> Wheel and Tire
Old 08-31-2005, 07:39 AM   #1
Mike_C
Moderator
Mike_C's Avatar
Default ► FAQ: How to paint your wheels
Originally Posted by doubleshotz
Since this topic has been popping up a lot lately, I decided to write up on painting wheels I did for my winter wheels.
Everything I used can be found in your local automotive parts store.
Materials
· Paint stripper + brush (that withstands the stripper)
· Wire brush
· Sandpaper (120-2000grit)
· Scuff pad
· Primer (optional)
· Paint
· Clearcoat
· Gloves
· Masking tape
· Blue shop towel
· Tack cloth
· Acetone
· Sanding Mask
· Spray can gun adapter (optional)
· Beer (optional)
· TIME AND PATIENCE
Some materials are not pictured
Wheel (OEM Integra)
Paint stripper (BIG container, not spray can)
<FONT COLOR="RED">READ THE INSTRUCTIONS ON PAINT STRIPPER BEFORE USE</FONT>
Step One: Strip
Removing existing paint and clearcoat on wheel
<FONT COLOR="RED">PROTECT EYES AND SKIN FROM PAINT STRIPPER AT ALL TIMES</FONT>
1. Pour the paint stripper in a metal can (I used a soup can). Dip the brush in can.
Start applying the stripper slowly with brush. DO NOT RUSH THIS STEP
2. The paint and clearcoat should start bubbling up shortly.
3. Set a timer to 20 minutes.
4. While you wait......
Step Two: Scrub
Scrubbing off paint and clearcoat. This will ensure you not to repeat step one.
1. Grab a wire brush (I used stainless steel)
2. Start scrubbing. Watch your eyes!!
3. Pressure wash off the remaining residue and air dry.
Step Three: Sand
Sanding down area that you wish to polish. Skip this step if you do not wish to polish.
1. Dry sand starting with 120 or 180grit if you have deep scratches and/or curb marks. If there is no damage start from 220grit. Work your way up to 320, 400, 600.
Here's how it looks after 120-400 (I sanded the lip only)
2. Wet sand starting with 600grit working up to 800, 1000, 1500, 2000. Use lots of water.
After wet sanding...
Step Four: Prep
Masking down area that will not be painted and scuffing.
1. Mask the area you polished and/or you do not wish to paint by using masking tape (I used green and blue, both by 3M)
2. Scuff down the area that will be painted with a scuffing pad. Take your time and make sure surface looks even.
3. Slightly wet 1/8 of a blue shop towel with acetone and start wiping down the scuffed area. Finally, wipe down with tack cloth to get every last piece of lint the towel left off.
Step Five: Primer
Spraying primer(optional). If you do not wish to use primer you may skip to the next step. You can use sandable primer, primer sealer, etc...
1. Make sure all surroundings are covered/masked unless you do not mind paint everywhere. Spray light coats. The first coat of primer should not fully cover the wheel.
After first coat of primer (I used primer sealer).
2. Wait 5 minutes, spray second coat. Again, lightly.
3. Wait 5 minutes, by now you can see the wheel is almost fully covered expect a few spots (depending on design of wheel). Lay down final coat of primer.
4. Let the wheel sit for about 15-20 minutes. If you used sandable primer, you may sand it down after it dries.
Step Six: Spray
Spraying paint and clearcoat.
1. Lay down first coat of paint. Several light coats to avoid runs and overspray. Spray in a sweeping motion (While pulling trigger move left, release. While pulling trigger move right, release. Repeat.)
After first coat..
2. Wait 10 minutes, lay down second coat.
3. Wait 10 minutes, lay down third coat.
4. Wait 10 minutes, inspect. At this point, if the wheel is evenly covered with paint you may stop and let it dry. If not, lay down another coat and call it final.
5. After final coat, color should look even across the wheel. Let it dry for 30 minutes before laying down clear.
While you wait..........
6. Lay down clearcoat just like painting. But you may use several medium coats instead of light coats to pull out more shine. Don't go crazy with it!!
(Sorry, no pictures of spraying clear)
Step Seven: Dry
Drying your work. Most overlooked process when painting at home. Failure to proper drying may result in repeating a lot of work.
1. After the final coat of clear, let it sit about 30 minutes before you transfer them to a cleaner safer place to air dry overnight.
