Old 08-08-2005, 07:09 PM   #1
Silvteg95
Silvteg95's Avatar
Default power steering fluid shooting out the resevoir
I'm hearing a grinding noise from my car and i was wondering if it was because i didnt have enough power steering fluid in the resevoir, which was just below the minimum( supposed to be betweend min.&max.) so as i was turning the wheel and watching the power steering pump there was fluid coming out of the resevoir with the cap on!! what the deeal?! Click the image to open in full size.
Silvteg95 is offline   Reply With Quote
Old 08-08-2005, 07:36 PM   #2
Silvteg95
Silvteg95's Avatar
Default Re: power steering fluid shooting out the resevoir (Silvteg95)
Im guessing that there is too much pressure in the pump maybe and thats why the fluid came pouring out, but im not too sure
Old 08-08-2005, 08:41 PM   #3
vidanator
vidanator's Avatar
same thing happened to me, but it was during the winter only
vidanator is offline   Reply With Quote
Old 08-09-2005, 10:20 AM   #4
Silvteg95
Silvteg95's Avatar
Default Re: power steering fluid shooting out the resevoir (vidanator)
really, i have no clue why this happened, but im still thinking its the pressure
Old 08-09-2005, 11:21 AM   #5
Silvteg95
Silvteg95's Avatar
ive serached and havent found anything, i really dont want to drive the car now since whenever i turn itll lose fliud and come out the resevoir
Old 08-09-2005, 12:15 PM   #6
95 integra
95 integra's Avatar
iTrader Rating: (1)
It does kick up alot but with 3 layers of seals Im wondering whats wrong with your cap.
- After 8 years I have an Integra that isnt making that damn buzzing sound from the abs pump.
- 2003 Berlina Black S2000 w/ OEM Hardtop and some other OEM goodies.
95 integra is offline   Reply With Quote
Old 08-09-2005, 12:19 PM   #7
JinteDgraM
JinteDgraM's Avatar
Default Re: power steering fluid shooting out the resevoir (95 integra)
mine did that after i put in NON honda fluid 2 weeks after I got my car.
Guess who has manual steering now.
Even though I totally shoulda known better, I HONESTLY think there should be a "Your PS will explode if you use ANYTHING but honda PS fluid". Instead of "Only use Honda Genuine Fluids" (That type of phrase is used everywhere).
Wait, i work for honda. Maybe I should sugggest that. haha.
JinteDgraM is offline   Reply With Quote
Old 08-09-2005, 04:18 PM   #8
Sam92Teg
Sam92Teg's Avatar
Default Re: power steering fluid shooting out the resevoir (JinteDgraM)
I imagine alot of people that are not familiar with honda's would buy regular power steering fluid and ruin there pumps. I have never owned a honda before, and am so glad that when I first went to buy power steering fluid I saw some "made for Honda" specific fluid, saved my ***.
[B]92 RS Integra For sale, $1800 OBO[/B]. [email]sam92teg@yahoo.com[/email] , 300K miles, still running like a champ. Idles solid 750 rpms, gets 30 mpg, and 5K mile oil changes. Recent Exedy clutch, Fidanza 7.5 lb flywheel, AGX's, Koni yellows, Nuespeed Sport springs, Ingalls camber kit. Needs paint.
Sam92Teg is offline   Reply With Quote
Old 08-09-2005, 04:43 PM   #9
95 integra
95 integra's Avatar
iTrader Rating: (1)
Default Re: power steering fluid shooting out the resevoir (Sam92Teg)
I always used Honda in my GSR, but in the civic I put in shitty $.99 **** and it seems to be working fine.
Old 08-09-2005, 05:33 PM   #10
slomofo
GDD Member
1991 Geo Metro Type-R
slomofo's Avatar
iTrader Rating: (1)
solbrothers xtrac1 George Knighton ILcrxsi1 uncle_ben markspan6243
Send a message via ICQ to slomofo Send a message via AIM to slomofo Send a message via MSN to slomofo Send a message via Yahoo to slomofo Send a message via Skype™ to slomofo
Loosen the power steering belt. If you put it on too tight, the fluid will boil.
Originally Posted by turbohatch96y7 View Post
I love a good creampie!
slomofo is offline   Reply With Quote
Old 08-10-2005, 01:18 PM   #11
Pootie
Pootie's Avatar
Default Re: (slomofo)
How is that?!
Pootie is offline   Reply With Quote
Old 08-10-2005, 01:51 PM   #12
Sifu
Sifu's Avatar
You need some of those "mAd TiGhT" JDM spoon reservoir covers now Click the image to open in full size.
Sifu is offline   Reply With Quote
Old 08-10-2005, 02:31 PM   #13
PandaBear
PandaBear's Avatar
It should be the other way around usually. But too tight will force the shaft/bearing to have too much stress on the mating surface and cause heat up.
Use 5mm flex on the long side as guideline on how tight the belt should be.
PandaBear is offline   Reply With Quote
Old 08-11-2005, 01:01 PM   #14
Pootie
Pootie's Avatar
ever seen this scenario? My ps was not working and eventually the fluid boiled out. I changed the pump and it worked for about 1 min. then stopped working again and the fluid boiled out once more. any idea what the culprit might be, besides the belt being too tight?
Old 08-11-2005, 02:24 PM   #15
95 integra
95 integra's Avatar
iTrader Rating: (1)
Default Re: (Pootie)
boiled out? Its hard to boil fluid until it dissappears....are you sure that the pump didnt just pump it all to the rack and that u needed to add more?
Old 08-11-2005, 04:08 PM   #16
slomofo
GDD Member
slomofo's Avatar
iTrader Rating: (1)
Maybe your power steering cooler is bad.
Old 08-11-2005, 06:14 PM   #17
Pootie
Pootie's Avatar
this stuff boiled...started smoking.....I don't think it's the cooler because it stopped working only after 1 minute...okay boiling, i dont' know, but it started smoking and started gushing out from either the pump or the reservoir
2003, accord, boils, cap, clutch, coming, ex, fluid, honda, integra, power, reservoir, steerin, steering, wrong
