Got my ES mounts for my 90 integra rs But I have a questions- Pics!
Hey guys whats up,
I got my ES Motor mounts because my upper left motor mount is broken
So I just have a question.
Do I hammer the old rubber mount out? and just put these in?
Cuz I thought these replace the oem rubber inserts
While it looks like the ES motor mount inserts looks likes I put them in <U>with</U> the oem rubber motor mount
but mine is broken, so Would it be ok to install these with the broken oem mount if that's the way it needs to be done??
Do I need the OEM Rubber mount to install these? or can I hammer it out and just put these in,
Here are some pics,
This is the one that is gone bad....
This kit also replaces this one too right...
And this rear mount behind the motor...
Thanks, Later
Here are some pics,
Thanks, Later
ES doesnt come with upper mount inserts
it tourqe mounts
aka
front tranny
and rear engine
driverside mount THERE ARE no es inserts
for that u gotta go with prothane
to install es inserts u dont hammer anything out
u wedge 2 inserts on both sides and zip tie em together
it tourqe mounts
aka
front tranny
and rear engine
Re: (importdude2000)
I would suggest using only the front ones. The rear mount is very difficult to get off, I gave up on it. The front two inserts are very easy to do and do make a significant difference
Re: (ProjectDarkBlack)
Ok, So this is for the front engine mount, the rear engine mount,
and the mount above the tranny?
This sucks, Where can I get the inserts for the upper mount That I have broken,
I'll get a mount from the junkyard
Ok thanks,
Also, I'l do the rear engine mount becuase,
I have to drop the tranny to install my Aasco 8lb flywheel
Might as well and tame the time to do it right
Ok thanks,
Re: Got my ES mounts for my 90 integra rs But I have a questions- Pics! (90DA-Pedro)
plently of people make that upper mount, but they are usually a bit of money, and might come in a kit with the other mounts. Like Hassport and all the copy designs on ebay
Re: Got my ES mounts for my 90 integra rs But I have a questions- Pics! (BlackLudeSi)
I believe Prothane has the 2 top mounts. I think they have to pressed out and the new ones pressed in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">ES doesnt come with upper mount inserts
it tourqe mounts
aka
front tranny
and rear engine
<U>driverside mount THERE ARE no es inserts
for that u gotta go with prothane</U>to install es inserts u dont hammer anything out
u wedge 2 inserts on both sides and zip tie em together</TD></TR></TABLE>
it tourqe mounts
aka
front tranny
and rear engine
darcane
Honda Civic (2001 - 2005)
08-06-2013 07:07 AM