2. Dry it overnight indoors.
Step Eight: Final Outcome
Inspect for damage and flaws under the sun. If you satisfied with the results, kickback, grab a beer, a blunt, a dutch, a L, a joint, whatever you want, and admire your work. Just don't forget you got 3 more to go.
1. Pull off the masking tape slowly. Be paitent!!!
Mmmhmmm
Optional Step: Polish
If you want that polished area to really shine, metal polish (mother's stuff works great), a polisher and/or power mini ball. Buff it up. Read instructions on metal polish.
Optional Step: Shine
Now you polished the metal so good the paint starting to look dull?
You can wet sand your clearcoat with 1500-2000grit sand paper to get a smooth even texture on the painted area. You can also polish the painted area with a rubbing compound, polishing compound, followed by wax.
This is not required but you may do it down the road once the paint fully cures. Give it about 2-3 weeks.
I didn't do the optional steps since these wheels are going to be hitting snow and salt 24/7.
As long as you have some common sense and know how to read, this job won't be a problem. Hope this helps the folks that PM'd me about this info.
Maintenance
Poor maintenance can make your wheels look worthless real quick.
For the first week just wash them down with low pressure water.
After that, wash your wheel separately when you wash your ride.
I use soap water but you can use your favorite wheel cleaner.
<FONT COLOR="RED">SOAK IT, BUT DON'T LET THE CLEANER/SOAP DRY OUT</FONT>
You may start buffing after they dry.
For painted areas,
pick your favorite rubbing compound and/or polishing compound followed by wax.
For polished areas,
pick your favorite metal polish followed by wax.
Polishing might not be necessary for every car wash.
You can re-polish them once a month or whenever they get dirty or dull.
Both buffing steps can be done by hand but I recommend a buffer/polisher and powerball mini (works great on lips) for the best results.
Don't forget about the tires, get your favorite tire wetter and let 'em shine!!
<FONT COLOR="BLUE">KEEP 'EM CLEAN!!!!</FONT>
copied from: http://www.honda-tech.com/zerothread?id=316500
Originally Posted by PatrickGSR94
Since lots of people have been asking about my wheels, I figured I would make a how-to for everyone to see. First, I'll go through the process I followed:
1. Clean off wheels thoroughly, then lay wheel/tire flat on ground.
2. Scuff wheel with sandpaper, then clean wheel again.
3. Stick index cards around edge of wheel between tire and wheel to keep paint off of tires.
4. Spray several light coats of paint onto wheel. I used DupliColor Wheel Paint, graphite color, available from AutoZone, $4/can.
5. Spray several light coats of clearcoat if desired, depending on how shiny you want the final product to be. Clearcoat will also make the final finish feel smoother.
Now, after doing that, here is what I have observed needs to be done in addition to those steps above:
- Before painting, you should use an aircraft stripper to remove ALL original clearcoat and any paint that is on the wheel to begin with. Take it down to bare aluminum.
- Clean wheel, strip off clearcoat (use gloves, and try to keep the stuff off the tires), clean off residue, clean/wash wheel again, then paint as above.
- As far as primer, I'm not sure if that should be used beforehand or not. I didn't, but you might have better results if you use it.
And now the before:
And after:
*NEW EDIT*
I touched up my wheels last week, added a bunch more gunmetal paint, and this time I used a TON of clear on top of it. Now they have a wet look to them which I think looks really nice.
Modified by toyomatt84 at 11:51 PM 4/7/2008
http://www.iammike.org
XBOX: iammikeDOTorg
I put more miles on my body than my vehicles.
Current: 93 Civic, 97 VFR, 01 Big Sur, 05 TCR2, 09 1x1
Past: 01 S2000, 91 Accord, 86 Delta 88, 95 Integra
Mike_C is offline Report Post   Reply With Quote
Old 09-02-2005, 10:11 AM   #2
streetinformer
streetinformer's Avatar
Send a message via AIM to streetinformer
Default Re: FAQ: How to paint your wheels (Mike C)
is there any pics of mesh integra wheels painted and on a car??
