Car Making Whining Noise
Old 10-20-2005, 03:44 AM
misskita's Avatar
Default Car Making Whining Noise
I have a 2000 Honda Accord SE and the car makes a whining noise whenever the heat or a/c is on. It also does it when the fan speeds are on 1-2-3-4. I also noticed that it makes the same noise when ever the defrost is used. I posted earlier to see if any one could help me with this, but I failed to mention the year and model.
I also had an air compressor put on but it isn't blowing very cool air. Does any one know what this could be? Miss Kita
Old 10-20-2005, 05:49 AM
P_Adams's Avatar
Default Re: Car Making Whining Noise (misskita)
Two questions I need answered so's I can help
1) Does this whine occure with both the A/C on/off ?
2) Is this noise more under the Hood, or on the right side of the dash.?
P
Old 10-20-2005, 07:23 AM
I'm a Jackass
CB5F22A1's Avatar
Default Re: Car Making Whining Noise (P_Adams)
its ure sick stock turbo spooling
Old 10-31-2005, 08:06 AM
misskita's Avatar
Default Re: Car wouldn't start
I drive a 2000 Honda Accord SE. This morning I couln't get my car to crank and I had to use a boost to get it started. I know the car was making a whining noise whenever I turned on the fan speeds for the airconditioner. Could this be the alternator or the battery? I did not have this problem until this morning. Could it be the alternator belt ? If some one knows or has suggestions please help?
Old 10-31-2005, 05:57 PM
markski037's Avatar
this could be ur alternator, when i hooked up my system in my previous car 95 bmw i got the worst whining sound from the alternator, every time i would turn on the stereo it would do that
Old 10-31-2005, 06:40 PM
P_Adams's Avatar
Default Re: Car wouldn't start (misskita)
If it cranked with a boost, and kept running when the cables were removed, you most likely have a bad battery.
The whining could be the Alternator working hard, trying to make something of the bogus Battery. The same could apply to when you asked it to work hard by turning on the A/C Fan etc. Althought that system can cause it's own whine as well....
You would do well to have both checked. The bad battery could well have damaged the alternator electrically.
P
I'd also check the trunk for your mother-in-law, they whine often and with the fold down seat they can get pretty loud
Cstanis
Honda Accord (2013 - 2015)
03-12-2019 02:12 PM
ashleymarie90
10
09-23-2015 06:49 PM
ashleymarie90
09-22-2015 08:42 AM
skhell
01-30-2008 12:19 AM
Quick Reply: Car Making Whining Noise
