Changing Transmission Fluid
Old 08-15-2005, 08:38 AM
bemused's Avatar
Default Changing Transmission Fluid
I have a 1999 4 cylinder Accord auto with 102,000 miles on it. I want to change the transmission fluid. What's the best way of doing this? Is there a drain plug on the transmission and how much fluid will come out when I remove it? Do I need to drain it, refill it, run the car for a short time and then repeat to replace the old fluid?
Old 08-15-2005, 10:48 AM
0x5359-0055
213374U's Avatar
Default Re: Changing Transmission Fluid (bemused)
Once again.....
Old 08-15-2005, 02:21 PM
YeuEmMaiMai's Avatar
you would open the drain bolt and let the fluid drain out add between 3-5 quarts of fluid (add until it shows at the proper level on dipstick) and drive car for a few miles. repeat 2 or 3 more times. I would find a honda dealer with a wynns trans flush machine and have the trans flushed. I change my fluid once a year and it seems to work just fine. I drive about 10K a year
Old 08-15-2005, 04:33 PM
P_Adams's Avatar
Default Re: Changing Transmission Fluid (YeuEmMaiMai)
I vote for the complete trans fluid flush, It's the only way to get everything out and replace it with new fluid correctly.
P
Old 08-15-2005, 05:10 PM
bemused's Avatar
Default Re: Changing Transmission Fluid (Vt4cPwn35)
Thanks guys, I do the dump and fill on my other car, I wondered if it was a normal thing to do on the Honda.
Vt4cPwn35, you're a funny bloke aren't you?.........
Old 08-15-2005, 05:34 PM
hondadude's Avatar
When I learned to tie my shoelaces I didn't make fools of people that couldn't tie their shoelaces. [Albert Einstien]
There is a drain plug on the lower part of the trans that has a 3/8" square hole in it.
Remove that plug with a 3/8" drive ratchet, clean off the second gear clutch pak material from the magnet attached to the drain plug. Reinstall the drain plug then put in 3 qts of genuine honda trans fluid.
No doubt some simpleton will now jump in and SHOUT the 'book' calls for 2.8 qts of trans fluid, but I've been doing this for over 22 years and have NEVER seen a honda trans hurt by having .2 qts extra fluid in it.
Old 08-15-2005, 07:53 PM
0x5359-0055
213374U's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bemused &raquo;</TD></TR><TR><TD CLASS="quote">Vt4cPwn35, you're a funny bloke aren't you?.........</TD></TR></TABLE>
I try
Old 08-28-2005, 06:02 AM
Integra_Boi's Avatar
i just did mines yesterday but on a civic hx (1999 cvt auto), i stuck 3 quarts in and its barely reading the line on the dip stick? Would it be odd to add mor then 3 quarts?
Old 08-28-2005, 11:52 AM
Chiovnidca's Avatar
Default Re: Changing Transmission Fluid (Integra_Boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_Boi &raquo;</TD></TR><TR><TD CLASS="quote">i just did mines yesterday but on a civic hx (1999 cvt auto), i stuck 3 quarts in and its barely reading the line on the dip stick? Would it be odd to add mor then 3 quarts?</TD></TR></TABLE>
Do you have the car sitting level?
Old 08-28-2005, 12:01 PM
goowakjai
Guest
Posts: n/a
Default Re: Changing Transmission Fluid (Chiovnidca)
is it absoltely neccesary to flush the tranny? i changed mine about 6K ago and just changed it like i would oil...didnt flush the tranny, is this a problem, shud i go back and do the whole thing over but this time flush it?
Old 08-28-2005, 01:18 PM
Beach Accord's Avatar
honda recommends against trans flush machines.
a few drain and refills, however is not a bad idea.
Old 08-28-2005, 02:28 PM
car was level in a garage.....
Old 08-28-2005, 03:03 PM
cambopheonix56's Avatar
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">honda recommends against trans flush machines.
a few drain and refills, however is not a bad idea.</TD></TR></TABLE>
i agree. don't flush the trans.
Old 02-19-2007, 08:00 PM
Mitsu's Avatar
Default Re: (cambopheonix56)
i'm a noob, where is the drain plug located on the accord? will the pan be marked appropriately? wouldn't want to drain the brake fluid or something.
Old 02-19-2007, 08:28 PM
BLKFLSH's Avatar
Default Re: (Mitsu)
There is only one drain plug down there with a 3/8" drive hole in it. It's at the lowest part of the trans, so I doubt you can miss it. The engine oil drain plug has a bolt head on it, and it's on the engine oil pan. I change out 3 quarts every 15,000 miles, so hopefully I will never need a flush.
PS: re-using the crush-washer will do just fine.
Old 02-20-2007, 02:32 AM
pos_cd5's Avatar
Default Re: (BLKFLSH)
wow, way to birng back a old *** thread, lol.
Old 02-20-2007, 03:19 AM
I know but if you use the ones that use your transmission's internal pump, you should be OK. I would definately stay away from the ones that "power flush" versus the ones that are basically 2 large tanks with a hose going to eachone that attaches directly to your trans cooler lines.
Old 02-20-2007, 03:20 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">wow, way to birng back a old *** thread, lol.</TD></TR></TABLE>
well, it shows they are using the search
Old 02-25-2007, 02:26 PM
Mitsu's Avatar
Default Re: (TouringAccord)
Other then new filter, replacement fluid, drain pan, jacks and wrench, is there anything else I might need? Should I use those oil drain box soakers for the trans gunk?
Old 02-25-2007, 07:28 PM
pos_cd5's Avatar
Default Re: (Mitsu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mitsu &raquo;</TD></TR><TR><TD CLASS="quote">Other then new filter, replacement fluid, drain pan, jacks and wrench, is there anything else I might need? Should I use those oil drain box soakers for the trans gunk?</TD></TR></TABLE>
from what im told, the accords dont have a serviceable transmisson filter
Old 02-25-2007, 07:30 PM
sony224422's Avatar
nope they don't. they have an internal one thats only accessed when shes cracked apart.
Old 02-25-2007, 07:41 PM
importfanatic17's Avatar
Default Re: (sony224422)
If I were you, I would open the fill plug first. That way, you won't be screwed if you drain the fluid and can't open the plug to fill it up!
Old 02-25-2007, 07:58 PM
sony224422's Avatar
Default Re: (importfanatic17)
the plug is just a thing like the dipstick i do believe.
Old 02-25-2007, 09:49 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">the plug is just a thing like the dipstick i do believe.</TD></TR></TABLE>
no, the drain plug is where you drain the ATF fron. the dipstick is where you also fill the transmisson from.
Old 02-25-2007, 10:09 PM
sony224422's Avatar
i know that, but the person above me said to open the dipstick first.
Quick Reply: Changing Transmission Fluid
