Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 08-24-2005, 11:31 PM   #1
BlueShadow
Default burping coolant system by running car with heater on and no radiator cap--how long?
Hi guys,
I need to make sure all the air is out of the coolant system cause I just refilled it. My water outlet didn't have the bleed screw so I have to burp the system by runnin it with no rad cap.
My question is how long do I ned to keep it running until I can stop? Right now the coolant is all the way to the radiator neck. So should I just run the car until it is fully warmed up, or should I run it for a certain amount of time? in either case the coolant would start overflowing out the rad cap, so do I just ignore it and keep running the motor?
TIA
BlueShadow is offline   Reply With Quote
Old 08-25-2005, 06:57 AM   #2
JimBlake
JimBlake's Avatar
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (BlueShadow)
I just watch the water in the radiator neck, so it doesn't overflow. I also push & squeeze the radiator hoses to push air bubbles over one way or the other. If your cap & reservoir bottle are working correctly, the last little bubbles should work out the next couple times you drive.
After having it open, I check the hoses every day or so until they're full. When you squeeze the hoses cold, you can hear whether there's air sloshing around in there.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 08-26-2005, 05:00 AM   #3
BlueShadow
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (JimBlake)
Yup, I "massage" the upper radiator hose too to get the air bubbles outand fluid to go down. I think I got most of the air bubbles out now since I've driven the car around for a bit.
Old 09-01-2005, 07:08 PM   #4
NitroStickers
NitroStickers's Avatar
im curious to, i just did a flush on my system, i refilled it and ready to bleed. i let car run with heat on and the nipple open, foam was coming out and then just nothing. i thought your supposed to get straight fluid come out streamin???????????
<FONT COLOR="DarkOrange">NitroStickers.com
Custom Vinyl Shop
Bloomfield, NJ
Full Sticker Catalog
orders@nitrostickers.com
AIM: nitrostickers</FONT>
NitroStickers is offline   Reply With Quote
Old 09-02-2005, 12:01 PM   #5
95lstegman
95lstegman's Avatar
Send a message via AIM to 95lstegman
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (NitroSticke
can you see fluid at the radiator neck? maybe it's just very low . . . tell you guys the truth, i never use the bleed screw. i run it for about 5 mins w/heater on full hot, shut it off, leave it alone and next time it's cool and i'm thinking about it and in the mood i check the level and top off if needed. it only goes down a little tiny bit, and your car will stay cool with only half of its coolant capacity.
It's true; there is no replacement for displacement.
~Jason
2004 Audi S4 4.2 Quattro 6MT, 2013 Hyundai Veloster Turbo 6MT
95lstegman is offline   Reply With Quote
Old 09-02-2005, 02:35 PM   #6
NitroStickers
yes its filled to the top.
Custom Vinyl Shop
Bloomfield, NJ
2008, air, bleed, bubbles, burp, burping, cap, car, coolant, corolla, heat, heater, no, on, radiator, toyota
