Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 08-27-2005, 04:29 PM   #1
pbink
pbink's Avatar
Default how long do catalytic converters last?
I'm getting a gnarly clicking/rattling sound during certain levels of acceleration as well as sense that my exhaust is getting blocked somehow...
How long do catalytic converters usually last? Is it dependent on mileage or lifespan, and what are some common symptoms of a bad/old cat?
'93 Accord LX coupe 5spd - stock
:::yesteryear:::
'99 Integra GSR hatch 5spd - shaved, CAI (mistakes hurt) http://images.honda-tech.com/set1/smile/emthdown.gif
'94 Saturn SL2 <-- T-boned (thank you State Farm! hello GSR!) http://images.honda-tech.com/set1/smile/emthup.gif
"I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it." -Thomas Jefferson
pbink is offline   Reply With Quote
Old 08-27-2005, 04:51 PM   #2
G2 Speed
G2 Speed's Avatar
Default Re: how long do catalytic converters last? (pbink)
i would assume mileage because... it filters the exaust gases that go threw..
G2 Speed is offline   Reply With Quote
Old 08-27-2005, 10:06 PM   #3
2000psi
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Send a message via AIM to 2000psi
Default Re: how long do catalytic converters last? (G2 Speed)
pull the cat off and look through it to see if it's clogged...I've heard they will make a rotten egg smell when they go bad too, The cat should last at least 90K miles on an engine thats not tuned to run rich.
2000psi is offline   Reply With Quote
Old 08-28-2005, 11:25 AM   #4
pbink
pbink's Avatar
Default Re: how long do catalytic converters last? (2000psi)
so no one's had a cat rattle on them?
:::yesteryear:::
Old 08-28-2005, 11:50 AM   #5
Lord Helmet
2013 Toyota Tacoma
Lord Helmet's Avatar
If you cat is rattling then it a sign that you're running too lean of a condition(High Nox). Hence the reason the mounting pad inside the cat is melting off the honeycomb brick inside the cat which is why the cat has that rattling sound. It's tumbling all around the cat. Check camshaft timing and crank timing is within specs and not overtly advanced.
My girls: 92 DA9 stock , Boosted 2013 Tacoma TRD
Lord Helmet is offline   Reply With Quote
acura, bad, catalytic, converter, converters, cover, gsr, honda, honeycomb, how, last, long, melting, rsx, shoud
