iacv coolant lines?
#1 Super Guy
Re: iacv coolant lines?
If they were clogged, everything would be fine...they just wouldn't heat the IACV. The coolant is routed to them to prevent icing in the winter.... Now If the hoses were letting air into the system during cool-down, then you could have an idle problem. The most likely problem would just be leaking coolant under pressure (when hot).
Also check the seal on the lower half of the IACV that has the two nipples. Mine was leaking at this point cause the rubber seal was hard and cracked. Unfortunately you cannot get this rubber seal anywhere. I simply took the old hard broken pieces and coated them with Hondabond. Seemed to do the trick. No more leaks.
Here is a photo I found that's similar. Shows the seal and coolant chamber disassembled. This rubber seal was never sold separately for the CRX IACV (at least not my Si).
Thanks for clearing that up for me.
EFB055
Isn't the point of them that the flowing coolant heats the wax and adjusts your idle depending on coolant temperature? this aids idle up on cold start. If it's clogged your idle would be affected.
#1 Super Guy
No not in the IACV. You're thinking of the Fast-Idle-Thermo-Valve) which is a different device completely and mounted underneath the throttle body (and I'm not sure if any US CRXs came with). I know for sure the 89-91 Si has a Fast-Idle-Solenoid (ECU controlled on/off). Again a different device from the IACV.
Fast Idle Solenoid:
Fast Idle Thermo Valve
Fast Idle Solenoid:
EFB055
Fast Idle Solenoid:
Fast Idle Solenoid:
Honda IACV explained - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
TLDR:
IACV compensates for engine loading, FITV increases idle when the car is cold.
It doesn't explain why the IACV has coolant lines running to it though.
Its in there sp33
The IAC valve is supplied heated water, via two small coolant hoses, to keep the valve from developing ice during cold operation. The IAC valve is not sensitive to the temperature increase from the heated water. The position of the IAC valve's plunger is totally dependent upon the amount of time the ground is on, which is controlled by the ECM.
nice write up
nice write up
