Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 08-25-2005, 07:01 PM   #1
310BHPB16
310BHPB16's Avatar
Default How DO I fix A Warped Cylinder Head ??
hello guys i just took the head off my motor so as to change the Headgasket.
and when i checked the cylinder head it seemed warped in the middle as there was a dip when i place a ruler across it !!
how can i ensure that the head is flat ???
will this be a big problem if i just put the head back on ???
if i sand the high area's so they match the low ones...should it be ok ???
what paper is best to use ??
any other advice please
310BHPB16 is offline   Reply With Quote
Old 08-25-2005, 07:15 PM   #2
projectTeG
projectTeG's Avatar
Send a message via AIM to projectTeG
take it to a machine shop and see if its servicable
RIP DonF.
projectTeG is offline   Reply With Quote
Old 08-25-2005, 07:55 PM   #3
ATS_Antone
ATS_Antone's Avatar
Default Re: (projectTeG)
: ATS garage :
<U>http://www.honda-tech.com/zerothread?id=1563491</U>
ATS_Antone is offline   Reply With Quote
Old 08-25-2005, 08:47 PM   #4
mgags7
mgags7's Avatar
put in in the oven, wait until its hot, and then bend it....
if its that bad it may be beyond the reaches of head milling....
mgags7 is offline   Reply With Quote
Old 08-25-2005, 08:54 PM   #5
xEnderx
xEnderx's Avatar
Send a message via AIM to xEnderx
Default Re: (mgags7)
Millign can fix it, but you will also need to figure out how that is goign to affect CR and piston to valve clearence at TDC. If there it is REALLY REALLY warped then I would suggest jsut gettign a new head.
H.E.A.R.T.
Honda Enthusiasts Against Ricer Trash
xEnderx is offline   Reply With Quote
Old 08-26-2005, 06:17 AM   #6
310BHPB16
310BHPB16's Avatar
Default Re: (antone)
its not warped very much maybe a 2 mm
ok i read if i use a service plate and abrasive paper of 400 (waterproof silicon carbide and i placed paper of the surface plate and rub against the gasketed surface ...if the warping is not too bad it would be ok.
i will check the surface again with a better instrument
if i get the head machined will it have a higer compressio ratio
and will i need to use cam gears to bribg it back into timing range ???
Old 08-26-2005, 09:17 AM   #7
MOTOCOMPO
MOTOCOMPO's Avatar
Default Re: (310BHPB16)
2mm is HUGE. like everyone said, take it to a machine shop and see what they say. if it's really 2mm, most likely it's not fixable.
and if you did resurface it, the cam journals could be off aligned causing the cam to lock up.
Modified by MOTOCOMPO at 10:43 PM 8/27/2005
MOTOCOMPO is offline   Reply With Quote
Old 08-26-2005, 04:08 PM   #8
Rocket
Default Re: (MOTOCOMPO)
Click the image to open in full size. MotoCompo
Do cams like to run in a bent cam tunnel? Click the image to open in full size.
Something to Think About
Does milling the bottom the head fix this?
Rocket is offline   Reply With Quote
Old 08-26-2005, 07:59 PM   #9
Honda Sport
Honda Sport's Avatar
Send a message via AIM to Honda Sport
Default Re: (xEnderx)
also cam timing will be off. Click the image to open in full size.
Honda Sport is offline   Reply With Quote
aluminum, camshaft, cylinder, diy, fix, fixable, fixing, head, journals, machine, plate, put, shop, straighten, surface, warped
