N路m) @ 4400 rpm (2008 EX)
+ Redline: 6500 rpm
+ Redline: 6800 rpm (LX) /7100 rpm (EX)
K24Z1
* Found in:
o 2007-2008 Honda CR-V
+ Power: 156 hp (119 kW) @ 6000 rpm (166 hp @ 5800 rpm in 2007/2008)
+ Torque: 161 ft路lbf (220 N路m) @ 4200 rpm
+ Redline: 6500 rpm
CL9 Squad #68
My Quote: The Integra Came Before The Type S, So They Typed R!
evertp1 is offline   Reply With Quote
Old 11-01-2007, 05:06 AM   #7
evertp1
evertp1's Avatar
DO NOT put a K20A or A2 head on any K24 block and expect it to do 8000rpm
CL9 Squad #68
Old 11-04-2007, 10:04 AM   #8
JDMsam.
JDMsam.'s Avatar
Default Re: (evertp1)
that k20 heads + k24 block= nonreliable
JDMsam. is offline   Reply With Quote
Old 11-04-2007, 10:14 AM   #9
onefstek
onefstek's Avatar
Default Re: (JDMsam.)
why do you say that?
Old 12-04-2007, 06:17 AM   #10
evertp1
evertp1's Avatar
Basically the K24 is the New B20 and the K20 is the B18C5... my 2004 TSX has 205 BHP, and a 2002 RSX Type S put outs the samthing with less torque... it wouldnt make sense to put a K20 head on a K24 block...
K20 was made for High HP and high RPM... the K24 is for Torque... so if you want one or the other, buy a RSX or a TSX
CL9 Squad #68
Old 12-08-2007, 07:21 PM   #11
donz
donz's Avatar
wow, r u kidding? Please look into the flow of the k20 head. Sure there is no 8000 rpm, but the extra torque makes up for that and more.
Please check k20.org before making yourself look bad.
have you heard of honda challenge?
FS: 02, 03, 04 civic SRS cable Reel Clock spring. $20 Brand new never installed!!!
part number 77900-S5A-A14
donz is offline   Reply With Quote
Old 12-08-2007, 07:38 PM   #12
evertp1
evertp1's Avatar
Default Re: (donz)
how am i making myself look bad? i know the K20a head is made for flow... its made so the air can flow freely at those high RPMs, thats why the K20 has a K20 head and a K24 head is different head! where could I have possibly gone wrong?
CL9 Squad #68
Old 03-10-2010, 06:45 PM   #13
VtecNotRequired
1990 Honda Civic
VtecNotRequired's Avatar
Default Re: (donz)
really sorry to bring this back from 07 but i was googling K24 differences and this was the first option. this is the funniest **** ive read in a while and thought you guys would like a good laugh too.
1990 Honda CRX
My Current Build Thread:
http://honda-tech.com/showthread.php...3#post42403883
VtecNotRequired is offline   Reply With Quote
Old 03-10-2010, 08:22 PM   #14
JDM FERIO RS
JDM FERIO RS's Avatar
Actually if you put a k20 head on a k24 block its all about tuning. Yes u may not have the high rpms like a k20a,k20a2,k20z1,k20z3 but its all bout tq in the heavier cars. I personally have a k20/24 frank swap in my fg2 and let me tell you im very pleased with my low end and top end tq. Yea u Can rev the k20a,k20a2,k20z1,k20z3 motors to 8200-8500 depending if you have flash pro, kpro but with no tq its point less. And the tsx head is very similar to all the others except it has a dif intake manifolf but it still uses the real vtec mechanism unlike the accord and crv and element. With my I/H/E, TBS,FP using hondata calibration my beast has about whats listed on its website but shy of the tq by a few ticks. But 275 whp and 205 tq is good enough for a few bolt ons and flashpro. So my advice to to anyone the extra tq is def a dif maker in any car but in a few yrs when every body is swappin 2.0 blocks for 2.4 just remember what I said its 2.4 FTW
Like capital 1 what's in ur honda FG Squad # 12
07 FG2 k20/24 on F-pro, 03 DC5 ITR Inspired-sold, 03 Ferio R.I.P,06 STI/cobb,
*NegroFlush* its not a statement, its a lifestyle
JDM FERIO RS is offline   Reply With Quote
Old 03-11-2010, 10:46 AM   #15
Mr. DB2
Mr. DB2's Avatar
I went from an 08 Si sedan(K20Z3) to an 04 6-speed TSX(K24A2) and the two are very different. Yes the Si is a tad bit quicker light to light,but was slower from an 60mph plus roll. The torque and constant feel of the K24A2 is much better for city driving and/or having passengers. The Si in city driving or with 1 or 2 people felt very sluggish if you didn't rev the **** out of it. Of course the Si had the "cool" loud as hell vtec crossover(didn't have nothing on my old 92 GS-R),but I kinda enjoy not broadcasting to the world that I'm accelerating(especially bored cops). It all depends what you want out of your engine and what kind of driving you do with it.
