Do anyone know where the fuel filter is on a 98 accord 2.3?
Old 10-06-2005, 01:51 AM
KDoGx504's Avatar
Default Do anyone know where the fuel filter is on a 98 accord 2.3?
I am thinking of replacing my fuel filter and pcv valve because my car is getting really bad gas mileage, and I think its about time to replace them. I heard from somewhere that the fuel filter is in the gas tank, is that true? Is this a DIY? Can someone please help me? Pics would be a plus. Thanks
Old 10-06-2005, 04:58 AM
notoriousB's Avatar
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (Charri)
there is no engine bay fuel filter on a 98-02 accord.
the only filter is in the tank, it's the screen on the pump, and it does not need to be changed.
Old 10-06-2005, 05:08 AM
Former Sponsor
-Bionic-'s Avatar
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">there is no engine bay fuel filter on a 98-02 accord.
the only filter is in the tank, it's the screen on the pump, and it does not need to be changed.</TD></TR></TABLE>
This is correct.
Old 10-06-2005, 06:12 AM
deserthonda's Avatar
yo charri you are thinking of the 94-97 accords..........98 is in the tank .
Old 10-06-2005, 10:40 AM
KDoGx504's Avatar
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (KDoGx504)
So what is the best way to clean my fuel system then since you fuel filter is non-replaceable? Do I just pour in the fuel system cleaner into the gas tank?
Old 10-06-2005, 12:12 PM
notoriousB's Avatar
what are you trying to clean? run some gumout or the like thru it if you think it needs it.
Old 10-06-2005, 02:21 PM
Chiovnidca's Avatar
the only filter is in the tank, it's the screen on the pump, </TD></TR></TABLE>
There's a pickup screen and also in the top of the pump housing itself is is the filter. It doesn't need to be changed unless it clogged up.
HondaTechPro's Avatar
Previous posts are correct, the 98's started the trend of non replaceable fuel filters. They are in the tank. The previous gen was located under the master area, as previously stated.
Old 10-06-2005, 02:23 PM
Chiovnidca's Avatar
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (HondaTechPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechPro &raquo;</TD></TR><TR><TD CLASS="quote">Previous posts are correct, the 98's started the trend of non replaceable fuel filters. </TD></TR></TABLE>
It replaceable, just a little tougher to do so. (and more expensive)
Old 10-06-2005, 02:43 PM
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (Chiovnidca)
By replaceable i meant durring "regular service" Of course you can replace almost any part, but it's not designed to be replaced like the older models...
Old 10-06-2005, 02:45 PM
iam7head's Avatar
The only filter is in the trunk/tank, there's no filter in the engine bay.
The filter in the tank is a plastic mesh that would only filter out sands, which is pretty useless. they are replaceable and snap right on.
I would just take it out and wash it with gas.
Old 10-06-2005, 03:28 PM
Chiovnidca's Avatar
Default Re: Do anyone know where the fuel filter is on a 98 accord 2.3? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
The main pump housing has an integrated filter in it. More than just the sock.
Old 10-06-2005, 05:27 PM
KDoGx504's Avatar
http://www.hondaautomotivepart...+PIPE
Here is a diagram of the fuel line, I was wondering do anyone know what is that filter #9 on the diagram?
Old 10-06-2005, 05:36 PM
KDoGx504's Avatar
http://www.hondaautomotivepart...+TANK
Here is one that shows a filter set for the tank. Is it a good idea to replace this one, if so, how hard would it be to replace? Thanks
Old 10-06-2005, 06:44 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KDoGx504 &raquo;</TD></TR><TR><TD CLASS="quote"> Is it a good idea to replace this one, </TD></TR></TABLE>
It doesnt need to be replaced unless it's causing a problem. It should be good for the life of the car.
Old 09-06-2016, 05:30 PM
Lacy's Avatar
Default my Honda
My Honda Accord is a 1998 2.3lt and the fuel filter is not in the engine bay or fuel tank it is situated under the car just In front of the back left wheel, it is by itself.
Old 09-07-2016, 12:29 PM
MM Gruppe B
MAD_MIKE's Avatar
There is the charcoal canister filter, but that is for the main charcoal canister/EVAP system. #9 in the first image. It is not a fuel filter, it may have fuel in it if the EVAP system has flooded but it is not the fuel filter
In the second image, if you follow the fuel lines, one small one goes to the canister, the other two are the feed/return lines that are connected via two quick disconnects, and those two lines continue up to the tank.From my understanding the actual fuel filter is part of the pickup assembly(#1) in the tank and is not a readily replaceable unit.
1999accord
04-06-2022 05:12 AM
ferreiae
11-13-2018 03:33 PM
creator1322
08-31-2008 01:34 AM
tshih
01-22-2006 07:23 PM
DIY_Racing
05-13-2004 06:16 PM
Quick Reply: Do anyone know where the fuel filter is on a 98 accord 2.3?
