how to remove my hubcaps, 2000 4 dr LX accord
Old 10-12-2005, 11:19 AM
blackriceman's Avatar
Default how to remove my hubcaps, 2000 4 dr LX accord
how do i remove my hubcaps, i tried to just pull them off but they are stuck under the lug nuts. is it possible t o remove them without takeing the nuts off?
Old 10-12-2005, 11:40 AM
SpankyG's Avatar
Default Re: how to remove my hubcaps, 2000 4 dr LX accord (johneyou)
it might be possible to take them off without removing all of your lugnuts, but it is not possible to take them off, without breaking them, unless you remove all or some of your lugnuts. Look at the lugnuts, there is a possibility that only 2 of them will have black washers connected to the lugnut, this is what holds the hubcap on. You only need to take the lugnuts off that have this washer on them to get the hubcap off. It isn't that difficult to remove the lugnuts, when you put the lugnuts back on you should torque them to 80 ft. lbs.
Old 10-12-2005, 12:33 PM
Elvis1977's Avatar
Default Re: how to remove my hubcaps, 2000 4 dr LX accord (SpankyG)
You must remove lug nuts to get wheel cover off.
Old 10-12-2005, 01:03 PM
93CX's Avatar
Default Re: how to remove my hubcaps, 2000 4 dr LX accord (Elvis1977)
Impressive.. worst thread ever
Old 10-12-2005, 01:19 PM
Banned
94accordsedan's Avatar
Default Re: how to remove my hubcaps, 2000 4 dr LX accord (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">Impressive.. worst thread ever </TD></TR></TABLE>
Not all of us know everything about cars, so take it easy.
Old 10-12-2005, 01:29 PM
Papoose's Avatar
this is not the worst thread ever.... sometimes people just have never tried something and are afraid that if they do try it, they'll expletive up.
better know before-hand than after, right? can't be hard on someone who asks for help.
Old 10-12-2005, 02:57 PM
YeuEmMaiMai's Avatar
loosesn lugs while on the ground
jack car up and remove lugs and remove wheel cover
reinstall lugs and tighten enough to ensure wheel is all the way on
lower car
torque lugs to spec
repeat for other 3 wheels
Old 10-12-2005, 05:32 PM
accrd18's Avatar
Default Re: (YeuEmMaiMai)
the only stupid questions are the ones that arent asked. weve all been there at one point or another.
Old 10-12-2005, 05:42 PM
zidek's Avatar
it should be that 2 out of the 4 (or 5) lugs have a rubber ring around it. thats actually what holds the hubcap on. if you find those you don't need to jack the car up.
Old 10-12-2005, 05:55 PM
accrd18's Avatar
Default Re: (zidek)
they all have rubber rings around the nuts. least on mine they do not sure about the 00.
Old 10-12-2005, 07:46 PM
Heat's Avatar
Default Re: (drivinaway367)
On my '99 LX, which I assume is the same as the '00 LX, you have to remove the four lugnuts. Jack up that part of the car and just take off the lugnuts.
By the way, if it scratched up, faded, or whatever, a new hubcap is only ~ $15 or $17. If they are beat up a little, you only need to replace two at a time (on the same side of the car) which will make the car look much better; I've done this before.
Old 10-12-2005, 08:35 PM
iLUVmyACCORD's Avatar
omg my roommate and i had the same problem with taking the hub caps off.. haha.. we tried pulling that crap off but all it did was warp the hub cap.. then we realized we had to take off lug nuts.. wat a pain in the ***
Old 10-12-2005, 09:20 PM
iam7head's Avatar
Default Re: (Negronese)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Negronese &raquo;</TD></TR><TR><TD CLASS="quote">omg my roommate and i had the same problem with taking the hub caps off.. haha.. we tried pulling that crap off but all it did was warp the hub cap.. then we realized we had to take off lug nuts.. wat a pain in the ***</TD></TR></TABLE>
ar..yes and no..those lugsnutskeep those poor hub from flying all over the road, hey i do ANYTHING to keep my bling bling 14 inch plastic spinner.
if you don't like those, just swap in some old lugnuts.
Old 10-13-2005, 08:42 AM
accrd18's Avatar
Default Re: (iam7head)
they r held on by lugs so they dont fly off when u hit a pothole or something. revealing steelies
thekid_12
03-25-2008 03:31 AM
AccordGreen
06-05-2007 07:01 PM
DB1_559
07-21-2006 01:49 PM
mars
05-07-2005 08:05 AM
ITACivic
11
04-14-2003 04:41 PM
Quick Reply: how to remove my hubcaps, 2000 4 dr LX accord
