How to replace clock light in a 2002 Accord
Old 09-21-2005, 08:40 PM
jdmspoonitr's Avatar
Default How to replace clock light in a 2002 Accord
Well it happened to two of my accords. I didnt want to bother going to the dealer to find out. I spend most of my time working on Integras so I'm unsure how to replace the bulb and remove the whole center console vent area with the clock. I'm assuming I have to unhook some wire and pop off the buttons just like the integra.
If anyone has a how-to or some tips that would be great because seeing as this happened fairly soon after I got both cars, I would have to assume that it happened to a lot of you guys too. Thanks
Old 09-22-2005, 06:12 AM
AFAccord's Avatar
Default Re: How to replace clock light in a 2002 Accord (jdmspoonitr)
It's a relatively simple process, and the 6th gen accords are notorious for this bulb blowing out. I don't have pictures but I will give you a general process for replacing this. You WILL NOT have to remove the climate control panel, just the clock assembly itself.
1. Use a small flat-blade screw-driver to pry the clock/hazard button assembly out of the dash panel. Wrap the screw-driver in a papertowel, tape, or a cloth to avoid scratching the plastic. This usually works best if you pry from one side then the other.
2. There is a vertical connector for the hazard switch, and a horizontal connector for the clock. Disconnect both of these and remove the clock assembly.
3. I believe there is a plastic cover on the back of this assembly. Remove it using a phillips head screw-driver. There you will see the back of the plastic bulb holder.
4. Twist the bulb holder out of the socket and replace the bulb and holder with a new one purchased from a Honda dealership.
5. Installation is the reverse of removal.
I believe this bulb runs $1.47 from the dealer, which is way too much IMO. You could buy an LED bulb conversion from http://www.ledautomotive.com/ if this becomes a continuous problem.
Old 03-20-2011, 01:58 PM
qwerty1946's Avatar
Icon2 Re: How to replace clock light in a 2002 Accord
We have a similar problem on a 2002 Accord - took the light out tested on a 9 volt battery - the light works fine!! Is there a connection inside the clock cluster that can be loose?
Old 03-20-2011, 02:04 PM
nus_dogg's Avatar
God damn, thanks alot for reviving a six years old thread. I'm pretty sure the OP took care of the problem already.
somgop
05-14-2016 07:11 AM
uberEFtuner
02-18-2014 08:26 AM
bub0440
06-17-2006 04:21 PM
DOHC-ter AMIEL
02-26-2005 01:57 PM
B2FiNiTY
05-13-2003 07:44 PM
Quick Reply: How to replace clock light in a 2002 Accord
