Output for tach on ecu of B18c?
Old 09-19-2005, 11:23 PM
apexinghonda's Avatar
Default Output for tach on ecu of B18c?
I searched. Didn't find it. I don't trust any other section on Honda-tech for "technical advice". Trying to put in a autometer big tach. Where do you get your signal? I am assuming the ECU which is what I did with my supra for a shift light. Any help appreciated.
B18c in a CRX Si chassis.
Barry H.
Old 09-20-2005, 03:32 AM
.RJ
.RJ's Avatar
Default Re: Output for tach on ecu of B18c? (apexinghonda)
Is it an OBD1 Engine/ECU? I *belive* the signal is off the distributor.
I have a helms on .pdf that I can send you - drop me an email, rpjenkins@gmail.com
Old 09-20-2005, 10:22 AM
Default Re: Output for tach on ecu of B18c? (.RJ)
Hey R.J. according to the previous owner the car has a OBD1 Ecu. I also have Hondata (unknown model number) I looked on it to see what outputs it had and "rpm" was not one of them. Any help appreciated. Trying to mount one of those monster tach so that I quit shifting based on how long the tach needle has been pegged at 8,000revs and stopped before I shift.
Barry H.
Old 09-20-2005, 10:25 AM
.RJ
.RJ's Avatar
Drop me an email and I can send you or host a copy of the helms for you.
Old 09-20-2005, 10:53 AM
STN_Pat's Avatar
Is it the same signal as for a shift light ? Got mine from behind the cluster, it's the only green wire !
Old 09-20-2005, 10:57 AM
slammed_93_hatch's Avatar
Default Re: Output for tach on ecu of B18c? (STN_Pat)
for 92-95 civic's i have always heard it is the blue wire attached to nothing in the engine bay in the drivers side right next to the fire wall.
I have seen 2 or 3 tachs hooked up here and they worked
Old 09-20-2005, 11:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Drop me an email and I can send you or host a copy of the helms for you.</TD></TR></TABLE>
Done and thanks. Blue wire, green wire, hell I will cut them all. I think I have another Hondata "box" right under the hood on the driver's side. My car has one of those Kenji wiring harnesses so which wire is which may be a bitch. I am a poet and don't know it.
Barry H.
Old 09-20-2005, 11:17 AM
.RJ
.RJ's Avatar
You got mail
Old 09-20-2005, 05:39 PM
Mohudsolo's Avatar
On my 94 GSR there is a blue wire on the firewall area near the master cylinder that is a tach signal. I never looked to see what the one is to the guage cluster since that was so easy to get to and use.
JBLAZE622
11-14-2008 07:50 AM
young geezer
07-16-2007 06:46 AM
apexinghonda
10-27-2005 03:26 PM
IS3Fifty
05-14-2004 10:20 PM
TRuST
05-07-2002 11:24 AM
Quick Reply: Output for tach on ecu of B18c?
