Old 09-16-2005, 10:32 AM   #1
frank_O
frank_O's Avatar
Default where data link connector(DLC) is located for 96 honda accord and what terminals to connect
to obtain the trouble codes. need to find out if i'm getting any ecm or crank position sensor codes. 96 honda accord lx 2.2 non-vtec
frank_O is offline   Reply With Quote
Old 09-16-2005, 11:26 AM   #2
Charri
Charri's Avatar
Send a message via AIM to Charri
Default Re: where data link connector(DLC) is located for 96 honda accord and what terminals to connect (fra
I believe youre talking about the OBDII connector pin? If so, all you have to do is pull out the ash tray and you'll see the connecting harness. Insert reader and you'll get your cold
'97 Accord SE F22B2 AT
Neuspeed Sports
Tanabe F Sways 30.4
Russell SS lines
Ebay Strut Bars F&R
Charri is offline   Reply With Quote
Old 09-16-2005, 01:32 PM   #3
Chiovnidca
Chiovnidca's Avatar
The DLC for an obd2 scantool is behind the ashtray. But there is a service check connector below the glovebox to pull the codes manually.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
2000, 2005, 96, 97, accord, connect, connector, data, dlc, honda, link, located, location, obd2, obdii