like so?? wat color show me picx thanx
streetinformer is offline Report Post   Reply With Quote
Old 09-04-2005, 11:05 PM   #3
DaZDiLI
Send a message via AIM to DaZDiLI
nice man , that looks clean
DaZDiLI is offline Report Post   Reply With Quote
Old 09-05-2005, 09:11 PM   #4
HONDASPANCHO
HONDASPANCHO's Avatar
nice job,,,,,to color goes with your teg
THE TOP IS SO MUCH BETTER THAN THE BOTTOM........SO MUCH BETTER
http://www.jdmchat.comwww.weaksauceforums.org
HONDASPANCHO is offline Report Post   Reply With Quote
Old 09-08-2005, 07:36 PM   #5
MPF_supra
MPF_supra's Avatar
Send a message via ICQ to MPF_supra
looks nice
jeep
MPF_supra is offline Report Post   Reply With Quote
Old 09-14-2005, 04:31 PM   #6
racer074
racer074's Avatar
Send a message via ICQ to racer074
Default Re: (MPF_supra)
i also have some gsr fat fives powder coated gunmetal...great color...very clean
BUMP...
1st::EF-rex stock::sold
2nd::DA-semi built::sold
3rd::DB8-gsr::sold
4th::accord-daily driver::sold
5th::EG::del slow-jdm b16/gsr head::sold
6th::EG::del slow-D16y8::sold
7th::DC2-built jdm b16:: sold
8th::EF8-was project 4 boost::Si-R::sold
9th::EG::del slow-D16z6::daily driver
10th::EF-rex::sold
racer074 is offline Report Post   Reply With Quote
Old 09-15-2005, 02:45 PM   #7
delsolb18c
delsolb18c's Avatar
Send a message via AIM to delsolb18c
Default Re: FAQ: How to paint your wheels (streetinformer)
great info!!!
delsolb18c is offline Report Post   Reply With Quote
Old 09-19-2005, 10:52 AM   #8
OneSickJDMBB6
OneSickJDMBB6's Avatar
Location: Watching Married With Children in, CA, United States
Default Re: FAQ: How to paint your wheels (delsolb18c)
hey what kind of sandpaper do u use? and do u sand it by hand or do u have to use a sander? Also, where do u get an aircraft stripper? I'm wondering this because I'm planning on painting my rims with a polished lip with a group of friends
http://JLyPhotography.com | http://www.flickr.com/photos/johnnyly/
2004 NBP TSX 6-Speed | Nikon D700 Gripped| PSN: OneSickJDMBB6
17-35 2.8|28-70 2.8|50 1.4|60 2.8|70-200 2.8 VR|Bunch of Flashes
OneSickJDMBB6 is offline Report Post   Reply With Quote
Old 09-19-2005, 08:55 PM   #9
hamburgler
hamburgler's Avatar
Send a message via ICQ to hamburgler Send a message via AIM to hamburgler
Default Re: FAQ: How to paint your wheels (Azn_JDMer)
they sell gunmetal color paint.......
95 rs integra- wrecked and for sale http://images.honda-tech.com/set1/smile/emhammer.gif
93 ej1-sold because im stupid http://images.honda-tech.com/set1//smile/emcrook.gif
95 ls integra- new project http://images.honda-tech.com/set1/smile/emcocktl.gif
need coilovers!!!!!
hamburgler is offline Report Post   Reply With Quote
Old 09-19-2005, 09:18 PM   #10
crxtuner98277
crxtuner98277's Avatar
why paint when you can powder coat? i recently bought an powdercoating over with a media blaster, and powder gun. if anyone who lives in the washington area and is up for powdercoated rims at hella cheap prices, send me an email at bmxerman98277@hotmail.com. put powdercoat as the subject line, or else i just delete.
~shane~
crxtuner98277 is offline Report Post   Reply With Quote
Old 09-25-2005, 06:37 AM   #11
cd5_2NR
cd5_2NR's Avatar
Send a message via AIM to cd5_2NR
Default Re: FAQ: How to paint your wheels (carless87)
yup...at any automotive shop...
CD Squad l ♠ HardParkerKrew™ # 80 ♠
PSN: [NUG] R1zzZ_O
cd5_2NR is offline Report Post   Reply With Quote
Old 09-27-2005, 08:55 AM   #12
T.
