Old 03-25-2015, 09:48 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Official: Post Your Valve Cover (56k warning)
Old 07-21-2009, 09:16 AM
  #7801
khmers0uljah's Avatar
Location: I'm always painting & polishing shiet, California
Default Re: Official: Post Your Valve Cover (56k warning)
Do you guys just use whatever kinds of paint on the valve covers? Will the paint mess up due to the high heat of the motor?
Old 07-21-2009, 09:28 AM
  #7802
robbys89's Avatar
you gota use high temp paint, a friend of mine used normal paint and it flaked off after a week or two, plenty of high temp paints out their all sorts of colours
Old 07-21-2009, 09:35 AM
  #7803
OddityDX's Avatar
I just used reg paint on mine and its lasted for over 2 years. Just prep it will.
Old 07-21-2009, 09:38 AM
  #7804
HiEn84's Avatar
Use VHT paint. They have many selections on high temp colors
Old 07-21-2009, 10:03 AM
  #7805
Hmm.. I wanted to use this thats why. It says heat resistance..
Old 07-21-2009, 01:49 PM
  #7806
dreamreaperx's Avatar
you don't have to use high heat paint or high heat primer....i've done it with vht wrinkle right onto bare metal...also used base coat / clear coat on bare metal..i just made sure to properly sand everything and clean it well....any type of paint will hold onto the valve cover just fine....here are a couple i did
Old 07-21-2009, 06:37 PM
  #7807
^ Alright, thanks bro, nice valve covers btw. Whaddup with the grass lol.
Old 07-21-2009, 07:04 PM
  #7808
pinoy.solsi's Avatar
i have a question.
when you paint your Valve Cover would u have to cover the engine, so no dirt gets it,
and would i have to replace the gasket?
Old 07-21-2009, 08:38 PM
  #7809
lunalink's Avatar
it all depends on you, if you want to take the extra step and cover it up and replace the gasket..the extra step isnt going to kill you..i personally replaced the gasket and i covered the motor..but its not a must..
Old 07-21-2009, 08:45 PM
  #7810
Radim's Avatar
i just mock up an extra valvecover while i paint the other valvecover.
You can reuse the gasket atleast once, but after that replace it for sure.
Old 07-21-2009, 09:16 PM
  #7811
i put it on the grass to change valve covers and a piece landed on it...it's not stuck just sitting there
Old 07-21-2009, 09:31 PM
  #7812
lunalink's Avatar
u should put more grass and lay down a coat of clear
Old 07-22-2009, 05:44 PM
  #7813
eazybmx's Avatar
i used the purple one with regular duplicolor primer and clearcoat, its lasted 3 months so far. it didnt come out the color on the can even after a bajillion coats, in the sun its violet and in the shade its a pinkish-purple:
Old 07-22-2009, 06:39 PM
  #7814
TunerN00b's Avatar
Metalcast is supposed to be used over bare metal, or their special primer (that I believe is aluminum colored). Its a partially transparent paint, which is why it came out different for you, your primer is showing through.
Old 07-22-2009, 06:55 PM
  #7815
.hawaii's Avatar
Originally Posted by EKsos_57
DAMN...there's some dope ones on here!
here's a couple pics of mines done a while back...
ANGRY WOEBOTS FTW!
damn, you got woebot to paint your valve cover? lucky...
Old 07-22-2009, 09:27 PM
  #7816
icedstar's Avatar
here's mine
Old 07-22-2009, 09:43 PM
  #7817
thnx
Old 07-22-2009, 10:10 PM
  #7818
lunalink's Avatar
Originally Posted by pinoy.solsi
thnx
no problemo!
Old 07-22-2009, 10:37 PM
  #7819
flatblack-h22's Avatar
Originally Posted by dreamreaperx
i like, colour?
Old 07-23-2009, 06:45 AM
  #7820
it is black with gold pearl mixed into the black, then gold pearl mixed into the clear, with two coats of clear...
Old 07-23-2009, 11:14 AM
  #7821
dxcivicsi's Avatar
my first valve cover wrkin on another currently see what i come up with
Old 07-24-2009, 07:07 PM
  #7822
Boosted_90Teg's Avatar
First one I bothered to paint. Had a VTEC cover laying around, stripped it, and rattle canned it and cleared all in one sitting. Isn't perfect, but let me know what ya think.
Sorry about the bad Cell phone picture, will get a proper one tomorrow.
Old 07-24-2009, 07:35 PM
  #7823
^^ looks pretty good from that pic, but don't rush paint...patience makes a big difference in how your stuff comes out...i know when i used to paint, i was so excited to see how it was gonna look that i would rush to get it done...usually either dripping or messing it up somehow in the process...now that i take the proper amount of time, everything is coming out a lot nicer
Old 07-24-2009, 07:59 PM
  #7824
Well by "one sitting" I mean one day, lol. I let the etching primer sit for a good long time before I started spraying the white. Let that sit for about 4 hours till I masked around the letters and sanded them down, then I went over it with a tack cloth, then sprayed about one good layer of clear, and could use a bit more, haha.
Right now my main project is a fully shaved B18B/B20 cover. Filled the grooves with QuikSteel, used some Loctite liquid metal in some areas instead of normal filler, since it's good up to 250 degrees.
But that brings up another question, would a thin layer of Bondo hold up to the temps these go through?
Old 07-25-2009, 12:41 AM
  #7825
EJ6JON's Avatar
i have a question.
Dont paint the v/c on the car Take it off and paint it away from the car easiest way and when u take off the v/c cover the head with a clean rag
Quick Reply: Official: Post Your Valve Cover (56k warning)
