The monthly h22 MAHLE pistons thread..
Old 10-21-2005, 07:25 AM
  #26
2point2's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">tyler... did the rods fit in your pistons? we had to grind about 0.050 off each side of the small end of the rod for it to fit the piston.</TD></TR></TABLE>
Isn't .100 quite a bit of material to be taking off of a rods small end?
Old 10-21-2005, 08:54 AM
  #27
JDogg's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't .100 quite a bit of material to be taking off of a rods small end? </TD></TR></TABLE>
guess not... we made good power... ~220hp with a ebay header and a stock head with bent valves.
Old 10-21-2005, 08:56 AM
  #28
quickchris's Avatar
Hey guys,I have been using the pistons with Eagle ESP rods with no issues at all.I have logged 7k miles on the engine already.Im running 10lbs of boost,I did no machine work at all.Cleaned the cylinder walls with a shop rag and brake cleaner,used the supplied rings,and put all new brown rod bearings in from Honda.I was going to make a thread,but been way to busy at work....sorry
  #29
D0GMAN's Avatar
Default Re: (quickchris)
yeah those pistons fit like ****.....
we had problems and basically they are useless paperweights
Old 10-21-2005, 09:09 AM
  #30
quickchris's Avatar
Default Re: (D0GMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D0GMAN &raquo;</TD></TR><TR><TD CLASS="quote">yeah those pistons fit like ****.....
we had problems and basically they are useless paperweights</TD></TR></TABLE>
care to elaborate? They fit like ****, what they don't fit in the box well, you put them in backwards and they don't fit cuz the valve reliefs were "wrong", what?...
Old 10-21-2005, 09:39 AM
  #31
JDogg's Avatar
you guys are funny... those pistons bent the exhaust valves, putting pistons in backwards dosnt bend the exhaust valves also.. fit like **** could also have to do with the rod pocket being too narrow, hell the pins didnt fit the rods well at all, we had to hone out the small end of the rod so the pin would fit. what else... the supplied rings wouldnt fit in the pistons, we had to use the the rings that came out of the motor ... (yeah we reused 80k mile rings).
tyler... im almost suprised you are making that much power w/o problems, when we asked about some low comp pistons, they told me that these things werent good for anymore than 125hp per piston.
Old 10-21-2005, 01:20 PM
  #32
BlueLude94's Avatar
Default Re: (JDogg)
Just wondering if there has been any experiences with the Wiseco "FRM compatible" pistons.
Old 10-21-2005, 01:21 PM
  #33
b18bturbo's Avatar
Default Re: (BlueLude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if there has been any experiences with the Wiseco "FRM compatible" pistons.</TD></TR></TABLE>
whend did wiseco ptu a frm piston out on the market i havent seen it yet you got any details on it
Old 10-21-2005, 04:40 PM
  #34
Jason kiDD's Avatar
Default Re: (b18bturbo)
Interesting..
Old 10-21-2005, 06:00 PM
  #35
EsQueue's Avatar
Default Re: (93preludes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludes &raquo;</TD></TR><TR><TD CLASS="quote">
I've got this setup, liners arent monster sized like the primo aftermarket sleeves but it's closed deck so I figure it will hold up. iron liners </TD></TR></TABLE>
How much did it cost for you go get this done to your block?
Old 10-22-2005, 10:53 AM
  #36
92 CIVIC HATCH VX's Avatar
Default Re: (SeaQuake)
yes i'm going to call wesico monday to see what new fmr piston they have.
keep me informed
Old 10-22-2005, 03:42 PM
  #37
Under_Pressure's Avatar
Default Re: (92 CIVIC HATCH VX)
i would like to know how much boost can those mahle pistons hold? I got a stock bottom end on 7 pounds right now. But i would like 18
Old 10-22-2005, 09:57 PM
  #38
Default Re: (92h22alude)
i would think the rods would be a big part in holding boost... so if you upgrade to eagle or to a rod the fit the stock piston and the right air fuel i couldn't see why not running 18lbs compression might be come a issue???? i know the temp should raise also but it will depend on how much the stock pistons can hold temp wise.
Old 10-22-2005, 10:13 PM
  #39
Blind-Fashion's Avatar
I just tuned a good friends car to 19-20 psi and he made 360 with a 2 inch downpipe. BONE STOCK H22 LONGBLOCK.... Using an apexi power fc, showing zero knock
Old 10-23-2005, 06:16 AM
  #40
bubs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">i would think the rods would be a big part in holding boost... so if you upgrade to eagle or to a rod the fit the stock piston and the right air fuel i couldn't see why not running 18lbs compression might be come a issue???? i know the temp should raise also but it will depend on how much the stock pistons can hold temp wise. </TD></TR></TABLE>
It's not the rods that are weak from the factory, it's the pistons. The ringlands are really weak and crack easily under high power levels.
Old 10-23-2005, 06:17 AM
  #41
bubs's Avatar
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">I just tuned a good friends car to 19-20 psi and he made 360 with a 2 inch downpipe. BONE STOCK H22 LONGBLOCK.... Using an apexi power fc, showing zero knock </TD></TR></TABLE>
Let us know if it makes it through the weekend
Old 10-23-2005, 10:11 AM
  #42
Default Re: (bubs)
so do the ring lands just brake off and you lose compression?
Old 10-23-2005, 10:34 AM
  #43
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">so do the ring lands just brake off and you lose compression?</TD></TR></TABLE>
yep
Old 10-23-2005, 12:19 PM
  #44
Default Re: (bubs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubs &raquo;</TD></TR><TR><TD CLASS="quote">
Let us know if it makes it through the weekend </TD></TR></TABLE>
he was running 16 psi with 19 psi spikes for 3 1/2 months beating the living **** out of it. its all in the tune.
Old 10-23-2005, 04:29 PM
  #45
bubs's Avatar
he was running 16 psi with 19 psi spikes for 3 1/2 months beating the living **** out of it. its all in the tune. </TD></TR></TABLE>
That's pretty crazy! He must of got a wednesday car or something to be able run that much boost with stock internals
Old 10-24-2005, 12:08 AM
  #46
h22's are strong strong motors, they just wont take detonation nicely.
Old 10-24-2005, 10:36 AM
  #47
turboH22Aakkord's Avatar
Default Re: (bubs)
amen
Old 10-26-2005, 02:03 AM
  #48
Tyler H's Avatar
Default Re: (JDogg)
No modification was necessary. The guy I spoke to was aware of the HT posts documenting the problems with the pistons. They told me those were old pieces that were designed off of a piston that they thought was stock, but was not. They told me they had fixed those problems already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92h22alude &raquo;</TD></TR><TR><TD CLASS="quote">i would like to know how much boost can those mahle pistons hold? I got a stock bottom end on 7 pounds right now. But i would like 18 </TD></TR></TABLE>
I've run 30 psi, so far..... Ran 10.38 @ 144 mph last weekend in Pomona. My best mph ever. You guys wouldn't believe me if I told you what was in this motor.
Tyler
Old 10-26-2005, 03:34 AM
  #49
bubs's Avatar
Default Re: (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">
Tyler</TD></TR></TABLE>
Please, do tell..
Old 10-26-2005, 05:03 AM
  #50
JDogg's Avatar
Default Re: (bubs)
mahle's and eagles?? lol.. eagles are going in my turbo h22
Quick Reply: The monthly h22 MAHLE pistons thread..
