Can JB weld handle exhaust heat?
Old 09-01-2005, 06:21 PM
StrangerWitCandy's Avatar
Default Can JB weld handle exhaust heat?
im thinking about plugging up an open bolt hole on my DP with JB weld to stop the damn exhaust leak through it... but someone told me they didn't think it could handle the heat, if thats true, that means ive gotta take off the dp, weld the hole closed, and then re-surface the flange
Old 09-01-2005, 06:27 PM
non-VTEC's Avatar
Default Re: Can JB weld handle exhaust heat? (StrangerWitCandy)
JB weld is good up to about 600deg.........i think your pipe right at the turbo flange will get much hotter than that.........
Old 09-01-2005, 06:39 PM
RogueWorks's Avatar
Default Re: Can JB weld handle exhaust heat? (non-VTEC)
they do make a putty for exhausts that may hold you over until you can get it properly fixed.
Old 09-01-2005, 11:39 PM
no2unenolife's Avatar
it'll probly come off after awhile
Old 09-01-2005, 11:42 PM
Cray91's Avatar
put a bolt in it, if it is a bolt hole.
Old 09-02-2005, 01:19 AM
ophdehEEEzy's Avatar
It will not handle the heat. I didnt even handle the heat from the stock y8 manifold that had a crack in it.
Old 09-02-2005, 03:06 AM
at the jetties fishin'
stackz's Avatar
Default Re: Can JB weld handle exhaust heat? (OH ISH ITS DAT FOOL JAMES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH ISH ITS DAT FOOL JAMES &raquo;</TD></TR><TR><TD CLASS="quote">It will not handle the heat. I didnt even handle the heat from the stock y8 manifold that had a crack in it.</TD></TR></TABLE>
then you did something wrong.
had a friend who ran around for the better part of a year with nothing but jb weld holding his exhaust pipe to his exhaust manifold. I was helping him change spark plugs and saw that crap on there and we finally figured out that the muffler shop broke the manifold bolts off inside the manifold and then apparently just held the two together and put a HUGE glob of jb around to hold everything together lol!
needless to say, he was pissed and made them replace the manifold and all
Old 09-02-2005, 03:24 AM
TSPeed Factory
AzntaggeR's Avatar
jb weld doesn't fair too well against heat. they sell an exhaust patching kit at the auto parts store. just buy that for at temporary fix if you can't find a bolt to fit.
Old 09-02-2005, 03:51 AM
well i dont think there is any physical way to get a bolt in this hole without making a whole new DP (the pipe comes right up against the side of the hole, theres no clearance for the head of a bolt) so i guess i gotta weld it.
Old 09-02-2005, 04:21 AM
yellowturbo's Avatar
just weld in the hole, a stop at a welding shop and your set.
Old 09-02-2005, 06:22 AM
PM-Performance's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">it'll probly come off after awhile</TD></TR></TABLE>
I will tell you from experience as soon as the car gets up to temp it will boil right off.
Been there tried it in a pinch
if its a bolt hole, put a bolt thru it. or a plug
Old 09-02-2005, 07:08 AM
blundar's Avatar
This question warmed my heart.
Old 09-02-2005, 09:00 AM
flood's Avatar
Default Re: (blundar)
weld it.
I had my stock Y8 manifold welded with some stainless rod and it wasn't a problem after that. Do it right, JB weld will just be a problem again soon.
Old 09-02-2005, 12:14 PM
blackeg's Avatar
Default Re: (flood)
bolt or weld it- dont bother with the jb for this
Old 09-03-2005, 08:37 AM
yee SERIOUS's Avatar
Location: The Village Hidden in the Leaves: Seattle, WA
GOOOD LUCK! i don't think it'll hold.
Boilermaker1
Welding / Fabrication
05-30-2007 02:02 PM
StolenTeg
01-08-2006 11:12 AM
david@didrace.com
12-07-2004 06:01 AM
egturbo
06-17-2004 10:55 PM
OTT
02-19-2004 06:47 PM
Quick Reply: Can JB weld handle exhaust heat?
