Old 10-12-2005, 11:07 AM   #1
AnAccordIsForever
2013 Honda Accord
My Garage
AnAccordIsForever's Avatar
Default Radiator fan switch test and replace
This is about the radiator fan switch located right beside the thermostat ('99 4-cyl). I think mine's not working because the fans dont come on when the engine gets hot, which they used to before. I unplugged the connector on the switch and shorted the contacts, the fans came on so nothing else in the circuit is wrong.
I believe the temperature rating for the switch is 196-203F.
Are there any aftermarket switches that close (switch on) at a lower temperature
like 170 or 160F ?
2013 Accord Touring V6
2001 MDX
AnAccordIsForever is offline   Reply With Quote
Old 10-12-2005, 11:40 AM   #2
Elvis1977
Elvis1977's Avatar
Default Re: Radiator fan switch test and replace (AnAccordIsForever)
Use honda factory switch. I have a 98 lx 4-cly with 140k and still original switch working perfectly. Why has your gone bad?
Elvis1977 is offline   Reply With Quote
Old 10-12-2005, 11:45 AM   #3
AnAccordIsForever
2013 Honda Accord
My Garage
Default Re: Radiator fan switch test and replace (Elvis1977)
I have no clue why it would go bad, out of all the things that could go bad by 77k miles. I tried checking resistance also, cold is open but engine hot still doesnt show some resistance.
After how long the engine has been running typically does the coolant temp reach 190-200F ? I remember only once when I left it idle for a while (>5mins), the fans kicked in but went off in a matter of 3 or 4 seconds.
2001 MDX
Old 10-12-2005, 11:51 AM   #4
Elvis1977
Elvis1977's Avatar
On a hot day, they will kick on about 10 minutes of idling. On a cold day, probably longer. What does the temperature gauge say? Does the needle point in the red?
Old 10-12-2005, 12:14 PM   #5
AnAccordIsForever
2013 Honda Accord
My Garage
Temp gauge is showing fine - a little under halfway mark between C and H - which leads me to believe that the thermostat is working fine and the coolant is flowing as it should.
2001 MDX
Old 10-12-2005, 12:19 PM   #6
Elvis1977
Elvis1977's Avatar
The switch is probably ok also. Nothing to worry about.
Old 10-12-2005, 12:20 PM   #7
JimBlake
JimBlake's Avatar
That isn't supposed to switch the fan on until the temperature gets hotter. Usually a little above 1/2 on the gauge.
It's just an SPST switch. It's supposed to measure open circuit until it switches ON. It's not a variable-resistance type of sensor. You can test it by putting it in a pot of water with a thermometer.
This time of year (in MN) you'll probably have a hard time getting your engine hot enough to switch it on.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
2001, 93, accord, bad, change, fan, honda, hondatech, makes, radiator, resistance, switch, tech, test, testing
