Old 09-10-2005, 06:37 PM   #1
Linh.
Linh.'s Avatar
Default car shuts off when turning steering wheel
I have this problem when i slighty turn the steering wheel the car completely shuts off. The only thing i can do is go straight forward/backwards. I tried changing the power steering belt but that wasn't it.
R & D Motorsports
Linh. is offline   Reply With Quote
Old 09-10-2005, 06:51 PM   #2
hondapwr
hondapwr's Avatar
Default Re: car shuts off when turning steering wheel (shooitslinh)
Try pushing the brake pedal and turning on the AC. Does the car shut off when you do that too? If so, you might have a bad ELD. Check your voltage at the battery too.
Ask any racer, any REAL racer... it doesnt matter whether you win by an inch, a centimeter, a millimeter, a mile, a picometer, a decimeter, a parking meter, a bird feeder - Uhh Turreto WTF are you talking about?
hondapwr is offline   Reply With Quote
Old 09-10-2005, 07:22 PM   #3
Linh.
Linh.'s Avatar
Default Re: car shuts off when turning steering wheel (hondapwr)
no the ac works perfectly fine and the battery is brand new
R & D Motorsports
Old 09-10-2005, 07:38 PM   #4
boosted civic 2k6
has to do nothing w/ ur powersteeing cuz unless ur pulley and belt is froze up somehow that it causes the crank to freeze up along with it...the engine shouldnt cut off. really if you think about it has NOTHING TO DO WITH POWER STEERING lol. because powersteering drives the pump and a bad pump does not cause an engine to cut off. what im thinking is you have some loose wires inside your steering column or maybe when someone didnt install your ingition righ or its worn out watever.
can you be a little more descriptive? does the car JERK DIE. or does it just shut off like you just turned off the key. does your radio still work after that? im thinking it has something to do with your ignition and somehow when you turn the wheel its moving wires along with it? lol. someone help this guy out. good luck man
boosted civic 2k6 is offline   Reply With Quote
Old 09-10-2005, 07:42 PM   #5
skunk2finatic
skunk2finatic's Avatar
Send a message via AIM to skunk2finatic
check your ignition switch....I bet your either pullin a wire when you turn it or your grounding out or something..
skunk2finatic is offline   Reply With Quote
Old 09-10-2005, 07:52 PM   #6
SL!M
SL!M's Avatar
It has nothing to do with your belts, its an electrical short in the steering column and is causing the car to cut-off. Other than that I have no idea. You might want to take that to a mechanic.
SL!M is offline   Reply With Quote
Old 09-11-2005, 08:23 AM   #7
Linh.
Linh.'s Avatar
Default Re: (SL!M)
Nope the radio doesnt not work. When your turn the car on it idles at around 500-800 and jumps up and down like the car is about to die out. But if you step on the gas it starts to idle at 1k rpm. When you turn the steering wheel the car shakes and dies out. Another thing is that it seems like the cat is clogged because when you step on the gas the whole exhaust system starts to shake
R & D Motorsports
Old 09-11-2005, 08:48 AM   #8
SiR:Mallard
SiR:Mallard's Avatar
Default Re: car shuts off when turning steering wheel (skunk2finatic)
Agree. You probably wrapped a wire harness around the steering shaft and have sucessfully worn through the wire insulation. The other likely cause could be your ignition harness plugs are loose at the base of the ignition. Pop the bottom cover off your column and check the 3 white harness plugs. Not sure what model care you have, but you may only have two. Once on each side of the steering shaft.
SiR:Mallard is offline   Reply With Quote
Old 09-11-2005, 09:19 AM   #9
EJ8VTEC
Mr. Indecisive
2004 Acura TSX
EJ8VTEC's Avatar
Default Re: (shooitslinh)
Check your grounds n every thing else said prior
edith that was said too
DD: 04 NBP CL9 6MT/Navi | Sold: 00 CGP EJ8
Go Lakers! Go Packers! PSN: LugNutZ-
EJ8VTEC is offline   Reply With Quote
Old 09-11-2005, 11:38 AM   #10
Linh.
Linh.'s Avatar
Default Re: (EJ8VTEC)
ill try and check that
R & D Motorsports
Old 09-11-2005, 12:02 PM   #11
jdm y0
Send a message via AIM to jdm y0
LOL sorry that sucks. best of luck 2 you fixing that
Garagerz
Rhino Custom Detailing
Showstoppers USA
jdm y0 is offline   Reply With Quote
Old 09-11-2005, 01:17 PM   #12
hondapwr
hondapwr's Avatar
Why not disconnect the exhaust from the header back to rule out the clogged cat theory? Also wouldn't hurt to check your pulleys to make sure they're not siezed.
Old 09-14-2005, 10:15 AM   #13
Linh.
Linh.'s Avatar
Default Re: (hondapwr)
i dont think its an electrical shortage because if you step on the gas you can turn the steering wheel im thinking that its the idle speed control valve
R & D Motorsports
Old 04-14-2011, 06:22 AM   #14
dreamer2414
Seriously it takes a female to figure this out, its none of the above listings except in rare circumstances that something else lead it to do that issue. If I were you I would look into you fuel injector as this has alot to do with a car shutting off when you turn the wheel, especially if you feel the car kinda making a bouncy feeling. I would look into all your fuel areas of your car to find out if its the injector or something else along the lines of the fuel process. Also check into your vacuum system as this sometimes can affect your car in this manner also. Hope this helps.
dreamer2414 is offline   Reply With Quote
Old 04-14-2011, 07:52 AM   #15
biggdogg
biggdogg's Avatar
Send a message via AIM to biggdogg
take the ps belt off. if it doesnt do it then you have a ps pump intermittently locking up and killing the engine. happened on a customers car replaced pump and went away.
qoute from NOFX,
Idle hands are the ricer's playground.
biggdogg is offline   Reply With Quote
Old 04-14-2011, 08:56 AM   #16
thecruzs2007@yahoo.com
thecruzs2007@yahoo.com's Avatar
x2
thecruzs2007@yahoo.com is offline   Reply With Quote
Old 04-14-2011, 10:54 AM   #17
Linh.
Linh.'s Avatar
This thread is from 05
R & D Motorsports
Old 04-14-2011, 03:54 PM   #18
TwoFaced
2000 Honda Civic
TwoFaced's Avatar
Lol. fail.
Originally Posted by the comanche View Post
Let's see some dicks!
TwoFaced is offline   Reply With Quote
Old 04-15-2011, 02:36 AM   #19
mooze
mooze's Avatar
Send a message via Yahoo to mooze Send a message via Skype™ to mooze
super
h23avtec with a/c.
mooze is offline   Reply With Quote
car, column, cut, cuts, grounding, loose, push, shuts, steering, turn, turned, turning, turns, tutn, wheel