T.'s Avatar
i painted then semi glose black with a teal lip to match my car...i'll try to get pics if u want, ls mesh are harder to work with sinse it has alot of hidden surfaces and spokes but well worth the time
WTB: koni yellows for eg and 450cc or more injectors
'93 civic b18c forsale: http://www.hondamarketplace.co/showthread.php?t=2537139
THC #116 BiAtch
T. is offline Report Post   Reply With Quote
Old 10-02-2005, 12:20 AM   #13
xdrian
xdrian's Avatar
came out really good
SPP/// StreetProvenPerformance
WRX-320WHP 406WTQ 12.2@113
xdrian is offline Report Post   Reply With Quote
Old 10-04-2005, 09:51 PM   #14
650jdmhatch
650jdmhatch's Avatar
Send a message via AIM to 650jdmhatch
i like your job man..umm what kind of sand paper did u use.
650jdmhatch is offline Report Post   Reply With Quote
Old 10-14-2005, 01:22 PM   #15
mmmsushi
Send a message via AIM to mmmsushi
seems pretty easy, but results would probably be better with primer before paint, and nice color choice.
mmmsushi is offline Report Post   Reply With Quote
Old 10-18-2005, 11:43 AM   #16
HONDA RR
HONDA RR's Avatar
Hey man it looks really nice . I want to do those to my gsr blades.
HONDA RR is offline Report Post   Reply With Quote
Old 11-09-2005, 12:24 AM   #17
Dee_SydekicK
Dee_SydekicK's Avatar
Send a message via ICQ to Dee_SydekicK Send a message via AIM to Dee_SydekicK
pretty good and easy tips. now imma go and paint my mesh rims
Get 20% off your purchase at KARMALOOP.com with no min purchase. Just simply use the REP Code=AO20193 .All street wear clothes
For cheap wholesale aftermarket parts click on http://www.rms-usa.com/
Dee_SydekicK is offline Report Post   Reply With Quote
Old 11-13-2005, 05:45 PM   #18
DCnotTHEshoes
DCnotTHEshoes's Avatar
nice
DCnotTHEshoes is offline Report Post   Reply With Quote
Old 11-17-2005, 10:24 AM   #19
RHDelSol
RHDelSol's Avatar
Send a message via AIM to RHDelSol
looks good. i did this to my friends wheels. They were more involved b/c they were two piece look-a-likes. We put fun-tak over the fake bolts to keep them from getting painted. They came out pretty good.
RHDelSol is offline Report Post   Reply With Quote
Old 11-21-2005, 09:55 AM   #20
jerkwrenchEM1
jerkwrenchEM1's Avatar
Send a message via AIM to jerkwrenchEM1
nice!! Looks clean
JERKWRENCH aka "JERKZ"
[EM1 CREW]
jerkwrenchEM1 is offline Report Post   Reply With Quote
Old 12-07-2005, 08:18 PM   #21
H22a T13
H22a T13's Avatar
Send a message via AIM to H22a T13
I hae some scratches on the face of my rims, what would be the best way of getting rid of them b4 the painting.
93 Civic SI - Current
95 Prelude SE - Stolen
Originally Posted by Ollie
IF YOU SPRAY YOUR GAY IF YOU SPOOL YOUR COOL
H22a T13 is offline Report Post   Reply With Quote
Old 12-11-2005, 11:59 PM   #22
Andrew619
clean
Andrew619 is offline Report Post   Reply With Quote
Old 12-15-2005, 07:36 AM   #23
midnightperformance
midnightperformance's Avatar
Those rims look really nice
midnightperformance is offline Report Post   Reply With Quote
Old 12-27-2005, 10:37 PM   #24
bigtuffguy
bigtuffguy's Avatar
Default Re: (midnightperformance)
sweet, gj man
i'll be doing this tomorow
someone got the same mags as me in my neighborhood, so i have to 1up him. :D
bigtuffguy is offline Report Post   Reply With Quote
Old 01-04-2006, 06:57 AM   #25
hb420
hb420's Avatar
Send a message via AIM to hb420
i did mine a while ago but with all the salt from the snow we had a little bit ago and me being lazy and not cleaning them they have to be redone heres a pic with the wheels on my car. I did them gold with a silver lip.
hb420 is offline Report Post   Reply With Quote
Bookmarks
cans, forums, gold, honda, hondatech, ls, mesh, msr, paint, rim, rims, rota, school, tech, wheel, wheels