2004 San Remo Red WRX COBB stage 2 w/supporting mods
Mr. DB2 is offline   Reply With Quote
Old 03-11-2010, 12:11 PM   #16
VtecNotRequired
1990 Honda Civic
lol i wasnt really trying to start this thread back up, i know this already and thats why reading it was just funny, the guy a few posts up dont even know what hes talking about
1990 Honda CRX
Old 03-12-2010, 10:04 AM   #17
20-EM2-05
20-EM2-05's Avatar
Naw really!? It was back in 07 where K swaps were still rare to see compared to seeing one every day.
I bet if we went back to 1998, no one ever heard of b20v or a b20 swap.
6thgenaccord.com
20-EM2-05 is offline   Reply With Quote
Old 03-12-2010, 11:37 AM   #18
Mr. DB2
Mr. DB2's Avatar
^Acually in 1998 b20's where in alot of hatches in my native homeland of Miami. B20's using LS or GSR trani's,LS intake manifolds,and chipped ecu's.Very cheap alternative. They were even cheaper that LS engines at the time..
Old 03-12-2010, 12:12 PM   #19
20-EM2-05
20-EM2-05's Avatar
But they weren't as popular as they are now, since people have discovered their potential by having it vtec.
6thgenaccord.com
Old 03-15-2010, 02:12 PM   #20
Mr. DB2
Mr. DB2's Avatar
I think their popularity has died down with K-series & J-sreies swaps taking over.
Old 11-11-2011, 09:34 PM   #21
black and pink
black and pink's Avatar
adonis james adonis james
so which is better stock k24a2 with bolt ons an kpro? or frank k20a2/ k24a1 with bolt ons and kpro?
black and pink is offline   Reply With Quote
Old 01-09-2012, 08:09 PM   #22
neihouse123
2002 Honda Civic
neihouse123's Avatar
Adam Neihouse Fat001 Pubertfairy001
Send a message via Yahoo to neihouse123
i kinda would like the answer to the aformentioned question by Black and Pink
neihouse123 is offline   Reply With Quote
Old 01-24-2012, 07:47 AM   #23
speedjunkie_g35
2013 Subaru Legacy
My Garage
speedjunkie_g35's Avatar
GANGSTER G35
I would say the Frankenstein would be better. IT is the reason I got back into the Honda scene. I had one blow the doors off me with simple bolt ons and a tune
-Not sponsored by Mom and Dad Motorsports!!!
Check my build: http://honda-tech.com/showthread.php?t=3031606
Have sold to: Greenitr2009, metalslug, optaire, 96GreenDB
speedjunkie_g35 is offline   Reply With Quote
Old 02-08-2012, 06:57 AM   #24
949
I HOPE THIS HELPS
K24A1
* Found in:
+ Redline: 6500 rpm
K24A2
* Found in:
+ Redline: 7100 rpm
K24A3
* Found in:
+ Redline: 7000 rpm
K24A4
* Found in:
+ Redline: 6500 rpm
K24A8
* Found in:
+ Redline: 6500 rpm
K24Z1
* Found in:
+ Redline: 6500 rpm
so what is popular now a days?
and why?
949 is offline   Reply With Quote
a2, block, compression, differences, head, honda, horsepower, k20, k20a, k24a1, k24a2, k24a4, k24a8, redline, vs
