#1 | |||||
The artist formerly known as maxvtec7500.... http://www.hondamarketplace.com/zerothread/1896951 |
#2 |
GRRRRRRRRRREAT write up - it should go into the essential prelude links.......
#3 |
god damn those pictures are huge! I will resize'em guys. Sorry
EDIT: much better. Let me know what you think! Modified by maxvtec7500 at 12:59 PM 8/22/2005
#4 |
Thanks NaptownKing, I was hoping it would be put there to cherish forever and ever
#5 |
Well done!
95 Prelude -intake, windshield washer lights, rear body kit, carbon fiber windows |
#6 |
is there any difference in braking now and are there any draw backs?
#7 | |
#8 |
Or you could try using an adjustable brake proportioning valve
It's not rust, it's free weight reduction http://images.honda-tech.com/set1/smile/emwink.gif |
#9 | |
#10 |
Damn, now I want to do that! ABS is annoying as sh1t during autox. I had a Prelude S before my Si and I never missed ABS then.
#80 94 Prelude Si "What's behind you doesn't matter." -Enzo Ferrari BayAreaPrelude |
#11 |
so in your opinion the prelude does better with out the abs . cause i just got done doing the 5lug conversion and i didnt want to spend the 250 per sensor thats required to get the rear abs sensors to work. but i just dont want to take out the abs and have some god awful braking results you know
#12 | |
#13 |
sorry to go slightly off topic, but is the rear abs sensors the only thing you need to have fully functional abs when going 5 lug?
#14 |
1995 Honda PreludeJoin Date: Oct 2003
Very nice write-up. I will eventually do this when I swap out my current engine for yet another...
BTW for anyone with a 4th gen, it is simple to disable the ABS. All you have to do is drive around for 30 seconds with the emergency brake switch turned on (Brake not actually applied, but just enough to get the dashboard light to switch on). After 30 seconds the ABS light will come on and the actual ABS unit will be deactivated. Of course you could probably pull a fuse or something too but I have never had a problem either way. Pirate
Chris Bolis is a douchebag. He capitalizes on a community's work without giving due credit. ..........Fact: Hondata eBay Paypal Tilton = Wankers My K24 Hybrid Alive as of 18:11 5/26/08, 262whp 200wtq 91 oct tuned |
#15 | |
Anyways, I'm glad this is helping some people, I will get more pictures of the final product when I get back home.
#16 |
yes you will notice that the spindles have a different bolt pattern for the sensor so you either have to machine the spindle or get the sensors......but if you have done the conversion yet keep in mind it could get priceyyyyyyyy.... i used all new parts from honda and i spent around 1500 on it and i didnt even get the rear sensorsyet thats why i think im just gonna pull the abs system all together.
#17 |
wow thats coo ive done it to my teg...only thing i did different was kept the stock brake master cylinder...ran it to a rs-40/40 prop valve...and called it a day...brakes very well and i def dont miss my abs...
OEP 4 Life...no other way to be http://images.honda-tech.com/set1/smile/emthup.gif |
#18 |
why again is it that you didn't want abs? lose 20 pounds and you can keep it on there and never notice.
92 hatch beater commuter on omni sports 98 supra getrag 6spd T88 |
#19 |
weight reduction along w/ better controlled braking.dry braking that is
#20 | |
#21 |
is it possible just to use the prelude s model parts in order to eliminate the abs just a question
#22 | |
#23 | |
#24 | |
#25 |
why did you have to remove the booster and master cylinder? When I did this in my accord I left them, I would think you could do the same with the prelude.
| Bookmarks |
